Old 12-22-2010, 07:59 PM   #18991
pakk's Avatar
Trader Rating: 79 (100%+)
Start and end RPM set when your boost will start and end. So if you set you boost to 50 start and 1000 and end and 10000, the esc will start adding timing at 1000rpm and by the time you hit 10000 rpm you will have 50 degrees of timing. That timing will hold at 50 as long as you stay at or above 10000 rpm.
Turbo is time based. If you set your turbo to 10 and .5 delay, after .5sec of full throttle, the ESC will begin to add timing till it hits 10degrees. How fast it gets to 10degrees will depend on your ramp rate. This timing will hold as long as you hold full throttle.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 12-22-2010, 08:04 PM   #18992
postoposto's Avatar
cool..... thanks pakk!!..... i traveled away from Malaysia for this... thanks again bro...
***Kelab Kereta Kawalan Jauh Dungun (Reg. No.: 2137-10-TRG)***
>>>Welcome to Dungun Model Car Speedway (DMCS)!!!!<<<
postoposto is offline   Reply With Quote
Old 12-23-2010, 07:56 PM   #18993
Hey guys,
can anyone help me with TITC sp 11.5 set-up?
thanks
boyangus is offline   Reply With Quote
Old 12-23-2010, 08:10 PM   #18994
hairy's Avatar
Great info, Question: What is a good spread on start and end RPM on a touring car w/17.5? The track has a 70ft straight, on carpet.
MERLIN RACING
"He once ran a marathon because it was on his way"
Logic is a lost art!
You are defined in life by how you respond to defeat!
hairy is offline   Reply With Quote
Old 12-23-2010, 08:14 PM   #18995
pakk's Avatar
To be conservative, I'd go 5k 15k with about 45 then adjust from there. There are a lot of setups on Tekins site from their team drivers.
*Photon* *SC10 4x4*
RCRD
Old 12-23-2010, 08:18 PM   #18996
hairy's Avatar
Thank you
MERLIN RACING
Old 12-23-2010, 09:53 PM   #18997
STLNLST's Avatar
Trader Rating: 21 (100%+)
What brand 17.5 are you using? The funny thing I'm seeing is that everyone has a different driving style and start and end RPM'S are all over the place. What has worked for me personally has been a start of about 2,500 and an end of 9,500. I do plan on trying a start of 5,000 and an end of 20,000 with all of my other settings the same. I've run this on small tracks and large tracks. I have been running off road lately and feel it's taught me how to better tune my sedan because I have been able to adjust the settings for traction rather than for raw power. What settings are you currently running?
STLNLST is offline   Reply With Quote
Old 12-23-2010, 10:36 PM   #18998
hairy's Avatar
I'm running a LRP X-12 17.5, I have been running the 4k to 10k range on the RPM's and 50 boost. Just curious what everyone else thinks.
MERLIN RACING
Old 12-24-2010, 12:25 AM   #18999
STLNLST's Avatar
45 Boost for me but now with 212 I play with the min throtle as well.
Old 12-24-2010, 04:31 AM   #19000
tc3team's Avatar
+1
Everyone has a different way of managing the power, some like a short burst of power through a minimal rpm range, (aggressive) others prefer to smooth it out over several K rpm, there is no "right or wrong" setting
Obviously esc settings can be dependant on grip levels too.
As long as the motor is geared right for the track and therefore not hot after a run, it's all good....
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 12-24-2010, 06:17 AM   #19001
raced last weekend with my TRF416,
x11 10.5 geared at 8.0 timed 25deg
All timing options full open, boost 55, 5k-15k, turbo 20, 0.25s
had inmense amounts of power and brakes! absoulutely rocking! motor got 65deg C after 5 minutes and 75 after 10. it was like driving a modified motor! love the scream at the back straight of 20meters
Markiempje is offline   Reply With Quote
Old 12-24-2010, 06:25 AM   #19002
all open?
toptek is offline   Reply With Quote
Old 12-24-2010, 09:34 AM   #19003
StevenOlsen's Avatar
i have been running a SP 9,5 geared around 7.5 with boost 50, 34xx-1000, turbo 20, 0,00 delay the motor came off around 75 deg. C after 6 min
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Old 12-24-2010, 09:54 AM   #19004
2wdrive's Avatar
Just curious if you felt any fading after a few minutes or did it stay constant throughout the 5 minute run? Did you use a fan on the motor?
I am not sure if that setup works on the MACH outdoors but i will try that setup on the indoortrack next time
2wdrive is offline   Reply With Quote
Old 12-24-2010, 09:59 AM   #19005
on small tracks it will work because you never have full timing.
i think that a lower end rpm with a lower boost and turbo will get the same speeds.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
