Old 01-14-2011, 09:28 AM   #19201
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by louielou View Post
k. i need a mod setup too. probablly for a ballistic or lrp 8-6.5t
for k-raceway,you coming to minnreg
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-15-2011, 07:13 AM   #19202
Default Speed Passion 13.5 V3 212
Any suggestions for Speed Passion 13.5 V3 running 212 software in 1/10 TC on low to medium traction asphalt?
Was thinking of running Hara's 17.5 settings for 208 but with 7.45 FDR as a starting point. His settings and FDR worked well for me with 17.5 on my regular tracks and I notice a few 13.5 set-ups are close to his.
Any thoughts and suggestions will be much appreciated.
He who dies with the most toys wins, if it's a tie, then it's he with the best.
sjh28 is offline   Reply With Quote
Old 01-15-2011, 08:05 AM   #19203
StevenOlsen's Avatar
how big is the track ?
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Old 01-15-2011, 02:09 PM   #19204
mac853's Avatar
Questions??
Could somebody make me advice of setup for RS with 8min race in this track(picture below), and also recommend what kind of motor(makes and turns) which recommend to use.
Best regards
Tekin RS ESC sensored-149875_155893717787252_100000998754506_265051_2832959_n.jpg
mac853 is offline   Reply With Quote
Old 01-15-2011, 03:11 PM   #19205
20 SMOKE's Avatar
need to know what class,we cant tell you to run tc or 12 or wgt
Jamie W
Old 01-15-2011, 05:20 PM   #19206
louielou's Avatar
Trader Rating: 16 (100%+)
Default mod setup
20 Smoke it is for K raceway. Also any suggestions for an lrp 17.5
Luis
[email protected]
Ebay account LOU840
louielou is offline   Reply With Quote
Old 01-15-2011, 05:22 PM   #19207
Well, here is the latest.....
I bought a Mamba Max to run in my 1/10 2wd buggy. It was a sound choice.
I currently run 2 Tekin RS ESC's in my SC trucks (previously used in touring and other classes that have dwindled).
I also run 2 RX8's.
So the decision was to buy an ESC that I could use in both classes as a back up since 2wd buggy would be the first class sacrificed.
The Mamba ESC wasn't in my buggy and in my possession more than 40 hours. It's throttle wasn't as smooth as the Tekin's, and the software is extremely lacking to make it user friendly and very tuneable. Thank goodness I found a buying soon without taking too much of a loss!
A new RS is on the way. Wish the RX8's were as relaible as the RS units!! <cough>
Keep up the good work Tekin...
www.TheRcShack.com
www.TeamXray.com
Spdjunky is offline   Reply With Quote
Old 01-15-2011, 06:18 PM   #19208
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
Alright guys- Did a quick search and came up with nothing solid.
I bought an RS Pro from a techher-- and it arrived without the capacitor.
Otherwise, good shape. Updated it with hotwire and all seems well. Tomorrow I will run it for the first time.
I have on hand a 1000uF 16V Capacitor and I guess im just wondering if anyone had any experience with larger caps on this unit?
A friend has a 600uF available as well.
I have read of people doubling up on the cap..
thoughts from the Tekin Pros??
Thanks in advance!
OUT
Keith Billanti is offline   Reply With Quote
Old 01-15-2011, 06:38 PM   #19209
20 SMOKE's Avatar
1000 is ok to get you by never heard any one use a 600,dont see a problem since two stack would be 660
Jamie W
Old 01-15-2011, 06:41 PM   #19210
What is the exact purpose of this capacitor?
is it just to even out voltage coming from the pack?
OUT
Old 01-15-2011, 06:44 PM   #19211
20 SMOKE's Avatar
Originally Posted by Krio View Post
The point of the cap is to keep the voltage going to the esc as steady as possible. There is a tiny bit of resistance and impedance in the capacitor that slows how fast it can charge/discharge. The smaller the esr value, the more effective the capacitor. There are several ways to decrease the esr value of a system, but the main two are to add more capacitors/capacity (higher uF) or use better capacitors with lower esr values. The 330 uF cap included has a very low esr value while the 1000 uF cap from the shack does not. However, the larger capacity helps somewhat. The best solution if your esc is on the toasty side is multiple caps with the low esr designation so that you are maintaining the esr, but adding to the capacity. That is why 2 330 uF caps are suggested for hot mod motors.
Jamie W
Old 01-15-2011, 06:58 PM   #19212
Nice
I figured as much.. well, i didnt think as far into it as esr Values..
I wonder how I could get that info off of mine.. ill start digging..
thanks again-
and I swore up and down i would never do anything from "Circuits"..
KB
OUT
Old 01-15-2011, 07:04 PM   #19213
K= according to my search, if this is at all solid info- (ha) my cap should have 230.0 mOhm esr.
Do you know what the rating is on the 330uF unit? Can you tell me the manufacturer?
edit=
http://parts.digikey.com/1/parts/146...102m016st.html
OUT
Old 01-15-2011, 07:35 PM   #19214
j86
Hoping someone may be familiar with this problem im having...
my Speed Passion v3 13.5 doesnt seem to make any TURBO with any settings on the RS PRO i have...
I've tried boost from 10-15 with 0 to 0.05 delay and the motor doesnt seem to make any Turbo. (turbo at 30-40 and timing advance left at 80)
I've played around with gearing to ~7.3 FDR and the in-field speeds are similar to our racers but on the straight, the motor just seems to run out of horsepower. The torque feels right but the straight away obviously has no turbo.
I've tried different sensor wires (wires that I tested on another car that works fine). I've also tried other SP/Duo 13.5 on with this Tekin RS PRO and there is obviously turbo.
I have my RS Pro set on SENSORED mode and 2s...this is for my 1/10 Touring...
What else should I try? It's just weird because it seems like there IS power but nothing for the straight away...
j86 is offline   Reply With Quote
Old 01-15-2011, 10:09 PM   #19215
Whats your boost set at?
Cyclone Bender is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
