Old 02-01-2011, 10:23 AM   #19441
kuruption's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to kuruption
Originally Posted by forrestboy View Post
how do i get my rs in the ROAR sportsman "blinky" mode using my hot wire on version 208?
You don't, you need to update to 212. 208 is not approved by ROAR for sportsman classes.
Ray Sundland
Eat. Sleep. Race. Repeat.
"Feel not as though it is a sphere we live on, rather an infinite plane which has the illusion of leading yourself back to a point of origin."
kuruption is offline   Reply With Quote
Old 02-01-2011, 10:24 AM   #19442
forrestboy's Avatar
Trader Rating: 16 (100%+)
o ok thanks
Team C Racing
evohobbies.com
forrestboy is offline   Reply With Quote
Old 02-01-2011, 10:29 AM   #19443
drpower's Avatar
OK no time to research this so i have to ask... I got a deal on a Diggity Designs XLR8 TC3 and I want to add a Tekin system. Theres an RS Pro with a 5.5T i can get for $260, should I pull the trigger on that? Is this well suited for the TC3 for high speed runs, no racing just a sunny day crowd pleaser. And the car is all bling so I want a new esc/motor to match
drpower is offline   Reply With Quote
Old 02-01-2011, 10:33 AM   #19444
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
You don't. You should be using 212. 212 Blinky mode is Timing Profile 1.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 02-01-2011, 10:41 AM   #19445
forrestboy's Avatar
where do i find the timing profiles?
Team C Racing
evohobbies.com
Old 02-01-2011, 11:09 AM   #19446
Team Tekin
Randy_Pike's Avatar
Either on the Hotwire or once you've downloaded 212 you can us the onboard buttons.
Old 02-01-2011, 12:04 PM   #19447
gonzo416's Avatar
Trader Rating: 39 (98%+)
Originally Posted by RSCosworth View Post
Hi.
What would be the difference or bennifits of using a bigger capacitor?
For example, going from a 16v 330uf to a 16v 1000uf?
I would recommend using the original Tekin capacitor because this is how a capacitor works to my knowledge and someone correct me if I'm wrong.
A capacitor is used to store power so that when the speedo is drawing constant power there is no flaw or interruption in it's operation. As the speedo is running but not at maximum capacity the capacitor slowly stores power until it is full so if there is any kind of interruption with the current to the speedo the capacitor will supply it with the current or power it has stored and this process continues until the speedo is turned off. I lost the capacitor in my Tekin and the car would stutter when full throttle was applied. When I put one in, this stopped and worked flawless.
Another thing is the use of the proper size because if it is too small it will not store enough power or current and if it is too big it will take too long to fill it and the current going to the speedo can be affected because the capacitor is filled from the same power going to the speedo. I would assume that Tekin has engineers that have a formula to find out what size capacitor is needed for the power consumption of their speedos.
Kind of like a capacitor used in a car stereo system. You will see the lights in the car dim every time the base hits if a a capacitor is not used because that is when the most current is drawn. So a capacitor is used to correct this.
Hope my example helps you understand the need of a capacitor and also the right size for.
gonzo416 is offline   Reply With Quote
Old 02-01-2011, 08:27 PM   #19448
randy, i blew up my controller last sat. i crossed the pos and neg wires on the battery, and turned it on. can you guys repair this? it is no longer in warranty. i will pay the repair costs if if it is feasable. thanks in advance
gdcopbdcop is offline   Reply With Quote
Old 02-01-2011, 08:53 PM   #19449
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
79+shipping,fill out the form and get a RA# and send it in http://www.teamtekin.com/Forms/Servi...estForm_V2.pdf
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 02-01-2011, 09:16 PM   #19450
thanks 20smoke, i will send it in.
Old 02-01-2011, 09:39 PM   #19451
Quick question. I have two scenarios here.
Which would be faster and why:
A) An esc with 12 degrees of fixed timing (no boost or turbo), and zero Motor timing.
or
B) An ESC at 0 Timing and the motor and 12 degrees of timing.
Thanks....
www.TheRcShack.com
www.TeamXray.com
Spdjunky is offline   Reply With Quote
Old 02-02-2011, 09:43 AM   #19452
Team Tekin
Randy_Pike's Avatar
Timing is timing.
Old 02-02-2011, 10:01 AM   #19453
Trader Rating: 18 (100%+)
Originally Posted by Randy_Pike View Post
Timing is timing.
Very true "but" no ones zero motor timing is actually "zero".
eek....sorry. Can of worms here.....
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 02-02-2011, 10:23 AM   #19454
Krio's Avatar
Trader Rating: 150 (99%+)
What he means is that if you can verify that you add exactly 12 degrees on the motor by rotating the endbell vs adding exactly 12 degrees in the esc it does not matter. Yes, 0 pretty much never equals 0 on another brand motor
www.kriostasis.com
Krio is offline   Reply With Quote
Old 02-02-2011, 11:12 AM   #19455
Team Tekin
Tekin Prez's Avatar
This helps support a decent argument to require a blinking led to indicate spec mode, rather than ban programmable escís that have a spec mode. Easier to tech and verifies that a manufacturers assures us the setting is 0deg of timing. Escís that indicate nothingÖ. Tell us nothing.
Rather than BAN the blinky, require the blinky for spec mode
[email protected]
Smarter, Smaller, Faster....
www.teamtekin.com
Tekin Prez is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
