Old 01-09-2011, 05:49 PM   #19141
macdude's Avatar
Originally Posted by hairy View Post
Hey i'm just frustrated that I am having this big a problem with my ESC it has been going on since well before November.They replace each one with a brand new one and after several runs the Esc won't turn the motor over without Me having to spin the wheels and as soon as I let off it won't turn the motor over without having the spin the wheels by hand and when it stops in order to get the tires to turn over I have to spin the tires by hand and then the Esc will keep the power to the motor until i let it stop and then I have to spin the tires by hand to get it to run.
What motor? Does the sensor board check out? Does the motor spin freely without the controller attached to it? First thing I would do if your motor keeps frying your speed control is try another motor. Or at least pull the thing apart and make sure the windings aren't shorted out or got something else wrong with them. I have had a couple rotors shatter in my motors. The motors would still run just not that well as they were no complete failures. I have also had my rotors flake and the metal get stuck in the end bearing and seize the motor.
I have seen a lot of weirdness, but never have I seen multiple failures of speed control when there was nothing else wrong.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 01-09-2011, 05:57 PM   #19142
Geezatec's Avatar
I may have misread about the LED's. Version 198-207 works fine. anything high Ive had the same problem with 10.5 motors. You may have the Push brake set to high. For some reason on adjustmode LED 1 & 2 counter act each other Play with these modes and redo the Calibration of TX. I dont use push control anyway, I'd just turn it off push control. 3 times or 4 times they replace it. I get tired of it happenijng twice!!!
I don't know why it loosses the setting of mode, or looses calibration of TX. I just think an error on setting the modes, an forget what modes we set!!
Geezatec is offline   Reply With Quote
Old 01-09-2011, 05:57 PM   #19143
postoposto's Avatar
hello guys...,
weird thing happened to my rspro...:
with fully charged 50c lipo, 1st n 2nd lap was damn good n fast...
after that, the speedo seems to be very weak... poor range of torque output..
tried swap the motor but the same prob occurred....
any ideas guys?... plz help me....
***Kelab Kereta Kawalan Jauh Dungun (Reg. No.: 2137-10-TRG)***
>>>Welcome to Dungun Model Car Speedway (DMCS)!!!!<<<
postoposto is offline   Reply With Quote
Old 01-09-2011, 06:15 PM   #19144
macdude's Avatar
Originally Posted by postoposto View Post
hello guys...,
Recalibrate your radio to your ESC. Also check your sensor cable. If it becomes loose then the ESC will run the motor in sensorless mode and will feel exactly how you describe.
Old 01-09-2011, 06:21 PM   #19145
postoposto's Avatar
i've done that too.... but still.....
Old 01-09-2011, 06:59 PM   #19146
picco007's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Default v212 help please
Hey guys, I'm running 17.5 on a low traction asphalt track 130 foot straight, fairly open. Can someone point me in the right direction on setup for 212? There are many more settings that I don't understand. Thanks in advance
Ronnie
EA Motorsports
picco007 is offline   Reply With Quote
Old 01-09-2011, 07:05 PM   #19147
smilekt's Avatar
already try change another good lipo ?
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 01-09-2011, 07:06 PM   #19148
hairy's Avatar
Your right... I must be dreaming this problem,Thanks
MERLIN RACING
"He once ran a marathon because it was on his way"
Logic is a lost art!
You are defined in life by how you respond to defeat!
hairy is offline   Reply With Quote
Old 01-09-2011, 07:11 PM   #19149
postoposto's Avatar
a brand new 5000mah 50c fully charged was used + brand new brushless 10.5 as well..... and the problem temporarily solved everytime i reset the on/off switch...
Old 01-09-2011, 07:15 PM   #19150
Yazid_TA05-IFS's Avatar
Send a message via Yahoo to Yazid_TA05-IFS Send a message via Skype™ to Yazid_TA05-IFS
I experienced this kind of issue previously.. and I managed to narrow down the root cause which was due to the on/off switch having bad contact. Problem solved after I change the switch to the new switch. Maybe you can have a try to change the on/off switch and see if the problem go away...
Yazid_TA05-IFS is offline   Reply With Quote
Old 01-09-2011, 07:26 PM   #19151
postoposto's Avatar
ok, i'll try.... many thanks bro.....
Old 01-09-2011, 07:53 PM   #19152
HarryLeach's Avatar
Send a message via AIM to HarryLeach
Out of curiosity, can you post a picture of how your RS is installed in the car?
I've seen something similar before where chassis flex or vibration combined with something mounted very close to the sensor port was causing some very strange behavior.
The reason I ask is because you're getting 2-3 runs before this issue pops up, so I believe you when you say the motor and sensor wire is good, but there's still got to be an underlying cause here somewhere.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 01-09-2011, 08:30 PM   #19153
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Ronnie
tc/12th ?
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-09-2011, 08:49 PM   #19154
picco007's Avatar
Originally Posted by 20 SMOKE View Post
tc/12th ?
Sorry it is for TC.....Thanks
EA Motorsports
Old 01-09-2011, 09:00 PM   #19155
20 SMOKE's Avatar
40 timing boost
14 turbo
start 2-3k
end 15k
ramp 2
delay .15
0 motor
fdr 6.0
throttle 3
everything else to your feel
Jamie W
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
