Old 02-15-2011, 01:38 PM   #19636
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by Randy_Pike View Post
Sorry for the delay on getting this setup. Mike Haynes 7.5 Mod TC setup from Snowbirds:
98* of timing is that right
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 02-15-2011, 01:39 PM   #19637
20 SMOKE's Avatar
Originally Posted by lorider75 View Post
how long does it normally take to get product back from tekin when sent in under warranty?
its been about 3 weeks now. just anxious to get my gear back in the car
email them and ask,make sure to have your ra# handy
Jamie W
Old 02-15-2011, 01:41 PM   #19638
20 SMOKE's Avatar
Originally Posted by InspGadgt View Post
Just sent one of my RS's off for repair...accidentally plugged it in backwards on the battery
Anyway I had a question on the turbo fade/lag issue I've been having. At first I thought it wasn't actually coming on due to a possible transmitter ATL wander as has been mentioned. But this past weekend I dropped the turbo delay down to it's bare minimum and at the start of the run the car was very fast but after a few laps the turbo seemed to go away. One of my fellow racers was observing and noticed that the turbo did seem to kick in but it wasn't until the very end of the 100+ ft straight. I'm wondering if maybe it could be just because they are old...both my current RS's I bought before the 1st Vegas version ever came out.
its bogging down from to much timing to soon even if you dont see it untill the end of the straight.how long of a straight
Jamie W
Old 02-15-2011, 06:34 PM   #19639
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Yeah I know, but that's what he used. TP's motor timing is clearly different than ours.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 02-15-2011, 06:35 PM   #19640
Team Tekin
Randy_Pike's Avatar
7 to 10 business days. If it's taken this long than something is off. Please give us a call during normal hours.
Old 02-15-2011, 06:37 PM   #19641
Team Tekin
Randy_Pike's Avatar
That "instance" is not the turbo kicking in. Trust me it's on after the delay time is extinquished. That is likely the car FINALLY accelerating at it's best. If you're seeing this late straight away "rush" then the setup is still off.
Your car should have a long hard pull, not a "hit" at the end of the straight.
RS's don't get "old" either. There is nothing in them to wear out.
Old 02-15-2011, 07:01 PM   #19642
Well it is an issue I have had with both my RS's for a long time now. I have tried numerous setups from this thread in the early days and setups that other people at my track are running with the same motor and gearing. I've tried the whole calibrate at 100% and back down to 90% and even 80%. If the same setups are working for others at my track it should work for me as well but there is a noticeable difference. Also I'm only running 17.5 motors...it isn't like I am taxing what the ESC should be able to do. Well I'll just wait and see what happens with the one that went in for repair today and I have a new one on the way as well.
Old 02-15-2011, 07:40 PM   #19643
Trader Rating: 19 (100%+)
i would check the bearings and stuff in your car, a bearing that is locking up can cause drag in the drive and slow it down
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 02-15-2011, 07:43 PM   #19644
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
fwiw
I've never had an issue with my 1.5 yr old RS.
It sounds like "your" setup is off for you.
The same rollout doesn't work for everyone.
In 17.5 12th scale, there is a narrow margin for the sweet spot.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 02-15-2011, 07:43 PM   #19645
Still Bill's Avatar
Aloha,
Each of my RS's have been in multiple cars with the 203/208/212 setups. They are doing fine.
Actually, with 212, my RS's are as fast as they have ever been.
It may be a shoot in the dark; but, have you tried replacing the caps?
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 02-15-2011, 07:53 PM   #19646
Does the Tekin RS run motors cooler than other ESC's?
Heard that one motor ran 30 degrees cooler, Rumor?
looklikeaflip is offline   Reply With Quote
Old 02-15-2011, 08:55 PM   #19647
wingracer's Avatar
Trader Rating: 24 (100%+)
Instead of dropping the gearing, try dropping the total timing. Knock maybe ten degrees off through some combination of reduced motor timing, boost and/or turbo. I find if you over time them just a bit, fade can get pretty extreme. If this cures the problem but you think you need more speed, you may then be able to go up a tooth or two on the pinion to get it back without fading.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 02-15-2011, 08:57 PM   #19648
wingracer's Avatar
You got that right. 1 tooth too much or 5 degrees too much timing and the things drop off a second a lap.
Team Shepherd USA
Old 02-15-2011, 09:13 PM   #19649
I have tried timing as much as 30 less than I am currently using. Typically I had been running about 15 less then what the rest of the drivers at my track have been using.
It isn't bearings...this has been happening in multiple cars and I have replaced them. Also if it was bearings my motor temps would be higher.
I have tried different caps and have even gone as far as running 2 caps.
Old 02-15-2011, 11:09 PM   #19650
Still Bill's Avatar
Burt,
Is Mike having similar issues?
I am believing that you two run under some pretty hot/humid conditions.
Bill
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
