Old 02-06-2011, 06:47 AM   #19501
contact Tekin or Randy. You will get a RA#. Fill in the return form that you can download from the Tekin website. Than send it to them.
toptek is offline   Reply With Quote
Old 02-06-2011, 09:26 AM   #19502
jammincrtjames's Avatar
Randy,
Will you be posting Haynes 17.5 Expert set-up?
NEXUS RACING www.nexusracing.com | FANTOM RACING www.fantomracing.com
ORCA www.orcarc.com | TURTLE TRAX / www.turtletraxraceway.com
"If you're not first...you're last!"
jammincrtjames is offline   Reply With Quote
Old 02-06-2011, 10:39 AM   #19503
rcfiend's Avatar
Trader Rating: 30 (100%+)
I just purchased a the RS 17.5 combo and ran it for the first time yesterday. I have a couple of problems.
1. When I installed the software for the hotwire I get ver. 178, 180. When I try to update it says no updates available. But when I go to the website to get the 218 ver. It will not install, I get an error message and the install cancels. Oh and I'm using Win XP
2. When I ran the car it was extremely slow tried a 3.81 and 3.75 fdr. Also whatever I did I could not setup brakes for the esc. Tried resetting the speedo and same thing.
Any suggestions would be helpful.
rcfiend is offline   Reply With Quote
Old 02-06-2011, 11:08 AM   #19504
Remove the old installation first.
Than install the new software.
After updating reset the speedo and recalibrate it with the radio.
After that put a setup on it. With a 17,5 boosted class use the sensord mode.
Old 02-06-2011, 11:28 AM   #19505
rcfiend's Avatar
Topdek - I did remove the old installation twice and it still will not take anything newer than 178-180. When I try to install the 218 after I remove the old installation, the install just cancells.
Anyone using the KO EUR10 can you share what throttle settings you are using. I just switched to the KO from the M11 and the terminology is way different.
Old 02-06-2011, 11:58 AM   #19506
avs
avs's Avatar
when you install the latest hotwire version, what is getting canceled? is it the hotwire install on windows, or the hotwire trying to install new firmware in the ESC. you stated there was an error message, what did it say?
also, the new hotwire version has a very different gui, are you seeing the new gui or the original? one thing tat is puzzling is that the new hotwire won't let you select anything but the latest firmware.
Tony Shimko
avs is offline   Reply With Quote
Old 02-06-2011, 12:03 PM   #19507
1M
1M's Avatar
Trader Rating: 35 (100%+)
You tube how to remove old, and install new.
http://www.youtube.com/watch?v=tTp3tUL9u8Y
1M is offline   Reply With Quote
Old 02-06-2011, 12:25 PM   #19508
rcfiend's Avatar
AVS- The install cancels at the hotwire install. The error message is "error#" and then the install just cancels. Also I don't see the new gui.
I just installed the 212 ver. on my home computer and it worked fine and performed the update on my RS, but for some reason or another the 212 will not install on my laptop or update the esc from the 178-180 ver. Wierd.
I'll have to fool around with my laptop a little.
1M does that youtube video only apply to Vista? I'm using XP.
Is it possible that the motor was running so slowly becuase I had an older version on the esc.?
Old 02-06-2011, 02:33 PM   #19509
install the software on an other lokation.
So not in the map that it shows you but rename the map.
Old 02-06-2011, 02:40 PM   #19510
locked's Avatar
yeah. Stock firmware is pretty slow.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 02-06-2011, 03:17 PM   #19511
rcfiend's Avatar
[GVIDEO][/GVIDEO]
Not sure I understand what map you are referring to.
Old 02-06-2011, 03:38 PM   #19512
rcfiend's Avatar
I'm trying to figure how to change the modes on the esc. What sequence do I have to go through to activate the stock mode (blinky)?
Old 02-06-2011, 03:57 PM   #19513
locked's Avatar
press MODE button 5 times (TP) then press INCR until only 1 LED is lit
Dave Locke
Old 02-06-2011, 04:03 PM   #19514
Blue Screw's Avatar
Send a message via AIM to Blue Screw
can some one tell me what the timing profiles are? also why do they have C1 and C2.. can u set c1 for one set of values and c2 for different
Angelo DAlessandro
AE~REEDY~LRP~JCONCEPTS~NOVAROSSI~HUDY~IRS~KALGUARD ~ABSOULUTE HOBBYZ~GRAVITY-RC~TnT CUSTOM GRAPHICS
NITRO ONROAD
XRAY~RCAMERICA~HUDY~SRC~MURNAN MODS
Blue Screw is offline   Reply With Quote
Old 02-06-2011, 04:08 PM   #19515
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
YES you can set 2 different timing profiles with C1 C2,spec mode is 1 no timing 2 is 15* 3 is 25* 4 is 35* 5 is 45* with a rpm range of 5k start and 20k end
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
