Old 01-25-2011, 03:49 AM   #19321
The GM is as fast as the Tekin, but the (few) guys at my track using GMs, are pushing 125 degrees celcius on the motor, where I can get the same speed with my Tekin, but only pushing 60 degrees celcius.
I <3 Tekin
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 01-25-2011, 04:28 AM   #19322
djiewie's Avatar
it seems to me that the specific moter used come`s in to play. With the speedpassion 10,5 i run fast with the tekin and temps don`t get over 40 degrees celcius. But with the 13,5 LRp stockspec the speed is not equal with the HW esc.
They (HW) seem to suit the LRP 13,5 better with their timing and get more punch and more speed, so i am losing out on them. We can observe the speed because we have a speedtrap in the lap counts. Punch is observed when we both blip the throttle before the straight. Some improvement can be made here by tekin i would wish. One driver with a nosram 13,5 gets good speed so it has to do with the moter i presume.
Greetz JW
djiewie is offline   Reply With Quote
Old 01-25-2011, 04:56 AM   #19323
Greetz JW
You didn't mention your temp with the 13.5T, but if it also around 40 degrees celcius, I would recommend you to gear up a tooth or 2. You will still get roughly the same punch (with temps this low) and you will get more speed.
Niklas Hansen
Old 01-25-2011, 05:11 AM   #19324
does tekin have a modified esc which is able to
update with stock supercharge software for stock racing
like the SP GT 2.0 ESC?
i want to try something different.
thilo-alexander is offline   Reply With Quote
Old 01-25-2011, 06:05 AM   #19325
STLNLST's Avatar
Trader Rating: 21 (100%+)
Updates have already been put out. Version 212 isn't losing any races in stock. What does the SP GT have that Tekin doesn't?
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-25-2011, 06:08 AM   #19326
The Tekin RS Pro can handle modified, and uses the same software as the Tekin RS.
Niklas Hansen
Old 01-25-2011, 07:13 AM   #19327
Any suggestions on set up for lrp x12 4.5t and 5.0t motor for a TC on asphalt.The track has long straight and technical infield. Thanks in advance.
DYANAJAMBUL is offline   Reply With Quote
Old 01-25-2011, 07:21 AM   #19328
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
http://www.teamtekin.com/hotwire/ESC...-RS-TC-4-5.pdf
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-25-2011, 09:25 AM   #19329
Thanks for the Link.
As per JMoberly's setup sheet, his set up is based on a 6 min race. What if it was a 8 minute race, fortunately our race organizer made it challenging and bumped it up to that duration FOR both heats and finals. This would particularly effect temp on the motor, ESC and my Lipos as well. What is the first adjustment i need to make and at the same time maintaining considerate performance (power ,peed) till the end? should i be playing around lets say the FDR? boost? drag brakes? etc.. Thanks again.
Old 01-25-2011, 09:43 AM   #19330
20 SMOKE's Avatar
gearing,timing how heavy you are on the throttle can all play a roll on temp just start slow and work your way up
Jamie W
Old 01-25-2011, 10:12 AM   #19331
bukil's Avatar
Trader Rating: 39 (100%+)
Originally Posted by COLD AS ICE View Post
start with a 6.4 and max motor timing on the endbell, put these settings on your speedo
boost:45
turbo:10-15
delay:.05
start rpm:5300
end rpm:15000
ramp:3.0
timing advance: start at 25 and go up for more top end, just keep an eye on your temps.
Originally Posted by gonzo416 View Post
I'm not sure but I thought timing advance was set at 100 only so that if the sensor wire somehow came off it would not affect the motor in sensored mode. Can someone correct me if I'm wrong.
Originally Posted by bukil View Post
@ gonzo416:
That's what I thought too.
Could any of the team drivers confirm this?
Anyone?
☆ ActivRC ☆
bukil is offline   Reply With Quote
Old 01-25-2011, 10:21 AM   #19332
20 SMOKE's Avatar
yes it is 30* so if you loose the sensor wire you still have 30 and finish a race
Jamie W
Old 01-25-2011, 10:37 AM   #19333
rcfiend's Avatar
Trader Rating: 30 (100%+)
I;m thinking about purchasing a Tekin esc, but don't want to lug a laptop to the track all of the time. Will the Tekin run adequatley enough on a netbook?
rcfiend is offline   Reply With Quote
Old 01-25-2011, 10:43 AM   #19334
Originally Posted by tc3nitro View Post
Saving setups and some datalogging would be great.
I have run my Tekin RS back to back against a GM 90 2010 and the gm is a little smoother on the throttle and feels to get the power down a little better, but the Tekin runs way way cooler on the motor.
I am running a Tekin redline 10.5t motor indoors on carpet with rubber tires.
Tekin interface is far easier (although i think not detailed enough) compared to the Gm (which you need a degree in physics to program).
I agree with you, That is why I use the Tekin and not my GM.
I have my Tekin smooth enough. I love the Tekin.
My GM do I keep because it is still fast and good for a backup.
I run 10,5 13,5 and 17,5 with Tekin motors. 17,5T I got 2 days before the race from last sunday.
toptek is offline   Reply With Quote
Old 01-25-2011, 10:59 AM   #19335
Krio's Avatar
Trader Rating: 150 (99%+)
Yes. The latest software has the option to do an "express install" with a lightweight interface just for netbooks.
www.kriostasis.com
Krio is online now   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
