Old 01-25-2011, 09:40 PM   #19366
Still Bill's Avatar
Originally Posted by STLNLST View Post
That's what we're here for. The min brake does the same thing.
One setting at a time...
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 01-25-2011, 09:46 PM   #19367
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by gonzo416 View Post
There doesn't seem to be any 212 setups. Everyone says use the 208 setups but there are additions to the 212 that are not in 208. I'm looking for a good setup for a x-12 17.5 on a carpet track for a rubber tire Touring car. I'm thinking of going back to 203.
212 does have a few additional settings but guys are saying that the car has less punch or it doesn't feel like the previous. If all the setting are carried over EXACTLY then you should feel the same and laptimes should be the same. The new additions are to further fine tune the throtle and brakes. Don't give up just yet. We're here to help. What settings are you currently running? What are you looking to get out of your car? What's it lacking? What are you happy with? Once we have a starting point we have nowhere to go but up
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-25-2011, 09:48 PM   #19368
STLNLST's Avatar
Fair enough How have things been on the rug? I miss ya'll I'm playing in the dirt now.
Old 01-25-2011, 10:35 PM   #19369
Still Bill's Avatar
Ask Scotty B, he came by on Saturday during the rug racing. I don't think that we could have accommodated one more racer in the pit area. Racing is great; but, I let some other "valley boys" get the best of me.
Sunday off-road was strong too. But, I still don't do dirt...Too much fun in WGT with my Tekin RS.
Old 01-25-2011, 11:04 PM   #19370
myan_gsr's Avatar
I've been proudly running an RS Pro in various spec racing classes over the last 2 years with great success. I am now looking into running Mod/open in the next couple of months with an LRP/Nosram X12 style motor and i was wondering if the RS Pro is competitive in that situation or would it be advisable to buy an RX8 for better power handling.
l remember trying a 3.5T motor not long ago and the speedie thermalled within 2 minutes in dual mode. I believe running twin caps and a fan on the posts is advisable but will it give me the performance i need to be competitive against LRP's and Speed Passions ESC's. Any advice/opinions/setups would be greatly appreciated
FYI: I'm currently runing a 416WE/X on various outdoor tracks w/ rubber tyres.
Thanks in Advance,
Steve
---Tamiya 416X---Tamiya TRF416WE---Tamiya TA05R---Tamiya F104 Pro ---Tamiya F103R 15th Anniversary ---Tamiya F103---Tamiya F103GT---Tamiya TL01---
www.brccc.org
myan racing (coming soon)
myan_gsr is offline   Reply With Quote
Old 01-25-2011, 11:15 PM   #19371
AndreC's Avatar
If you're running 212 then you have the new min throtle adjustments. This helps with the bottom end. The higher the number the more punch it will have. If you were happy with the settings of 203 then you should be fine with the same settings on 212. We will get you pointed in the right direction.
Thanks!
AndreC is offline   Reply With Quote
Old 01-26-2011, 01:06 AM   #19372
Jochim_18's Avatar
It has proven that the RS is fast but now how can you make this speedcontrol smooth on the infield.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 01-26-2011, 05:45 AM   #19373
This is exaclty what i have been struggling with !
If someone has some good settings for a Rs and 10.5t Redline for use indoor on carpet that would be great. The throttle feels dead at the bottom then WHAM all the power comes in a massive chunk right at the top.
tc3nitro is offline   Reply With Quote
Old 01-26-2011, 05:59 AM   #19374
What are your settings?
Sounds like you should degrease the rpm range and increase your turbo delay.
MartinBasse is offline   Reply With Quote
Old 01-26-2011, 06:12 AM   #19375
STLNLST's Avatar
Thanks in Advance,
Steve
It all comes down to throtle finger and proper gearing. The caps and fan do help but if someone is heavy on the throtle then the gearing needs to be adjusted as well as the speedo settings. A 3.5 is a beast and will need the proper settings to be controllable. Use a practice day or two to get the feel of it and do the 2min run and temp your motor test to see if the gearing/settings are correct.
What settings are both of you currently running and what motor? One way to smooth out the car is increasing the end rpm's while staying with the same start rpm's. Boost also plays a factor. What changes have you already done to try and smooth it out so I dont suggest something you did already?
TC3nitro- Sounds like you could use a bit more boost in your set up. How much are you running now and what motor and gearing? I'm sure a simple adjustment and you'll be happy. I also assume this is for sedan???
Old 01-26-2011, 06:13 AM   #19376
STLNLST's Avatar
I talk to Art all the time. He said it was packed.
Old 01-26-2011, 07:31 AM   #19377
FLHX1550's Avatar
Exclamation
I am sure this is going to come off like a Rookie question.
Broke the capacitor on my RS, and would like to use it this weekend, but none of our local hobby shops stock any Tekin hardware. Would I be able to find one at Radio Shack?
The stock Tekin cap is 330uf, 16v. See the shack has a 1000uf, 35v Radial cap. Would this get me by till I can get the Tekin one?
http://www.radioshack.com/product/in...tic+capacitors
JConcepts - TKO - RW Mods - B-Fast - MODX Motors & Batteries - Skare OCD Designs
FLHX1550 is offline   Reply With Quote
Old 01-26-2011, 07:49 AM   #19378
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
a 1000 16v will get you by
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-26-2011, 07:52 AM   #19379
FLHX1550's Avatar
But the 35v won't work?
Old 01-26-2011, 08:13 AM   #19380
wallot's Avatar
it will. any 16+V 330uf+ low ESR cap will do.
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
