Old 01-26-2011, 08:17 AM   #19381
FLHX1550's Avatar
Originally Posted by wallot View Post
it will. any 16+V 330uf+ low ESR cap will do.
How does one verify if they are low ESR?
JConcepts - TKO - RW Mods - B-Fast - MODX Motors & Batteries - Skare OCD Designs
FLHX1550 is offline   Reply With Quote
Old 01-26-2011, 08:42 AM   #19382
FLHX1550's Avatar
So, will the capacitor I listed work?
This one:
http://www.radioshack.com/product/in...tic+capacitors
Old 01-26-2011, 09:39 AM   #19383
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Jochim_18 View Post
It has proven that the RS is fast but now how can you make this speedcontrol smooth on the infield.
Mine is smooth as butter on the infield but still very very fast. Run a wider RPM range and more turbo delay. I am running a .3 turbo delay and it makes a big difference in the smoothness of the power delivery.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 01-26-2011, 11:19 AM   #19384
Jochim_18's Avatar
I got the RPM setup at 5400-2000 with delay of .2 seconds. I will try changing the delay to .3 may even late. It was sure fast but when the turbo kicks in I just over shoot the corner and it's frustrating.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 01-26-2011, 11:48 AM   #19385
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
if you over shoot a corner then there is to much turbo try taking some of it out.what size is the track
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-26-2011, 01:04 PM   #19386
ets
ets's Avatar
im sure this has been covered but does anyone know how to put a tekin rs pro into stock mode? i am running a class in feb. that says stock esc setting !a little help would be appreciated thanks!
ets is offline   Reply With Quote
Old 01-26-2011, 02:06 PM   #19387
20 SMOKE's Avatar
push mode button 5 times untell led is at TP press INS untill 1 led flashes that is spec mode
Jamie W
Old 01-26-2011, 02:29 PM   #19388
BCbud's Avatar
Trader Rating: 37 (100%+)
That would be LED's 3 & 5 for 212.
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Old 01-26-2011, 03:08 PM   #19389
STLNLST's Avatar
Trader Rating: 21 (100%+)
Sounds like your turbo is coming on super late. If your car is that fast I would question if you need turbo at all.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-26-2011, 04:09 PM   #19390
ets
ets's Avatar
ok thanks for the info guys
Old 01-26-2011, 05:05 PM   #19391
20 SMOKE's Avatar
3,5 is the sequence,the 1 led is profile 1 which is spec
Jamie W
Old 01-26-2011, 09:34 PM   #19392
Jochim_18's Avatar
Track is about 100x50 it's a temporary parking lot track so our layout change every race day. I really like how fast is the car right now and the bottom end is insane. I just need to make the throttle feel smoother. On the infield it feels like I have a second gear when the turbo kicks in.
Boost - 50 degree
Turbo - 15 degree
RPM - 5400-20000
Delay - .2 sec
Ramp - 2
Dynamic timing - 30 degree
Motor - duo 3
FDR - 6.9
Old 01-26-2011, 09:45 PM   #19393
20 SMOKE's Avatar
Boost - 50 degree
Turbo - 15 degree
RPM - 5400-20000
Delay - .2 sec
Ramp - 2
Motor - duo 3
FDR - 6.9
turn the turbo off run a end of around 12k and 3-5 start with 5 motor neutral width 10,minimum throttle 8.,try a fdr around 5.8 check the temp and add 5 turbo
Jamie W
Old 01-26-2011, 09:48 PM   #19394
Jochim_18's Avatar
I have done that setup but no bottom end it feels really flat.
Old 01-26-2011, 09:49 PM   #19395
20 SMOKE's Avatar
lower the start to 2-3 and 12 min throttle
Jamie W
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
