Old 01-13-2011, 03:46 PM   #19186
padailey's Avatar
Originally Posted by jetmechG550 View Post
What version on Winblows are you running?
Vista
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 01-13-2011, 04:06 PM   #19187
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Did you restart your computer after the install?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 01-13-2011, 06:52 PM   #19188
padailey's Avatar
Originally Posted by djiewie View Post
you installed the software but did you then updated the esc?
it has a button on the rightside lower corner. maybe first toggle the advanced button and then it shows the update button. After update you have to calibrate your controls again.
wish you succes, greetz JW
Advanced button would not respond. So it only went through the initial 4 stage update when I first plugged in the esc. I tried some different setups and could see the differences on the track so I know the settings I had made it to the esc. I also had to setup the esc to the radio each time. Its just that I had to start from the default each time.
Tamiya TRF416X
Old 01-13-2011, 06:55 PM   #19189
padailey's Avatar
I'm not sure.... I know it restarted at least once but I think that was after the hotwire setup uninstalled on my first try. Actually I'm pretty sure it didn't restart after it finished installing. If that's all it is I guess I'll know the next time I plug in the esc because it has been restarted since I last used it.
Tamiya TRF416X
Old 01-13-2011, 06:56 PM   #19190
Team Tekin
Randy_Pike's Avatar
If you just updated the esc you must re launch the software to gain access to the "update" button.
Old 01-13-2011, 07:34 PM   #19191
lorider75's Avatar
hello,
i have an issue with my rspro. When i hit the brakes the car needs a push start to get going. and just recently lights 1,2,6 and 7 have started flashing and the car does nothing.
i have tried 2 different motors, 3 sensor leads, 2 of which i know are good.
im stuck what to do, it just started doing this last time out.
thanks
anthony
Team High Torque * Extremercmods.com
lorider75 is offline   Reply With Quote
Old 01-13-2011, 07:45 PM   #19192
Randy is there an issue with upgrading from an older version of Hotwire on Vista like on Win 7? There were a few steps I had I had to follow to completely remove the old version to get the new version to work right, just wondering if that may be same for padailey?
jetmechG550 is offline   Reply With Quote
Old 01-13-2011, 07:53 PM   #19193
hairy's Avatar
Originally Posted by lorider75 View Post
hello,
thanks
anthony
Anthony you have a p.m.
MERLIN RACING
"He once ran a marathon because it was on his way"
Logic is a lost art!
You are defined in life by how you respond to defeat!
hairy is offline   Reply With Quote
Old 01-13-2011, 09:11 PM   #19194
louielou's Avatar
Trader Rating: 16 (100%+)
Default lrp 17.5 carpet
i am running a lrp x12 17.5 touring car on carpet. does anyone have a bad ass setup for this motor. appreciate it!
Luis
[email protected]
Ebay account LOU840
louielou is offline   Reply With Quote
Old 01-13-2011, 09:13 PM   #19195
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
not for you
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-13-2011, 11:24 PM   #19196
Cannondale1974's Avatar
Trader Rating: 29 (100%+)
Hey guys, what exactly does the INCR button in the bottom right hand corner of the Tekin RS do? Is it absolutely necessary to use it?
Reason I ask is mine doesn't work and I am going to be selling it soon. I've had two of these ESC and never used that button. I want to be accurate when I advertise this ESC as it works flawlessly otherwise.
Thanks!
Cannondale1974 is offline   Reply With Quote
Old 01-13-2011, 11:51 PM   #19197
Skitee's Avatar
The INCR button is used to adjust settings like Drag Brake etc. when you are in Quick Tune / Pit Tune mode, the INCR button is also used if you need to do a factory reset on the RS.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 01-14-2011, 07:46 AM   #19198
louielou's Avatar
Default lrp 17.5
20Smoke, FUNNY!
Luis
[email protected]
Ebay account LOU840
Old 01-14-2011, 08:15 AM   #19199
20 SMOKE's Avatar
20Smoke, FUNNY!
i'll pm you later
Jamie W
Old 01-14-2011, 08:33 AM   #19200
louielou's Avatar
Default lrp 17.5
k. i need a mod setup too. probablly for a ballistic or lrp 8-6.5t
Luis
[email protected]
Ebay account LOU840
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
