Old 02-21-2011, 06:15 AM   #19696
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
10 motor
40 timing boost
0 turbo (to start)
start 3-4k
end 15k
fdr 6-6.5
get it to accelerate out of the corner check the temps around 2 min if it is good add 5 turbo to start
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 02-21-2011, 08:36 AM   #19697
Layin' Wood's Avatar
Originally Posted by 20 SMOKE View Post
check all the solder joints reflash master reset if still no go then yeah it needs to go back,if you dont get it back in time i will let you use one
Thanks man I really appreciate it. I'll be on the phone with them shortly. Dennis was able to look at it for me at the track and it was still no dice. He has one that did the same thing and I think Daniel experienced the same issue. It happened to Kat to but they were able to get her working by reloading the old software and then updating it again.
Layin' Wood is offline   Reply With Quote
Old 02-21-2011, 12:04 PM   #19698
Originally Posted by Rob long View Post
Anyone ????
LMAO !!!!
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 02-21-2011, 12:34 PM   #19699
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by mikeygar View Post
Hi Randy - any Tekin drivers or reps going to be at TITC?
Unfortunately no. It conflicts with other events already scheduled.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 02-21-2011, 07:53 PM   #19700
Trader Rating: 15 (100%+)
Default Speedo
Is anyone else having to re flash thier speedos to default and then reset to thier settings ever weekend? Mine runs fast for two or three runs then slows down . After I reset it's fast again .
AARON YOUNG is offline   Reply With Quote
Old 02-21-2011, 08:13 PM   #19701
mikeygar's Avatar
Trader Rating: 14 (100%+)
Too bad hopefully I'll see you guys next year! Leaving for BKK tomorrow and I'll be running my RS in the 11.5 open brushless class running a Speed Passion V3. Will a setup for 13.5 work well with this motor?
Thanks!
mikeygar is offline   Reply With Quote
Old 02-21-2011, 08:24 PM   #19702
Still Bill's Avatar
Aaron,
That's an interesting condition. Never experienced anything like that myself.
So, you take preemptive action every other run?
Do you reset your neutral/forward/reverse on your radio too?
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 02-21-2011, 09:35 PM   #19703
Yeah have to reset everything speedo and radio settings
Old 02-21-2011, 10:11 PM   #19704
Still Bill's Avatar
Do you have a Throttle Highpoint adjustment that you can bump up after setting the radio's neutral/forward/brake to the RS speedo? For my KO Eurus, I do that to avoid issues with not getting full throttle after a few runs.
Bill
Old 02-22-2011, 12:38 AM   #19705
maxepower's Avatar
Cool It can happen!
Bill
I'm only adding my 2$ because this happened to me recently!
I have the RS and using the KO radio.
I noticed after running my car then trying to run it again I tried to turn on my esc it wouldn't work at all. It would turn on I had steering but no throttle to speak of. All the lights were flashing but the esc wouldn't respond.
I finally realized my problem was I had turned up my throttle trim while I was running and didn't return it back to zero after I finished running. For some reason if the trim is set too high when you turn it on again the esc can't set itself properly. So, I turned it down and restarted it and then it worked fine.
This may not be what he is having problems with but I thought it wouldn't hurt to mention it!
Just my 2$
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 02-22-2011, 07:33 AM   #19706
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Max, you might try more Neutral width on the RS.
KO radios throttle neutral point, tend to wander quite a bit.
Maybe Robert at KO has a tuning fix for the radio also ?
With the 4PK I run 0 Neutral Width, and never have any issues.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 02-22-2011, 07:44 AM   #19707
theisgroup's Avatar
Just my 2$
this is true of any radio. the tekin rs need to see neutral before it will "arm". if you bump your throttle trim up after you did the calibration, the rs does not see neutral and will not arm.
i have never notice that. I run 0 neutral width as well. as a matter of fact, with the novak sentry connected, you can see what the rx see from the radio and 0 is always 0 and 100 is 99-100 so i would say that it pretty darn close to accurate.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 02-22-2011, 07:48 AM   #19708
theisgroup's Avatar
what does slow down mean. is it noticably slower? is it slower on the clock? are you loosing timing or turbo?
yang lai
Old 02-22-2011, 07:50 AM   #19709
JPMSRacing's Avatar
Location: Lost in the Dead Space between my Ears Somewhere around Wamego, KS (OZ Land)
Bill
I second this,
I'm around still!!!
JPMSRacing is offline   Reply With Quote
Old 02-22-2011, 08:25 AM   #19710
I always bump my endpoint to 120 after setting at 100 . The car loses boost and overall power it is just slow all around. After I reset it it's fast
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
