Old 02-22-2011, 09:24 PM   #19726
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I run everything Spektrum in all my cars. Servos, receivers and Tekin and have not had one problem in 2+ years of running this combo.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 02-22-2011, 09:41 PM   #19727
HarryLeach's Avatar
Send a message via AIM to HarryLeach
I'm also a long time spektrum user.
Like I said earlier, take a peak inside the RS' case, all the issues I was having kept pointing to receiver, or receiver power issue. Went so far as installing an external BEC, after swapping servos and receivers, and trying a receiver cap. Found my servo lead wires and power switch wires in questionable condition, replaced them, and have been good since.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 02-22-2011, 09:59 PM   #19728
caltek1's Avatar
Trader Rating: 36 (100%+)
If you suspect the spektrum, you can always connect a capacitor into the reciever. Spektrum have one of these as an extra. It solved a problem I was having a couple of years ago with voltage drop and loss of signal.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 02-22-2011, 11:40 PM   #19729
Well if the epic shreftrace runs it it should be good lol
U gonna be at IIC this year if they run it Larry? I'm keeping my fingers crossed
Old 02-22-2011, 11:44 PM   #19730
Still Bill's Avatar
Burt,
IIC is supposedly the first weekend of October.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 02-23-2011, 02:35 AM   #19731
Originally Posted by Still Bill View Post
Burt,
Bill
Yup...supposedly...I'm not banking on anything until the official announcement But I do plan on being there so we can resume our WGT battle
Old 02-23-2011, 03:38 AM   #19732
warnos's Avatar
Once I found out about the low voltage issue with Spektrum years ago I haven't had any problems that I could say was definately the system so I stayed with them. But after hearing about the power issue with some things like the servos I am starting to put things together and can definately see where this could be an issue with Spektrum and their issues with being power hungry. At the same time I've got 4 Spektrum RXs so switching systems at this point isn't practical...but might be necessary. If I am able to cure my fade issue with a RX battery or a capacitor I will definately move to a Futaba or Airtronics system.
I had a tekin / spektrum issue. But it was the older Spektrum Module with a 3001 and or a 3500 micro.. the only way I could stop brown outs under hard braking was by changing the RX to another brand or by put a 3A Bec conected straight to the battery. Like what is used on the Nitro cars using lipo. Tried using the cap and it didn't work.. trying to fix this problem cost me heaps of money in broken parts and run away cars.. Tekin even gave me a new ESC under warranty when I told them about the issue but this didn't fix it.. would never put a Spektrum DSM1/ Tekin combo in my car again.. work flawlessly for heats/weeks/months then one day you have a full power run away at the end of the straight when u are trying to brake. No good... Don't know why this happens to not all setups.. but it does happen..
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 02-23-2011, 02:40 PM   #19733
I do have the older Spektrum module in my transmitter...But I'm not using the original old recievers.
Old 02-23-2011, 02:51 PM   #19734
Mr. MR4's Avatar
Default Set up for 1/10 Touring 2S
Hi,
What is the best way to set up the RS Pro for 1/10 TC?
Shall I start off without turbo and see if the car has good acceleration till mid way down the straight, and then set the turbo for the end of the main straight?
(Straight is 85 feet long)
Xray T4'16 HobbyWing Xerun 120A V3.1
Xray X1'16 HobbyWing Justock
Yokomo R12C3 HobbyWing Xerun V3.1
Mr. MR4 is offline   Reply With Quote
Old 02-23-2011, 03:02 PM   #19735
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
There really is no "best" way. 85' is nothing huge and for the most part any of the carpet track esc setups will work just fine.
http://www.teamtekin.com/hotwire/ESCsetups/index.html
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 02-23-2011, 03:09 PM   #19736
Mr. MR4's Avatar
Thanks Randy
Old 02-23-2011, 05:23 PM   #19737
rpoage's Avatar
I have a odd stutter issue. It seems that after a couple tire scrub laps the car is very, very slow off the line at the start of qualifying or the final. I could care less about qualifying but I’m getting tired of being hit from behind at race starts (yes I warn the other racers). It is also noticeable if I drop down slow in a corner (traffic) It take about 10 to 15 feet to get back up to speed. I have changed the motor and I have continuity tested the sensor cable. Any thoughts are appreciated? My TC RS Pro works fine.
1/12th Scale 1S 13.5 Novak Ballistic (stock timing) 30deg
Roll Out: 67.3mm (37t/76t 44mm tire)
Motor Type: BLFW
Voltage Cutoff: 1S
Timing Profile: C1
Sensored: Yes
Motor Direction: Normal
Throttle Profile: 5
Current Limit: Off
Throttle Minimum: 10
Drag Brake: Off
Brake Strength: 100
Reverse Speed: Off
Neutral Width: 10
Push Control: Off
Brake Minimum: 20
Timing Advance: 100
Boost: 50
Starting RPM: 4001
Ending RPM: 8607
Turbo: 10
Turbo Delay: 0.20
Turbo Ramp: 3.0
Ashford Hobby
Real time inventory for the things you need.
rpoage is offline   Reply With Quote
Old 02-23-2011, 05:34 PM   #19738
Team Tekin
Randy_Pike's Avatar
Booster or rx pack?
Old 02-23-2011, 05:36 PM   #19739
rpoage's Avatar
LiFe 2s receiver Pack. changed it also.
Ashford Hobby
Old 02-23-2011, 06:18 PM   #19740
JPMSRacing's Avatar
Location: Lost in the Dead Space between my Ears Somewhere around Wamego, KS (OZ Land)
is your end 8000 or 18000 on boost,
I'm around still!!!
JPMSRacing is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
