Old 01-07-2011, 09:19 PM   #19111
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by mikeygar View Post
Randy,
I have a Tekin RS which I plan to use on my 1/12th with a 1s lipo. Does the motor turn limit still apply or can I safely use a 4.0/4.5T since I assume the ESC will be pulling less amperes? Searched but very little info on this topic.
Lastly, I can't seem to find the wiring diagram for the RS with a booster/RX pack. Do I just remove the red wire in the ESC's plug?
Thanks in advance!
yes it still applies to the motor turn limit.do you mean this diagram.switch on you have lipo cut off switch of you have no lipo cut of.
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-07-2011, 10:01 PM   #19112
pakk's Avatar
Trader Rating: 79 (100%+)
1s voltage+mod=more current.
I'm no electrical engineer, but that's what I remember.
For 1s mod applications, you need a RS PRO. I'd recommend a Pro for any sort of Mod racing.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 01-08-2011, 02:33 AM   #19113
MattFromSooke's Avatar
Send a message via Skype™ to MattFromSooke
hey guys,
i need a good starting point for a SP 13.5 V3 on 1S in WGT
6 Ps of racing: Proper Preperation Prevents Piss Poor Performance
MattFromSooke is offline   Reply With Quote
Old 01-08-2011, 07:19 AM   #19114
Tomorrow a big race. 53 drivers in the 13,5T tc class.
Today we had free practice runs. we all have 6 runs. the 3 fastest runs decide in witch group you qualify tomorrow.
I just finished my last run and I now now for sure that I'm in the A qualification group.
There are many GM and LRP drivers but the Tekin drivers dominated today.
One Tekin driver to go but he is just like all the other Tekin drivers by the best 10.
5 Tekin drivers with 2 Tekin combo drivers.
The A group list. Tekin 1, 2, 4, 5, and 9.
The Tekin combo on 1 and 2.
The other drivers are 3 GM's and 2 LRP's.
There are some BD and MMP drivers but they are in the C or even further down.
The lap times are close.
I hope that we get all the Tekin drivers in the A final tomorrow.
Some GM drivers came and look to my speedo. They were impressed.
I had a bit more infield rip than them. top speed the same.
I must go now.
as I have time I will place the Qualification and final results.
toptek is offline   Reply With Quote
Old 01-08-2011, 08:59 AM   #19115
mac853's Avatar
Questions??
Could somebody tell could i use another capacitor if i wonder to run in spec motor classes?
If is possible then which 1 to be recommended?
Best regards
mac853 is offline   Reply With Quote
Old 01-08-2011, 09:58 AM   #19116
20 SMOKE's Avatar
in a pinch you can run a 1000uf 16v but should run the stock one if you can order it
Jamie W
Old 01-08-2011, 12:14 PM   #19117
kakaroctt's Avatar
whats going to happen if i soldered an orca power boost directly to the motor phase?is it going to improve the performance?got to change any setting?or will it harm the rs pro?
LEGGERE LE ISTRUZIONI PRIMA DELL' USO !
kakaroctt is offline   Reply With Quote
Old 01-08-2011, 01:40 PM   #19118
mac853's Avatar
Questions??
Original 1?
Which stock number really is?
Best regards
Old 01-08-2011, 02:37 PM   #19119
20 SMOKE's Avatar
Originally Posted by mac853 View Post
Original 1?
Best regards
factory cap is 330
Jamie W
Old 01-08-2011, 07:33 PM   #19120
hairy's Avatar
Well it has happened again......this is the fourth ESC to fail on me since November. they have ALL failed the same way, The ESC lights up but will NOT turn over the motor unless you spin the wheels and then it runs ,but let off the trigger and it won't start the motor without a push. I am very very dissappointed.
MERLIN RACING
"He once ran a marathon because it was on his way"
Logic is a lost art!
You are defined in life by how you respond to defeat!
hairy is offline   Reply With Quote
Old 01-08-2011, 07:46 PM   #19121
el salvador's Avatar
Hairy, One question, was this with Version 212 firmware?
ARC R8 X2/ Max RP9 or O.S. R2101 ,Capricorn LAB C02-TOP Elite R, ARC R11....
"Every Cemetery in Chicago Votes Democrat!"
el salvador is offline   Reply With Quote
Old 01-08-2011, 08:13 PM   #19122
hairy's Avatar
yes v212
MERLIN RACING
Old 01-08-2011, 08:18 PM   #19123
rcko's Avatar
Trader Rating: 15 (100%+)
I have witness this happen to Hairy and was there tonight when this speedo went out. He would be running just perfect and the things just dies on him... this is TC 17.5 2s. Nothing special.
rcko is offline   Reply With Quote
Old 01-08-2011, 09:40 PM   #19124
mikeygar's Avatar
Trader Rating: 14 (100%+)
Originally Posted by stipres View Post
We use the RX pack and it is not necessary to remove the wire. Just keep the ESC's switch in the off position.
Thanks guys, teamtekin.com says 5.5t max for the RS so i guess I'll try that and the RX pack soon in my 12R5.1 .
mikeygar is offline   Reply With Quote
Old 01-08-2011, 09:51 PM   #19125
pakk's Avatar
Originally Posted by TrevCoult View Post
No it is not true.
Lower voltage = more current = same heat.
You need the RS Pro.
Trev
Originally Posted by Randy_Pike View Post
Trevor is correct. Less voltage means more current. For 1s mod racing you should be uisng the RS Pro. I've seen others use the RS for it and you "can" but it may thermal so testing would need to be done.
Took a minute, but I knew I read it on here some where.
*Photon* *SC10 4x4*
RCRD
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
