Old 03-01-2011, 06:35 PM   #19861
Awesome thanks Randy!
Old 03-01-2011, 07:00 PM   #19862
slakr's Avatar
Trader Rating: 31 (100%+)
Originally Posted by slakr View Post
I will try this when I get home from work and report back whether it worked or not.
So, does this indicate that tightening up the screws is applying to much pressure to the sensor board? Has to be some reasonable explanation... and resulting fix other than leaving the screws loose.
Seems like mine was actually a BAD sensor board.
If I unhooked the sensor wire, the RS would power up.
Changed to a known good sensor wire... nothing on the RS.
Put the old sensor wire back and hooked to a known good motor... RS would power up.
Went back to the Synergy, tried loosening the endbell screws thing... nothing on the RS.
The known good motor was a D3, so I swapped the sensor board to the Synergy (since it is also a D3)... and the RS would power up.
Looks like I'm back in business... just need to get another sensor board for the Synergy.
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 03-01-2011, 07:27 PM   #19863
macdude's Avatar
Tried the loosening the endbell screws thing... nothing on the RS.
As a caution about the sensor boards. I have seen several go bad and it seems that if you tighten the screws too hard it cracks the solder joints. This is what I was told by the Fantom motor guys as they have had a lot of returned sensor boards and that is what they have found.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 03-01-2011, 07:45 PM   #19864
Originally Posted by Randy_Pike View Post
I need more setup info than that. Boosters or rx packs? What motors? Esc settings?
No problem! Will post my exact speedo setting tommorrow .
For now, Motor- Epic Duo 2, Booster-Novak & no receiver pack.
Thanks Randy
AE 12R5.1 TC5 B4 B44 RC8B RC8BE
TEKIN OS LRP EPIC NOVAK
SPEKTRUM
FUTABA
PROLINE
Tomasb is offline   Reply With Quote
Old 03-01-2011, 08:35 PM   #19865
There have been issues using the Novak booster with the RS running boosted setups. It works just fine in the non-boosted profile but not with boosted setups.
Old 03-02-2011, 12:58 AM   #19866
need advice, is there anyone running an epic D3 10,5t on 1/10 TC, i'm racing in a large asphalt nitro track, currently using lrp x12 10,5t and so far it's the fastest ever hooked-up on my rspro, laptimes faster than a nitro TC by .3 to .5 sec. the only problem is high temp. typical of x12 series it can reach even over 100C anyway with no issues. thanks.
genius120 is offline   Reply With Quote
Old 03-02-2011, 05:41 AM   #19867
I've heard the samething but others in my club some running receiver packs & others are using TQ boosters are having the same problem.
SPEKTRUM
FUTABA
PROLINE
Old 03-02-2011, 08:07 AM   #19868
Jochim_18's Avatar
Can you upgrade your Tekin RS to RS pro? I got the RA# for replacement of my non-warranty RS so I'm wondering if tekin offer an upgrade option? Like the "N" company offers to their customers.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 03-02-2011, 09:34 AM   #19869
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Yes, you can pay the difference to change items.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 03-02-2011, 09:38 AM   #19870
Team Tekin
Randy_Pike's Avatar
Thanks Randy
Try a different booster or use a 2s pack to power up the unit as a test.
If the booster or rx pack cannot supply enough power the unit will not chime and will not work.
Old 03-02-2011, 11:11 AM   #19871
Sorry Randy
But somewhere the info has been misunderstood. Everything chimes , we all can run a 10min main but 2-3 minutes in the power/boost/ etc. goes flat initial punch/boost is gone. But will post our esc setting tonight like you had earlier requested.
SPEKTRUM
FUTABA
PROLINE
Old 03-02-2011, 11:21 AM   #19872
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Sorry Randy
Can you post your settings, roll, timing ?
This is a common issue with too much timing and or gear with 1s racing.
I try to set my car up to loose only .5s a lap at 8min, vs: shooting for fastest lap in the 1st min.
This is more a battery punch issue than the motor getting hot or going flat, not the same as 2s racing.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-02-2011, 12:26 PM   #19873
Jochim_18's Avatar
How much it will cost? To upgrade to the RS PRO?
Old 03-02-2011, 12:29 PM   #19874
wingracer's Avatar
Trader Rating: 24 (100%+)
Yeah with 1s, just a few degrees too much timing or a tooth or two too much gear and they will completely fall on their face just a few minutes in.
Just as an example, ran my first 1/12th 17.5 boosted race a month or so ago (usually run 10.5 or mod) so had to start from scratch on set-up. Also my first time running an LRP motor (always ran Tekin or Duo before).
First heat I was good, 9.9 laps to start, 10.5 at the end but wanted a bit more speed so for the second heat I went up two teeth and added 5 degrees more boost.
Well at first this seemed ok, ran 9.8's up front but started falling off just a minute in. By halfway (4 minutes in) the car had gone so flat it was ridiculous. By the end I was running 11.9's! crazy slow.
3rd heat, dropped a tooth and took that extra 5 degrees of boost back out. Still ran 9.8's up front but still fell off really hard. I think 10.9's at the end.
So for the main (managed to qualify 3rd despite all this) I left the gearing alone but dropped the boost down another 10 degrees. Was only able to run one or two 9.9's early but this thing didn't fall off at ALL. 1 minute in I was in a three car freight train with the two fastest guys and by halfway, I was the fastest car on the track. A couple mistakes cost me the win, but I managed to catch the leader just as we got to the line to end the race. One more lap and I would have had him. Was still running 10.2 and 10.3 at the end.
1s, especially 17.5 there is a VERY narrow sweet spot. Find it, you're fast. Miss it by a hair and you are either slow or the thing falls off so bad you would think the motor or the battery was fried.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 03-02-2011, 12:48 PM   #19875
Team Tekin
Randy_Pike's Avatar
Non warranty repair pricing.
$26 it appears: $79 or RS $105 for RS Pro.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
