Tekin RS ESC sensored >
Old 01-25-2011, 05:43 PM
  #19351
AndreC's Avatar
Originally Posted by AndreC View Post
It doesnt seem anywhere near as fast as the 203. I'm pretty sure I have the right settings. Dennis set it for me.
I run up there at FLIRCC as well, although I don't think I've met you in person yet.
AndreC is offline
Old 01-25-2011, 05:45 PM
  #19352
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
what does your car need,care to post you setup and what car it is
20 SMOKE is offline
Old 01-25-2011, 05:57 PM
  #19353
AndreC's Avatar
It needs more torque, mid range speed is good, almost too fast for my skill.
The 203 version had way more acceleration off the line.
This is the setup Dennis put on there:
start rpm around 4750 end 10000
turbo 12 timming 100 boost 45
ramp3 delay .00 neutral width 5 drag brake 10
When I got home I lowerd the start rpm to about 2700, turbo up a few, boost to 50, timming down to 85
all else the same
Are you one of the Burnside brothers? Thanks for the help man
AndreC is offline
Old 01-25-2011, 05:58 PM
  #19354
AndreC's Avatar
all else the same
My car is a 10R5
AndreC is offline
Old 01-25-2011, 06:08 PM
  #19355
20 SMOKE's Avatar
no i am not on of the burnsides,my name is in my signature.
2-3k start( i started going down from the 4-5k and like it better)
8500 end
50 timing boost
0 turbo (track is to short)
5 motor (what motor do you have)
throttle profile 3
neutral width min
minimum throttle 13
208 tire
34-37/100
i think i will be there sunday if you need help
20 SMOKE is offline
Old 01-25-2011, 06:12 PM
  #19356
dzstr's Avatar
Trader Rating: 20 (100%+)
You will be lonely there if you show up this Sunday
dzstr is offline
Old 01-25-2011, 06:15 PM
  #19357
20 SMOKE's Avatar
i will be there on points day
20 SMOKE is offline
Old 01-25-2011, 06:18 PM
  #19358
AndreC's Avatar
8500 end
50 timing boost
throttle profile 3
neutral width min
minimum throttle 13
208 tire
34-37/100
Sorry man, I didnt notice your name down there.
i still have the end rpm set to 10k
i was wondering if the track was too short for the turbo
i have a moms motor, and i thnk the timing is set to 0, so that may be the prob
my gearing is 88/43
2.10 on the tires
everything else is roughly the same
i was planning on going up this weekend but Dennis said him and Ron would be at the birds. i will be up there if its open.
Thanks for the help
AndreC is offline
Old 01-25-2011, 06:19 PM
  #19359
AndreC's Avatar
my gearing is 88/43
2.10 on the tires
Thanks for the help
If not i'll definitely be up there for points day as well
AndreC is offline
Old 01-25-2011, 06:21 PM
  #19360
20 SMOKE's Avatar
the 10k is fine it just smooths it out,go to the first mark + from the center
20 SMOKE is offline
Old 01-25-2011, 07:51 PM
  #19361
STLNLST's Avatar
Trader Rating: 22 (100%+)
all else the same
If you're running 212 then you have the new min throtle adjustments. This helps with the bottom end. The higher the number the more punch it will have. If you were happy with the settings of 203 then you should be fine with the same settings on 212. We will get you pointed in the right direction.
STLNLST is offline
Old 01-25-2011, 08:18 PM
  #19362
gonzo416's Avatar
Trader Rating: 39 (98%+)
There doesn't seem to be any 212 setups. Everyone says use the 208 setups but there are additions to the 212 that are not in 208. I'm looking for a good setup for a x-12 17.5 on a carpet track for a rubber tire Touring car. I'm thinking of going back to 203.
gonzo416 is offline
Old 01-25-2011, 08:20 PM
  #19363
hairy's Avatar
hairy is offline
Old 01-25-2011, 08:22 PM
  #19364
Still Bill's Avatar
Sounds like I should try messing with my minimum throttle adjustment setting. Thanks Clint.
Bill
Still Bill is offline
Old 01-25-2011, 08:39 PM
  #19365
STLNLST's Avatar
Bill
That's what we're here for. The min brake does the same thing.
STLNLST is offline
