Old 12-24-2010, 10:28 AM   #19006
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by tc3team View Post
+1
Everyone has a different way of managing the power, some like a short burst of power through a minimal rpm range, (aggressive) others prefer to smooth it out over several K rpm, there is no "right or wrong" setting
Obviously esc settings can be dependant on grip levels too.
As long as the motor is geared right for the track and therefore not hot after a run, it's all good....
Great minds think alike
STLNLST is offline   Reply With Quote
Old 12-24-2010, 11:12 AM   #19007
Trader Rating: 19 (100%+)
Hi guys, can anybody help me with a mod touring setup for a ballistic 7.5 on a snowbirds dize track?
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 12-24-2010, 11:51 AM   #19008
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
http://www.teamtekin.com/hotwire/ESC...d-7-5-v203.pdf
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 12-26-2010, 09:31 AM   #19009
Originally Posted by 2wdrive View Post
Just curious if you felt any fading after a few minutes or did it stay constant throughout the 5 minute run? Did you use a fan on the motor?
I am not sure if that setup works on the MACH outdoors but i will try that setup on the indoortrack next time
no fading!
i run the same setup on Megadrom in geilenkirchen, Germany
awesome speeds, no fading.
i even use these weak 30C 4200mah batteries of 18 euro from HK, too cheap to be true, little less power than 40C 5000mah batts but enough to keep up with the pack. also with the 40C batts i dont get high temperatures. I might try to lower the end rpm to get even more speed as you say it wont even reach full timing. i run 8.0 gearing so and i do hear some screaming down the back straight so it might just reach alot of rpms there...
Markiempje is offline   Reply With Quote
Old 12-26-2010, 09:59 AM   #19010
Dragula426's Avatar
+1
X3 on that one. I have found in off road, I prefer the smooth powerband over a long rpm range so I don't get that burst just as I hit the jump. In dirt oval, indoors anyways, I will raise the lower rpm range and lower the upper for a huge jump in speed when the throttle is pulled. Its all driver preference!!!
Team Tekin
Jeffery Racing Concepts
Little 'O' Speedway
Extreme Graffix
Dragula426 is offline   Reply With Quote
Old 12-27-2010, 03:12 AM   #19011
Big Midget's Avatar
Trader Rating: 100 (100%+)
sorry to interrupt guys....just got a quick question. Has anyone put a ''Y" connector off they're speed control lead? So you dont have to disconnect it from the rx every time to make adjustments using your Hot wire......
UltralineHobbies.com
Ultraline Raceway Topeka Ks
Dee & Mee Hobbies RickyRacer Lidz,Absolute Tattoo,Fuzzy Dice Decals
Big Midget is offline   Reply With Quote
Old 12-27-2010, 03:27 AM   #19012
pakk's Avatar
Trader Rating: 79 (100%+)
Yeah, it doesn't work. It has to be disconnected from the RX for some reason. Another option is to just put a 1" extension. Makes it a lot easier and you able to grip the plastic connector.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 12-27-2010, 06:16 AM   #19013
Buckaroo's Avatar
Doesn't work. Puts the reciever in parallel with the computer and the ESC, messing up the signal.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 12-27-2010, 06:24 AM   #19014
WIITA's Avatar
Trader Rating: 42 (100%+)
Buy a 3" servo extension. Plug it in and shoe goo then female end somewhere else that is easy to get to. I rum mine on the top of the servo. This makes changes so easy.
Team CRC / Sanwa / Team scream / Genesis RC / Hobbywing / TQ Wire / Schelle / MIP / RC^2 / TEKNO / BoomRC
WIITA is offline   Reply With Quote
Old 12-27-2010, 07:59 AM   #19015
Big Midget's Avatar
I never thought of using an extension....
Thanks for the heads up suggestions
Old 12-27-2010, 08:22 AM   #19016
tc3team's Avatar
im an agressive racer with the throttle (too many years racing 27t!) so I will typically have a narrow rpm band, which is highlighted also by racing on a 10x15m carpet track, I want POWER out the corners!
But, on the other end of the scale, ive enjoyed using dual drive, yes even with 13.5. with a few tweaks it could be just as fast as sensored drive, if not faster.
Like we all agree guys, power is one element, controlling it is quite another.
Even on the g11pro, I never used max power, i used it at 90% to preserve brush and comm wear in the 27t class, with no noticable drop in performance.
Great conversation guys
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 12-28-2010, 02:17 PM   #19017
warnos's Avatar
Default timing
Anyone know what the far left slidder does on the timing tab for hotwire 212 in sensored mode?
There are the two usual turbo and boost slidders then there is the rpm range.. but I noticed on the far left kinda in the back ground.. there is a third slidder called timing advance which has a range from 0-100 anyone know what this does.. by default I think its on 80.. I have moved it around up to 100 down to 50 but cannot seem to notice a difference..
Cheers
Warnos
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 12-28-2010, 02:28 PM   #19018
M-Technic's Avatar
Trader Rating: 15 (100%+)
Cheers
Warnos
That is the timing advance for when you are running in dual mode. In sensored mode it does nothing unless you lose your sensor during a run and it switches to dual mode.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 12-28-2010, 02:59 PM   #19019
20 SMOKE's Avatar
leave it on 100 that way you have 30* if you loose the sensor wire
Jamie W
Old 12-28-2010, 03:13 PM   #19020
rayhoe1's Avatar
yep yep and it does happen!
rayhoe1 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
