Old 01-02-2009, 06:27 PM   #1906
TeamCarnage's Avatar
Trader Rating: 23 (100%+)
Adam- Happy New Year!!! Pick a Sunday and come up to Underground! Your VTA and 12th scale will be great target practice...J/K Hope all is well! Nick
TeamCarnage is offline   Reply With Quote
Old 01-02-2009, 06:36 PM   #1907
Send a message via MSN to Adim_X
Hey Nick,
Long time no see. I would love to come up there and check it out. I have gotten bit by the onroad bug big time. Lafayette has dumped their dirtoval and now have a carpet track. I need to call ya sometime and say hello. We have a 5month old daughter now. Take care, Adam
Adim_X is offline   Reply With Quote
Old 01-02-2009, 09:17 PM   #1908
Tomradio's Avatar
Trader Rating: 25 (100%+)
Originally Posted by or8ital View Post
I updated my instructions post a bit (I edited the post). But here they are again. I forgot that the second folder that needed to be deleted was a hidden folder.
Here is what I needed to do to get it to work on Vista (32 bit version). I would only follow these instructions if you have a problem with it only showing the old versions of the firmware.
- Go to Control Panel
- Go to Programs and Features
- Highlight Tekin HotWire
- Click Uninstall
- Follow Uninstall Instructions
- Reboot
- Go to C:\Program Files and make sure the "Tekin Hotwire" folder has been removed. If not, delete the folder
- Do the following if you do not have "Show Hidden Files and Folders" enabled
- On the left hand side click "Classic View"
- Go to Folder Options
- Click on the View Tab
- Choose the "Show Hidden Files and Folders" radio button
- Click OK
- Go to C:\Users\[USERNAME]\AppData\Local\VirtualStore\Program Files replace [USERNAME] with your username and make sure the "Tekin Hotwire" folder has been removed (seems like it often doesn't with Vista). If it hasn't then delete the folder
- Install New Version
- If you enabled showing Hidden Files and Folders and no longer want them showing make sure to undo the changes above
Great help, thanks
Tomradio is offline   Reply With Quote
Old 01-03-2009, 11:36 AM   #1909
Rio
Rio's Avatar
Hi can anyone tell me if this is a good setup as i'm racing in the morning and don't fancy taking a laptop with me. I'm runnig an rs pro with a 13.5 orion vortex fdr is 4.93 and the speedo is set up with drag brake 4, brake strength 100, Neurtal width 10, throttle profile 5 and timing 70. I've got it in dula mod as i dont really understand the whole timing thing. I'm just a lowly club racer Any help would be most welcome oh and the track is fairly large
Rio is offline   Reply With Quote
Old 01-03-2009, 12:23 PM   #1910
I assume you have hotwire, that setup is pretty close, turn the limiter down to 90% and watch the temps.
When you get the new firmware that is coming out, it will be even faster.
DA_cookie_monst is offline   Reply With Quote
Old 01-03-2009, 02:39 PM   #1911
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default i hope some one can answer this
i have a trinity dual mode 13.5 heres my ? do i half to run it in dual mode or is it ok to run in senser mode im new to these dual motors and brushless as far as that goes thanks for info
CRC Gen XL / Xray 09 , t2r pro / CW sprint and CW rocket / Kyosho evolva m3 / Tekin rs / Futaba 4pks / Trinity / Dirtburners thanks Bill / 1/8th racers of Toledo / Trex chassi / Summit Race way / Stateline
LAZER SPEEDWAY where all else IS just a parking lot / Hobby Stop West Raceway
2056dennis is offline   Reply With Quote
Old 01-03-2009, 02:49 PM   #1912
Default you mean duo right?
you mean you have a 13.5 duo right? the blue can? in order for you to benefit from the boost you need to be in sensored only mode other wise the esc is only going off the timing of the motor. That is probably why your car was flat the other day as you said in your pm. start at ten degrees on the can and maybe 20 on the boost and gear down a couple of teeth and try it then adjust up or down from there. MAKE SURE YOU WATCH THE TEMP!
Tim
shaggy1 is offline   Reply With Quote
Old 01-03-2009, 02:53 PM   #1913
2056dennis's Avatar
Default motor
shaggy this will be the first time ive run the 13.5 ive been running a famton ion in the my 12th scale the 13.5 is in my gt car
Old 01-03-2009, 03:28 PM   #1914
You can run in either mode but the gearing will be different and you'll have less timing in hybrid mode. Also the brakes are a little weak in hybrid mode with the high wind motors like 13.5 and 17.5's.
I rolled at 2.40 at Riders last time I was there. You'll have to gear up if you run hybrid mode.
Fred_B is offline   Reply With Quote
Old 01-03-2009, 03:33 PM   #1915
2056dennis's Avatar
Default esc
ok thanks Fred just trying to get a starting point
Old 01-03-2009, 03:57 PM   #1916
Rio
Rio's Avatar
Yeah i've got the hot wire and the 189 update fingers crossed it'll be fast
Old 01-03-2009, 07:37 PM   #1917
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
On most 13.5's a good starting point is 25 to 30 degrees of motor timing/boost timing combined.
Timing is timing, either way you get there you'll be fine.
If you're looking to get the most of out the high turn sensored motors you should be in sensored only mode.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 01-03-2009, 08:01 PM   #1918
2056dennis's Avatar
Default help
thanks shaggy1 and fred and randy that helps alot time to play
Old 01-03-2009, 08:13 PM   #1919
jkirkwood's Avatar
When is the 189 version going to be released?
jkirkwood is offline   Reply With Quote
Old 01-03-2009, 08:38 PM   #1920
Hey guys,
I was just wondering can anybody tell me what is the advantage of running ceramic bearings in a brushless motor. I know this is a esc page, but I have a brushless texin motor(17.5). I heard it made more free, but some people told me otherwise. Can anyone help.
Shawn
Race Hard baby!
bucatl is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
