Old 03-06-2011, 11:41 AM   #19921
Hello
What's the average 10.5 tc setup ?
thank
zozo is offline   Reply With Quote
Old 03-06-2011, 11:50 AM   #19922
Starteur's Avatar
Originally Posted by Starteur View Post
Good morning,
we run "N" 17.5 motors in our sedan class (by rules), I have the endbell timing set at 45, RS speedo in spec mode,
Brake 100%
Drag brake 20
No Boost
No turbo
Throttle profile 3
Current limiter None
Here is my problem:
I upped the endbell timing to 45 (before it was 30, with a 53 pinion), I do a 5min with a 50 pinion and get off at 172 degrees wich is too much, but I did apply the 1 tooth per 5 degrees of timing recommendation.
I then go down to a 47 pinion and get off the track after 5 minutes at 175 degrees ?????
I don't understand, I went down 6 teeth and it still overheats!
Thanks for the help
Anyone?????
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer -Tamiya F-104X1 Formula 1 Racer.
Starteur is offline   Reply With Quote
Old 03-06-2011, 11:56 AM   #19923
wingracer's Avatar
Trader Rating: 24 (100%+)
Anyone?????
Put a fan on it or back off the timing.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 03-06-2011, 04:58 PM   #19924
darrenoakley's Avatar
Any one know if there are plans to bring the hotwire interface out for the MacOS ?
Xray x11
Xray T3 011
darrenoakley is offline   Reply With Quote
Old 03-06-2011, 10:24 PM   #19925
That's for that 10.5 SC setup Randy...it seemed to run quite well today in my SC10. I geared it more for our shorter track but other than that I used the same setup. The truck itself still needs some work to get balanced out but the power definately wasn't holding it back. Truck felt great with my 3800mah practice pack but not so good with the 5000mah pack I use for racing. I think I'm going to have to work on battery placement some to get a better balance overall.
Old 03-07-2011, 08:02 AM   #19926
Default ????
Originally Posted by zozo View Post
Hello
thank
I need a bit more information, what size track are you racing on?
Team Durango UK, Muchmore Racing
Adam Howe is offline   Reply With Quote
Old 03-07-2011, 12:28 PM   #19927
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Anyone?????
175 isn't overheating in my opinion after 5 minutes in the blinky stock class.
The ? is how were your laptimes? How did the car feel on the track?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 03-07-2011, 01:33 PM   #19928
install windows under your mac os, that should solved your problem.
and then set the hot wire interface from your windows
flashrevolution is offline   Reply With Quote
Old 03-07-2011, 05:00 PM   #19929
TheCoolCanFanMan's Avatar
Hi
I experiencing a lack of punch off the grid, simular to what the GM esc's experience. I run a 13.5 redine motor it does it, I run a Duo 2 and it does it. I have reset my Helios 10 handset with 90% epa to the esc then turned it up to 110% and still it happens
Any help would be appreciated.
Cheers Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 03-07-2011, 09:36 PM   #19930
bvoltz's Avatar
Trader Rating: 44 (100%+)
Anyone?????
Does your car have a bind in it? Does it role free? Do you have a bearing that has gone bad?
Just asking... I have had a bearing in the wheel (running on carpet) that got fuss in it and cause the motor to heat up...
bvoltz is offline   Reply With Quote
Old 03-07-2011, 09:46 PM   #19931
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by TheCoolCanFanMan View Post
Hi
Cheers Malc
post your setup
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 03-09-2011, 09:44 AM   #19932
waOscar's Avatar
Hello
thank
if your running an x12 stock spec (4 dot insert), start at 40 boost, 15 turbo, ramp 2, delay 0.05, rpm 10,000 min to 22500 max and gear for a 95 deg Celcius after 5 min.
Xray T3 2011 - my asphalt chassis
Xray T3 2011 - my carpet chassis
waOscar is offline   Reply With Quote
Old 03-09-2011, 10:12 AM   #19933
J-milz's Avatar
Trader Rating: 38 (100%+)
I thought we'd have a smart phone compatible hot-wire program by now. What's up Tekin?
💫XRAY addict💫 sponsored by the secret stash.....tee-hee-hee.
J-milz is offline   Reply With Quote
Old 03-09-2011, 10:36 AM   #19934
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
to be honest, i'd just be happy with a plain boring Windows version of the progam without the fancy graphics.. all the usual buttons, sliders, text boxes and menus, even in that boring standard Windows grey colour lol..
now that would be awesome
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 03-09-2011, 11:37 AM   #19935
locked's Avatar
They have that already. When you install it, you select the minimal install. I can't remember exactly how it's worded, but there are 2 options. One says something like "full install (recommended)" and then the option below that is the lite version without the goofy looking interface.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
