Old 02-12-2011, 03:02 PM   #19606
pmc
Hello
Wich is the best motor of this two options to run with the Tekin RS Pro in stock class.
LRP X12 13,5T or GM Pro 13,5T (GM 97294)
Thanks in advance.
Best regards:
Pedro Silva
pmc is offline   Reply With Quote
Old 02-12-2011, 04:43 PM   #19607
part-time racer's Avatar
Originally Posted by pmc View Post
Hello
Thanks in advance.
Best regards:
Pedro Silva
I'll tell yopu tomorrow mate as i have both and we have a big meeting. x12 in now with the gm waiting in the wings.
part-time racer is offline   Reply With Quote
Old 02-12-2011, 05:04 PM   #19608
pmc
Hello
Ok , Thanks.
Best regards:
Pedro silva
Old 02-12-2011, 06:02 PM   #19609
Randy, when comes the new hotwire version with the save option?
toptek is offline   Reply With Quote
Old 02-12-2011, 07:20 PM   #19610
Trader Rating: 19 (100%+)
Any word on Mike Haynes' snowbirds expert setup for the tekin?
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 02-12-2011, 07:46 PM   #19611
LocalRacer83's Avatar
Send a message via AIM to LocalRacer83 Send a message via Yahoo to LocalRacer83
Default ESC setting? motor tining?
hey im just getting back into the hobby. I have a t2 009 foam with a duo 2 10.5 and tekin pro esc. motor timing is a factory settings FDR 6.1 and ESC settings are:
212 software
sensored c1
drag 10
brake strength 100
push off
brake 10
throttle profile 3
current off
neutral 56
throttle min 10
timing 45
boost 40
rpm start 5400
rpm end 27000
turbo 10
delay .24
ramp 1.0
Does this look right? any suggestions would be helpful! running on semi tight track. ab a 70 ft straight. Thanks.
Xray*KO Propo*SMC*Jaco*Epic*Hobby Hangout
"Again, racing for me is about energy management."
LocalRacer83 is offline   Reply With Quote
Old 02-13-2011, 05:04 AM   #19612
212 software
sensored c2
drag 10
brake strength 85
push off
brake 10
throttle profile 5
current off
neutral 10
throttle min 15
timing not used in sensord mode.
boost 50
rpm start 7000
rpm end 16000
turbo 10
delay .15
ramp 2
gearing 7.4FDR
Try this setup.
Old 02-13-2011, 03:04 PM   #19613
sandsurfer's Avatar
Trader Rating: 20 (100%+)
Send a message via Skype™ to sandsurfer
Default drag brake
Looking for some clarification. Does drag brake come into effect whenever throttle is in neutral position after any position of throttle? Eg. at half throttle then throttle returned to neutral position. Or does it only come into play only after full throttle then returned to neutral position? Or does it come into play when going from any throttle position to less throttle position?
sandsurfer is offline   Reply With Quote
Old 02-13-2011, 03:48 PM   #19614
for what I now only when you come off the throttle.
I never use it. I use the brake. works better for me because some corners are faster without the drag brake.
Old 02-14-2011, 08:32 AM   #19615
mikeygar's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Chubba View Post
Hi there, I currently running a1:12 Yokomo R12 and looking for a new ESC.
I am quite interested in the Rs Pro and was wondering do I need a anything else apart from the USB hot wire and the RS Pro?
you'll need an RX pack
mikeygar is offline   Reply With Quote
Old 02-14-2011, 09:11 AM   #19616
tc3team's Avatar
Originally Posted by LocalRacer83 View Post
timing 45
boost 40
total timing (boost and turbo combined) should imo, not exceed 50, excessive timing can, and will eventually lead to motor failure.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 02-14-2011, 10:16 AM   #19617
That's really playing it safe.
Normally the rule of thumb is not to exceed 60-65.
I am using 75 (50 boost + 15 turb + 10 motor timing) on my Speed Passion with low temps and lots of power.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 02-14-2011, 11:29 AM   #19618
wingracer's Avatar
Trader Rating: 24 (100%+)
Now I'm running 1/12th, not TC but what I find is that yes, you can run that much timing but better results are usually obtained by less timing, more gear. Perhaps the higher rpms of 2s likes more than 1s but I just can't get that much timing to work.
Then there are LRP motors which need even less timing.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 02-14-2011, 12:57 PM   #19619
HarryLeach's Avatar
Send a message via AIM to HarryLeach
+1, I've been finding the same thing.
1s setups seem to maintain speed through the run a bit better with timing in the 40-50 degree range.
2s setups you can get away with 50-65 degrees without seeing much fall off through the run.
Of course, some motors have more timing than others, and ESC setup has to mesh with your motor.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 02-14-2011, 12:59 PM   #19620
So i've managed to sort the answer out for myself, i ran the x12 with good effect yesterday and on 203 firmware.
boost at 45 and turbo on 15 with fdr of 6.5
next step is to play with drag brake settings as the car overshoot apex's to offer to post a fast overall time.
this motor is excellent me thinks for large in-door / out-door tracks.
The GM in my view is better suited to small / med indoor circuits.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
