Old 02-15-2011, 11:11 PM   #19651
Nope...most of the guys at our track run an RS and don't seem to have this issue.
I wonder if it is my battery starting to drop off in performance...might have to borrow one and see.
Old 02-16-2011, 07:28 AM   #19652
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
That could very well be the cause, what lipo are you running ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 02-16-2011, 09:17 AM   #19653
darrenoakley's Avatar
Got a problem with my RS pro
Only running 17.5 fdr 6.5 and until now it has worked fine but today it feels like it had gone sensorless, then now and agian the boost will kick in for a blip and drop again. I have changed motors and sensor wires and also opened up the motor to check its not the sensor board. Will it be worth reinstalling 212 to see if it is a software issue ? Do hope it is as I have only used it 5 meetings since it was sent to Tekin for replacement.
Any ideas would be great
Xray x11
Xray T3 011
darrenoakley is offline   Reply With Quote
Old 02-16-2011, 10:55 AM   #19654
Wall Banger's Avatar
Well it is an issue I have had with both my RS's for a long time now. I have tried numerous setups from this thread in the early days and setups that other people at my track are running with the same motor and gearing. I've tried the whole calibrate at 100% and back down to 90% and even 80%. If the same setups are working for others at my track it should work for me as well but there is a noticeable difference. Also I'm only running 17.5 motors...it isn't like I am taxing what the ESC should be able to do. Well I'll just wait and see what happens with the one that went in for repair today and I have a new one on the way as well.
Try doing the calibration at 90% and then up to 100% or higher on the throttle
Wall Banger is offline   Reply With Quote
Old 02-16-2011, 11:11 AM   #19655
Done that...doesn't help
Old 02-16-2011, 11:18 AM   #19656
I am looking in getting the RS or RS Pro. I am going to be running 17.5 Boosted. Is there any advantages in shelling out a few $$$ extra for the pro?
Also, sounds like some people are having issues with glitches and with power drops. Has these problems been solved or is it just an isolated occurrence?
DW
dreadwing is offline   Reply With Quote
Old 02-16-2011, 11:23 AM   #19657
locked's Avatar
DW
Not really worth the extra $ for the pro if you only plan to run higher turn motors
I think the glitches are isolated occurrences. I have an RS and an RS Pro and have never had any issues. I know many people with several Tekin ESCs too that have never had a problem.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 02-16-2011, 11:25 AM   #19658
Thanks for the info.
Old 02-16-2011, 01:04 PM   #19659
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
What servo are you using? Is there any consistency on the issue? Or is it totally random?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 02-16-2011, 03:08 PM   #19660
xray09ACT's Avatar
I would have a look at your connector to the reciever. i have had a simular issue, where the car drops in and out of boost/power as the connector rattles around in the receiver. I replaced the cable and all sorted. It's because we pull the cable in and out on a regular basis to change settings, no biggie.
ACE Hobby Australia | Monaro models
TEAM Associated TC6 | LRP | LRP
TEAM Associated TC6 | Nosram | Nosram
TEAM Associated 12R5.1 | LRP | LRP
xray09ACT is offline   Reply With Quote
Old 02-16-2011, 03:13 PM   #19661
HarryLeach's Avatar
Send a message via AIM to HarryLeach
Yep, only glitching/problems I've ever had with my oldest RS were sorted after replacing the servo lead and power switch wires.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 02-16-2011, 03:42 PM   #19662
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
i have a glitch in my wgt that happens every no and again
anyone that use a data logger that isn't using it anymore and would like to get rid of it,i want to play with one
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 02-16-2011, 03:59 PM   #19663
Its mainly no boost but sometimes it will stutter into boost but not stay there.I am using the Savox low profile servo. it has been ok for a good year before this. I will check the receiver plug. When you guys have replaced them do you mean open the speedo up and replace it ?
Cheers for the reply
Xray x11
Xray T3 011
Old 02-16-2011, 05:19 PM   #19664
xray09ACT's Avatar
There are several ways to replace the plug and/or wire.
opening the case is one of them, you can also splice a new peice cut from an extension cable or pull apart and crimp a new plug.
I can neither confirm or deny that any of these actions will void your warrenty.
best way to tell is accelerate on the table and wiggle the plug, not to hard though as free revving is bad
Old 02-16-2011, 08:15 PM   #19665
M-Technic's Avatar
Trader Rating: 15 (100%+)
Sorry for the delay on getting this setup. Mike Haynes 7.5 Mod TC setup from Snowbirds:
That is insane. I would consider that setup/FDR to be a little extreme even for a 17.5, I can't believe it worked with a 7.5.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
