Tekin RS ESC sensored >
Old 03-03-2011, 11:03 AM
  #19891
robertvb's Avatar
Unhappy 13.5T Tekin esc setup
Hi Randy I am running a Orion 13.5t with my Tekin RS Pro. I have loaded the latest version software, but just cannot seem to get a competitive setup. Our track is not to big with a lot of corners. Can you perhaps give me a good starting setup? Thanks
robertvb is offline
Old 03-03-2011, 11:23 AM
  #19892
wingracer's Avatar
Trader Rating: 24 (100%+)
Need more info. 1s or 2s (TC, 1/12th, what?), what is your entire current set-up? Where are you getting beat? etc. etc.
wingracer is offline
Old 03-03-2011, 11:28 AM
  #19893
robertvb's Avatar
Default Tekin esc
Sorry - should have known better. I run a Scumacher Mi4 with a 2S 5300 40C Lipo
robertvb is offline
Old 03-03-2011, 11:29 AM
  #19894
robertvb's Avatar
Default Tekin esc
I do not seem to have the grunt out of corners and even top-end I seem to lose out
robertvb is offline
Old 03-03-2011, 11:52 AM
  #19895
wingracer's Avatar
Well I run 1/12th so I can only help you based on what I've seen and read but there are plenty of others on here that can get you straight. They are going to want to know what your set-up is now.
Endbell timing
Boost
Turbo
FDR
RPM points
Ramp
etc. etc.
If you just want a good starting set-up, look on the website. There should be some good ones on there.
Old 03-03-2011, 11:54 AM
  #19896
Integra's Avatar
where's your motor timing at ?
What about your ESC setting's ? Boost, Turbo, Delay ?
Integra is offline
Old 03-03-2011, 01:32 PM
  #19897
Team Tekin
Randy_Pike's Avatar
The guys are all right. We need more info. Get us/me your current esc settings so we can see what's off.
Also what generation Orion motor?
Randy_Pike is offline
Old 03-03-2011, 04:34 PM
  #19898
ok, thanks guys. i will remove the heatshrink and will redo some of the joints.
omegaf is offline
Old 03-04-2011, 11:16 AM
  #19899
Hi everyones , I've done some search with no sucess for 1/12 scale 17,5 with boost , I have done sedan for ever and now just get a crc genxl, I am looking for a good starting setup for my esc and rollout , Track is 90x50 motor tekin redline 17.5 , batteries smc 4000 25c , Power to reciever with a small reciever pack 7.4v , Thanks in advance!
Philrace34 is offline
Old 03-04-2011, 11:25 AM
  #19900
wingracer's Avatar
My set-up with an LRP motor.
85mm rollout
-10 endbell timing (probably close to 15-20 degrees on a tekin) I would go between 0-12 on a Tekin.
Boost 35 (go with 40-45 on a Tekin with less endbell timing)
Turbo 8, ramp 1, delay .4
End rpm 7500
Start around 2000
A little bit of push, I think 10 or 15.
If laptimes are falling off hard late in the race, try reducing timing before dropping teeth on the pinion. If the motor is cool and not falling off bad, try going up a tooth before adding more timing.
Old 03-04-2011, 11:19 PM
  #19901
Default need help
Hey guys, I know this must be asked for many times but I hardly get anything aftering searching this great post. So I put it here: I'm interested in RSPro (212) for mod racing but meanwhile I also got something that the LRP is smoother and lower-temp than RSpro for mod racing, or the RSpro dual drive mode for mod racing is not fast enough and gets high temp. I'm confused and wondering whether RSpro (212) is as good as LRP or even better in smooth and temp? and why?
Any input will be appreciated. btw I'm running FXR for crawler and it's great
campaign000 is offline
Old 03-05-2011, 05:52 AM
  #19902
robertvb's Avatar
Default Setup info
Hi my info for my 13.5T Orion is as follow:
End bell timing: 20 (2nd line up)
Boost: 40
Start Rpm 4608
End Rpm 12009
Turbo delay 0.2
Turbo ramp 3
Turbo ramp 3
Turbo 19
Throttle profile 5
Current limiter 90
Brake strenght 100
Drag brake 18
Neutral width 10
I run a 96 spur with a 31 pinion and final rollout = 34
Hope this is info is what you wanted
robertvb is offline
Old 03-05-2011, 06:15 AM
  #19903
Starteur's Avatar
Good morning,
we run "N" 17.5 motors in our sedan class (by rules), I have the endbell timing set at 45, RS speedo in spec mode,
Brake 100%
Drag brake 20
No Boost
No turbo
Throttle profile 3
Current limiter None
Here is my problem:
I upped the endbell timing to 45 (before it was 30, with a 53 pinion), I do a 5min with a 50 pinion and get off at 172 degrees wich is too much, but I did apply the 1 tooth per 5 degrees of timing recommendation.
I then go down to a 47 pinion and get off the track after 5 minutes at 175 degrees ?????
I don't understand, I went down 6 teeth and it still overheats!
Thanks for the help
Starteur is offline
Old 03-05-2011, 07:12 AM
  #19904
wingracer's Avatar
edit: bad advice. Ignore post.
Old 03-05-2011, 08:44 AM
  #19905
robertvb's Avatar
Default Tekin setup
Hi
Thank you for your advice. I am running 61mm tyres.
robertvb is offline
