Tekin RS ESC sensored >
Old 01-06-2011, 06:41 PM
  #19096
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Originally Posted by RC MARKET
New arrived RS Pro updated new pcb & fet !
+3, or more - Don't know if this is a newbie question or what, but what are pcb, and fet's? Nothing on Tekin's or RC Market's website??? Is my new RS that arrived in the mail YESTERDAY now obsolete? Will be if it is!
Sith Lord is offline
Old 01-06-2011, 11:33 PM
  #19097
Questions??
Randy has to say about this?
higbo is offline
Old 01-07-2011, 03:10 AM
  #19098
dameetz's Avatar
Default Set-up for 10.5t
Where can I get set-up for RS-Pro with X12 10.5t motor? I ll be using this combo in a Tc car (TCX). My local track has long straights with technical infield.
Thanks.
dameetz is offline
Old 01-07-2011, 03:36 AM
  #19099
Skitee's Avatar
Thanks.
You can try something along these lines.
4 dot timing insert
Start RPM : around 6000
End RPM : around 21000
Boost : 45 to 48
Turbo : 10 to 12
Turbo Delay : 0.2
Turbo Ramp : 2
Min Drive : 10
Push Control : 0
Drag Brake : 5
FDR : 8.3 to 9.0
Skitee is offline
Old 01-07-2011, 04:32 AM
  #19100
dameetz's Avatar
4 dot timing insert
Boost : 45 to 48
Turbo : 10 to 12
Turbo Delay : 0.2
Turbo Ramp : 2
Min Drive : 10
Push Control : 0
Drag Brake : 5
FDR : 8.3 to 9.0
Thanks Skitee. Will try it out.
dameetz is offline
Old 01-07-2011, 11:02 AM
  #19101
syndr0me's Avatar
Trader Rating: 32 (100%+)
What's it mean if the ESC can't "see" the motor (the sensor LED's don't light) and the two LED's at each end of the bar flash?
syndr0me is offline
Old 01-07-2011, 11:27 AM
  #19102
PitNamedGordie's Avatar
I had this same issue with my last ESC...I'm supposed to send it in. I can't remember the technical term used but it had something to do with the ESC losing a phase...or something like that. Since it does not see three phases the ESC thinks you have a brushed motor connected, hence the 1,2,6,7 (wrong motor type warning) lights flashing. (Tekin please correct me if I'm wrong )
PitNamedGordie is offline
Old 01-07-2011, 12:41 PM
  #19103
syndr0me's Avatar
That's odd, considering it worked just fine before I put 212 on there.
syndr0me is offline
Old 01-07-2011, 01:20 PM
  #19104
bkspeedo's Avatar
have you tried reflashing the esc? you might even try flashing with an older version then again with 212.
bkspeedo is offline
Old 01-07-2011, 01:35 PM
  #19105
Team Tekin
Randy_Pike's Avatar
Led's 12 67 means the RS can't read a phase. This can be caused by the ABC motor wires, an open/shorted phase in the motor, or possibly something wrong internally with the esc.
Also on 1s there is one more possible cause. Insufficient BEC/Booster/Rx pack supply voltage.
Randy_Pike is offline
Old 01-07-2011, 01:43 PM
  #19106
higbo is offline
Old 01-07-2011, 01:59 PM
  #19107
BCbud's Avatar
Trader Rating: 37 (100%+)
Could you give us more info on this??????
BCbud is offline
Old 01-07-2011, 02:06 PM
  #19108
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
The silence on this subject is deafening.
Sounds like somebody let the cat out of the bag a wee bit early ?
RedBullFiXX is offline
Old 01-07-2011, 06:36 PM
  #19109
Trader Rating: 14 (100%+)
Randy,
I have a Tekin RS which I plan to use on my 1/12th with a 1s lipo. Does the motor turn limit still apply or can I safely use a 4.0/4.5T since I assume the ESC will be pulling less amperes? Searched but very little info on this topic.
Lastly, I can't seem to find the wiring diagram for the RS with a booster/RX pack. Do I just remove the red wire in the ESC's plug?
Thanks in advance!
mikeygar is offline
Old 01-07-2011, 07:10 PM
  #19110
stipres's Avatar
Trader Rating: 70 (100%+)
I had a motor wire come off at the solder joint. It gave the same code you are having. May want to double check...
Originally Posted by mikeygar
Randy,
Thanks in advance!
We use the RX pack and it is not necessary to remove the wire. Just keep the ESC's switch in the off position.
stipres is offline
