Old 01-03-2009, 08:43 PM   #1921
tallyrc's Avatar
hey folks. just picked up an rs-pro and searched for my answer but no luck.. i don't yet have a hotwire so i'm looking for a good baseline that i can achieve without a hotwire for 13.5 and 10.5 novak motors in sedan.. medium/large asphalt high traction track.. i believe it's the latest publicly available software... thanks..
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 01-03-2009, 10:07 PM   #1922
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
Gear it 4.1 to 4.2 with the default timing on the can. If you get 189 and hotwire then gear it 4.6 and 15+15 boost.
ChristopherKee is offline   Reply With Quote
Old 01-04-2009, 01:31 AM   #1923
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
your going to use taller hearing while in dual mode(default). I would also reccomend getting a hotwire to maximize the rs's potential.
Gear for temps and speed
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 01-04-2009, 04:12 AM   #1924
mangoman's Avatar
tallyrc, in my opinion you arent going to be able to get the rs competitive without a hotwire
But once you are able to program it with the hotwire it will be fast!
Ask around the pits and see if anyone can help program the speedie for ya, or if you are lucky and come across any of the tekin team drivers, im sure they will program the esc for you as long, as they have the equipment with them....
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 01-04-2009, 09:07 AM   #1925
AdamD's Avatar
If you can make it out to the track on wed. I could bring my laptop and hotwire and hook you up.Just let me know.
AJ DiPirro
T.O.P. Racing U.S.A. / Serpent America / EA Motorsports / Team Epic / Trinity
P3 Graphics / RC3 Grafix / Adco Paving Inc / Team Butter
AdamD is offline   Reply With Quote
Old 01-04-2009, 04:42 PM   #1926
Trader Rating: 26 (100%+)
im running a 4cell 12th scale with 13.5. today i tried the 189 software. the car stutered all the way down the straight. i played with all the settings but nothing made a difference. i loaded 183 and problem went away. anyone else expeirence this?
eddie10 is offline   Reply With Quote
Old 01-04-2009, 04:45 PM   #1927
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Which Motor and how was it setup? Rollout?
Share what you changed on your settings. Did you only change back to 1.83 or did you change something else as well, motor or sensor wire?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-04-2009, 04:49 PM   #1928
I've only had problems with studdering (or groaning on power) if I run too much timing. Once you get to a certain point it's going to cog or come close to coging off the corners.
It's worse if you have a ton of timing and you're overgeared.
They're not kidding when they say you need to gear down as many as 10 teeth when using the boost feature.
Fred_B is offline   Reply With Quote
Old 01-04-2009, 05:00 PM   #1929
What I like about having the extra timing is the ability to use almost "regular" sized pinions again. I am now using 74 t spur with 40 tooth pinion running 17.5 in my 12th scale. And it IS fast!
jeffb is offline   Reply With Quote
Old 01-04-2009, 05:28 PM   #1930
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default mail
Fred you have mail thanks
CRC Gen XL / Xray 09 , t2r pro / CW sprint and CW rocket / Kyosho evolva m3 / Tekin rs / Futaba 4pks / Trinity / Dirtburners thanks Bill / 1/8th racers of Toledo / Trex chassi / Summit Race way / Stateline
LAZER SPEEDWAY where all else IS just a parking lot / Hobby Stop West Raceway
2056dennis is offline   Reply With Quote
Old 01-04-2009, 05:29 PM   #1931
im running a novak 13.5. i also tried a redline 13.5 and different sensor wires. on the speedo i turned boost off, throtle profile,neutral width all wit no change. it was not even close to being overgeared as i changed to 183 and ended up gearing 2 teeth taller.
Old 01-04-2009, 06:05 PM   #1932
Back at ya. We'll get it going.
Old 01-05-2009, 07:04 AM   #1933
Trips's Avatar
Trader Rating: 16 (100%+)
If you don't mind, can I ask what 17.5 motor you're running, what timing at the motor (if any) and what settings you're running in the RS? Still looking for the optimal setting here, but closing in...
Thanks, here's what I got this weekend:
1/12 4 cell NIIMH Trinity Duo 17.5 with the endbell in the ten degree position, and varying boost sesttings and rollout.
First round, boost at 10, rollout 84.00 (46/76, tire 44.3mm) car was off the pace. 112* after the run. Very punchy in the infield, but either not enough on top or too hard to drive that punchy.
Second round boost at 10, rollout 85.63 (47/76, tire 44.1mm) car was faster overall, easier to drive, lap times fell, came off at 138 after 8 minutes.
Third round, boost at 10. rollout 87.26 (48/76, tire 44.0mm) car seemed faster yet, lap times better (same fast lap as round two, but 5 and ten lap averages better by a bit) came off at 155*after eight minutes.
Geared up once again for the main, rollout 89.08mm (49/76, 44mm tire) rolled the boost back from 10 to 2 lap times slowed a bit, not as good as round 3.
Donny Lia suggested running max boost, 0 at the endbell and gearing short. Next week I'll go that direcetion.
MARSHAL!!
Trips is offline   Reply With Quote
Old 01-05-2009, 07:49 AM   #1934
Grenade10's Avatar
Trader Rating: 37 (100%+)
Anyone running the RS in WGT? I've got it runnung pretty wel in 1/12 and oval with 17.5's, but still off in WGT .... need to find more speed prior to Snowbirds.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 01-05-2009, 11:19 AM   #1935
Team Tekin
Randy_Pike's Avatar
Eddie,
Have you checked the sensors in your motor yet using the sensor checker?
Also if you were to run too much boost you can get stuttering pretty easily.
Also, verify that the esc shows 189 in the Hotwire settings as "current."
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
