Tekin RS ESC sensored >
Old 01-30-2011, 08:36 AM
  #19426
lochness42's Avatar
Originally Posted by chris_blakey
Well my tekin RS Pro has developed an issue.
Working fast a week ago at my last club meeting. Come to fire it up at home and I get flashing LEDs 1,2,6&7.
This appears to indicate wrong motor type. I havent changed anything since the last club meeting, picked up the car of the track, removed the battery and took it home with me.
I have tried reflashing from the hotwire and returning to defaults but that hasnt working. Reading around the forums this appears to require a service from tekin.
Couple of questions about that:
I am in the UK so does it have to get sent to america?
Will they repair it free of charge, I only bought it in July?
Randy if you see this can you PM me what to do next?
I can't believe this has happened to me, I do not have a spare so can't race till it is fixed.
Please help.
Try different motor - had one motor with burnt coilings (wasn't mine - and it didn't work since I got it to my hands). Thats is how it was indicated - as it had shorted some wires.
Oh and you've got local distributor - RCDisco you still can try to contact them http://www.rcdisco.com/
lochness42 is offline
Old 01-30-2011, 08:40 AM
  #19427
landau's Avatar
Please help.
chris_blakey
I had same trouble. I bought RS last December and tried to ESC set-up with no problem, however RS suddenly error code 1,2,6 and7 blinking when I start to run. So my car could never run the track.
Motor changes, battery check, radio system check, but they were correct.
I mailed to Team Tekin service and received reply, their answere is as follows,
"Did you try a factory reset? Hold the mode and inc buttons
for 3 seconds?
If that doesn't work and you made sure your connections were
good, you should send it in to us for replacement. I will
post the info you need to send it in below...
Tekin Support
Thank you for contacting Tekin Support. Please read the
below regarding our Service Policies and Procedures. This
can serve as your service FAQ.
Your RA# is:+++++++"
I sent RS to Team Tekin and arrived this 11th I found it by tracking service.
After that, I mailed to Team Tekin again that I need to use end of this month or the first of next month, so please replace and send back me as soon as possible, however I don't hear from since then. There is no way for finding my ESC go anywhere, what problem occur upon and it is initial problem or not.
I think you should mail or call on Team Tekin service about your ESC.
I often saw LED error code 1,2,6 and 7 at my home circuit, in addition, their RS or RS pro could not sound beep when it could not work well.
I suspect that this trouble is not concerned with Hot Wire, motor and other electrical equipment. It might be initial ESC trouble in itself.
tech support: support [at] teamtekin [dot] com
Phone: (208) 634-5559
take care
cf. my application
1/12th car 1 cell lipo
trinity D3 17.5
radio sanwa(airtronics) M11X and 451R
Tekin RS varsion 212
landau is offline
Old 01-30-2011, 10:56 AM
  #19428
thanks guy, tried all of the above and still no go.
will give Rcdisco a ring tomorrow and see what they say.
chris_blakey is offline
Old 01-30-2011, 02:18 PM
  #19429
Geezatec's Avatar
Also ck your solder joints, one maybe a cold joint or came loose. What motor you running anyway? What Bettery you running also, NiMh or Lipo's, and mah & voltage??
Geezatec is offline
Old 02-01-2011, 02:19 AM
  #19430
Hi.
What would be the difference or bennifits of using a bigger capacitor?
For example, going from a 16v 330uf to a 16v 1000uf?
RSCosworth is offline
Old 02-01-2011, 02:27 AM
  #19431
Originally Posted by RSCosworth
Hi.
my guess is none. the capacitor is not there for performance reasons, it is there to act as a filter for the EMP noise generated by the motor. this allows you receiver to work without interference.
Don't quote me though. I am new to this stuff.
omegaf is offline
Old 02-01-2011, 03:55 AM
  #19432
Originally Posted by toptek
thye gm works. the new grauphners not. or change the sensor on the motor.
I had a few problems when running a Gm10.5 boosted.
I struggled to get any major speed out of the motor.
I have been told that the Gm motors like a lot of timing and the tekin is not suited to this motor.
I bought a Tekin redline 10.5 and never looked back - Motor is awesome quick and runs really cool.
tc3nitro is offline
Old 02-01-2011, 05:22 AM
  #19433
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
Hi.
you want to run the stock cap
20 SMOKE is offline
Old 02-01-2011, 05:33 AM
  #19434
I run also a Tekin redline motor.
My GM motor went in smoke. I used it with the GM speedo.
I tried it with the Tekin speedo but I liked the Tekin motor more.
I had good speed with the GM motor. I geared it quit heavy.
verry heavy compared to the tekin motor.
The LRP X12 is great with the Tekin speedo.
I used it in the mod class last sunday and the car was like a rocked.
A teammember did my car and speedo setup because I worked on my 13,5 car.
tried in that class other tiers and I will use them next time also in the mod class.
Mod motor became 70C and speedo with a bigger cap and no extra cooling had only 4 leds burning.
toptek is offline
Old 02-01-2011, 06:11 AM
  #19435
bigz's Avatar
when running 13.5 x12 motor with the tekin, will i need to use the 4 dot timing? used 2 dot instead but temps reach 200c and motor has drag brake e=when i let go of the throttle. any tips? haven't had much time playing with the motor with regards gearing and esc set up.
bigz is offline
Old 02-01-2011, 06:19 AM
  #19436
kuruption's Avatar
Trader Rating: 24 (100%+)
HOLY CRAP.... 200 CELSIUS?!
kuruption is offline
Old 02-01-2011, 09:07 AM
  #19437
Trader Rating: 14 (100%+)
200c = 392f
mikeygar is offline
Old 02-01-2011, 09:10 AM
  #19438
Team EAM
Trader Rating: 79 (100%+)
Huge Thanks to Randy for being at the Snowbirds for trackside support. Thanks to Jim and Tekin for the support and sending him. All my cars ran flawless with Tekin power in them for 4 A mains in On-road including a TQ. Everything ran fast and felt great!
EA
EAMotorsports is offline
Old 02-01-2011, 09:21 AM
  #19439
forrestboy's Avatar
Trader Rating: 16 (100%+)
how do i get my rs in the ROAR sportsman "blinky" mode using my hot wire on version 208?
forrestboy is offline
Old 02-01-2011, 09:23 AM
  #19440
20 SMOKE's Avatar
go to throttle it will be 1-5 and C1 C2 you want 1
20 SMOKE is offline
