Old 01-03-2011, 05:48 PM   #19066
Originally Posted by yellowshark View Post
Personally with a 10.5 I would start with 10k-13k rpm and end 20K-25K rpm. What is best will depend on your motor and your motor timing
Sorry I should have added that is based on an FDR circa 8 and 64mm tyres
yellowshark is offline   Reply With Quote
Old 01-03-2011, 05:55 PM   #19067
Trader Rating: 19 (100%+)
Originally Posted by rcscoot2539 View Post
I am looking for some help, I am running 10.5 rubber touring for the first time and need a good starting point. The track is the gate at cleveland, I believe it's 80x40. Thanks for any and all info.
try this.
fdr:7.8- 8.0
boost:45
turbo:15
start rpm:5300
end rpm:22,500
turbo delay:.1
ramp:3.0
i run 15 clicks of drag brake on a similar sized indoor asphalt track with my 416x and seems to work, the gate being carpet maybe 20 or 25 drag brake.
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 01-04-2011, 04:19 PM   #19068
bit of a weird issue tonight, hooked up a graupner 17.5 motor to my tekin and it wouldn't switch on !
When I pulled the sensor cable to check, it powered up fine. It's a brand new motor and I changed the sensor board on it for one from a 21.5, but the same thing happened. I then put the 21.5 motor in and got the same result.
Changed over to a GM 17.5 instead and it all works fine now...
Anyone had this before ?
CPD Racing
chris_dono is offline   Reply With Quote
Old 01-04-2011, 04:52 PM   #19069
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Sounds like those sensor boards are shorted out.
Try a known good BL motor. IF it works, you know those are bad.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 01-04-2011, 11:32 PM   #19070
Graupner motors dont work with Tekins , same as Corally motors , there was something here in Holland with them at the start of the season in 2010 , we all took them out and used other motors
sidecarphil1 is offline   Reply With Quote
Old 01-05-2011, 01:44 AM   #19071
StevenOlsen's Avatar
+1 have tryed 6 grupners and only 1 that works with my tekin
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Old 01-05-2011, 02:33 AM   #19072
Thanks for that guys, looks like I'll be going back to the GM speedo after all...
They are both brand new and work fine on my GM speedo, I wanted to try the tekin again to see what it's like now on 212
CPD Racing
Old 01-05-2011, 04:29 AM   #19073
Trader Rating: 10 (92%+)
http://demonpowerproducts.co.uk/prod...oducts_id=5797
captain stacker is offline   Reply With Quote
Old 01-05-2011, 05:05 AM   #19074
1M
1M's Avatar
Trader Rating: 35 (100%+)
Says on the listing "does not work with TEKIN"
1M is online now   Reply With Quote
Old 01-05-2011, 06:58 AM   #19075
RC MARKET's Avatar
New arrived RS Pro updated new pcb & fet !
RC MARKET is offline   Reply With Quote
Old 01-05-2011, 07:35 AM   #19076
I realise that now, I'm more interested in "why" though
CPD Racing
Old 01-05-2011, 07:41 AM   #19077
I have a GM speedo but I only run the Tekin RS Pro now.
The speedo is as fast as the GM but it runs better.
I tested some GM motors with the Tekin and they run verry good. The Groupner motor will not run with the current sensor in it. You can change it but you need to now what to do.
A club member changed it and I tried the motor on the Tekin and now it runs fine.
Still I like the Tekin motors more.
The GM runs good with a GM or Graupner motor but I didn like the feel as I like the feel of the Tekin combo.
Before I had a Tekin RS Pro, I burnt up my Graupner motor to get the same lap times.
I drove most of the time with the GM motor. worked better for me.
When I got the Tekin, I sold my GM and Graupner motors and bought some Tekin motors. Tried the 13,5T Tekin motor and I switched to them. They also run great under the GM speedo. great speeds.
toptek is offline   Reply With Quote
Old 01-05-2011, 07:46 AM   #19078
The temp part is on a sensor that gives a wrong signal to the Tekin speedo.
this is what a club member told me. He changed it.
Don ask me how.
Randy can Tekin change the software on the speedo so that you can use the Graupner motor and also see the motor temp? Or does it work on an other way?
My club member didn't now if it was possible.
Old 01-05-2011, 07:49 AM   #19079
jammincrtjames's Avatar
NEXUS RACING www.nexusracing.com | FANTOM RACING www.fantomracing.com
ORCA www.orcarc.com | TURTLE TRAX / www.turtletraxraceway.com
"If you're not first...you're last!"
jammincrtjames is offline   Reply With Quote
Old 01-05-2011, 08:02 AM   #19080
Originally Posted by jammincrtjames View Post
+1
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
