Old 01-20-2011, 11:39 AM   #19261
Send a message via AIM to Matt W
Default Throttle and brake minimum
Hi Guys,
I was wondering if someone could explain the new throttle and brake minimum feature on the new 212 software?
any help would be much appreciated?
Matt W is offline   Reply With Quote
Old 01-20-2011, 11:48 AM   #19262
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
if it is 10 you get 10% at throttle start up same with brakes 10 is 10% of brakes at when it is applied.this is when the throttle and brake are first being applied or being recognized by the esc
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-20-2011, 03:27 PM   #19263
padailey's Avatar
Originally Posted by djiewie View Post
you installed the software but did you then updated the esc?
it has a button on the rightside lower corner. maybe first toggle the advanced button and then it shows the update button. After update you have to calibrate your controls again.
wish you succes, greetz JW
Got a chance to try again last night to get 212 to work. Uninstalled... Installed... rebooted.... hooked up hotwire and it stated I had older software so it went through the update and reset to default. Advanced button would not work. When I pass the mouse over the button occasionally the word "Advanced" lights up but will not do anything else. I can make changes and apply those changes but once I quit and hook up the esc again it starts all over saying my software is an older version. Guess I'll just try going back to 208 unless someone has more suggestions.
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 01-20-2011, 05:39 PM   #19264
Grenade10's Avatar
Trader Rating: 37 (100%+)
If you come over to the HobbyPlex this weekend, I have 203, 208 and 212 with me that works and can see about upgrading your ESC if you want.
Will be in Friday afternoon 4-6 based on weather and running oval and onroad this weekend.
Mark
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 01-20-2011, 08:58 PM   #19265
hey can i run a tekin rs pro whit a 4.5t motor on mod class and not have to worriet about overhiting
f1o7x9 is offline   Reply With Quote
Old 01-20-2011, 09:19 PM   #19266
20 SMOKE's Avatar
yes
Jamie W
Old 01-20-2011, 11:28 PM   #19267
I have an RS and want to step up to Mod with my 1/12th 1S
What is the lowest turn motor i can run without it temping out on me ???
also do you run it in duel mode or sensored ??
Thanks Phil
sidecarphil1 is offline   Reply With Quote
Old 01-21-2011, 01:59 AM   #19268
tc3team's Avatar
Sometimes it is advised or heard of to run 2 capacitors (stock tekin caps that come with the ESC), but apart from that, you are good to go
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 01-21-2011, 06:12 AM   #19269
Skitee's Avatar
If you do still have a problem with heat after you've upgraded the cap then I find that a 25mm high rpm fan stuck to the chassis blowing across the posts helps loads when you run low turn mods.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 01-21-2011, 06:19 AM   #19270
20 SMOKE's Avatar
Thanks Phil
5.5 is max for a rs,run in dual mode.it can be run in sensored but you need to take it slow
Jamie W
Old 01-21-2011, 10:23 AM   #19271
Trader Rating: 15 (100%+)
Default Speedo settings
Anyone have a good setup for 17.5 ramping and non ramping tc on a small carpet track using the d3 ? Also range for gearing.
AARON YOUNG is offline   Reply With Quote
Old 01-21-2011, 11:34 AM   #19272
20 SMOKE's Avatar
how small of a track
Jamie W
Old 01-22-2011, 10:45 PM   #19273
STLNLST's Avatar
Trader Rating: 21 (100%+)
Are you gonna run the settings given or gear to the moon like normal.... Call me sucka!!!
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-23-2011, 12:09 AM   #19274
Still Bill's Avatar
Roasty!
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 01-23-2011, 12:10 AM   #19275
SPACEBOY's Avatar
Originally Posted by 20 SMOKE View Post
that fdr is around stock spec(no boost/turbo) i would start around mid 5 with a setting of 30-40 timing boost 10 turbo start 2-3k and 11k end delay .05 ramp 2.if you havent bought the esc yet just buy the rs you don't need the pro unless you are going to run mod or 4wd offroad.now all this boost and rpm will get you confused so here is a article that will help you understand what everything id and does.http://www.carsrcracing.co.uk/?p=244.after you get everything wired up come back and ask more questions
Ok got a chance to play with this today at Tamiyas track. I settled at 5.80 FDR with a slightly modified Hara setup (boosted/turbo) from the Tekin site. so if I turn off the boost/turbo, thats when I need to be geared closer to the 3.5 FDR? Temp on the endbell was around 170 when I came off the track.
SPACEBOY is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
