Old 12-20-2010, 09:59 AM   #18976
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by trackermi View Post
It is a B4.1 Buggy. I had the posts pointing towards the front of the car and the wires going back. The T4 and B4 both have the ESC in the same position but on the T4 the posts are outwards.
It was literally slapp the hill and then lights out instantly. But had steering. the ESC is pretty much gone outside of providing power to the other electronics. My truck has never done this before so I want to make sure its not a weakness of the ESC or if something else may be wrong.
But the posts and the esc is clear from other objects. Unless the wires routing over the top can cause the issue.
The RS rarely fails due to vibration or impacts. When the unit powers up what led's are shown?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 12-20-2010, 10:00 AM   #18977
Team Tekin
Randy_Pike's Avatar
Originally Posted by AiR2k View Post
I run Durango DEX410 with Tekin RS Pro and Speed Passion Comp V3 6.5t.
Speedo and motor gets too hot in 10 mins when running offroad indoors. Now I'm looking for a solution to make them run cooler and found this message by RC MARKET. Did Tekin actually release alu case?
Durango is really harsh for speedos 'cause of it's weight, gear diffs and tight fittings. Anyway I'm really happy with RS Pro and would like to use this in future too.
We need setup info from the esc, motor timing and what gearing you're running?
Old 12-20-2010, 06:01 PM   #18978
No lights.. All of them Re out.
The first was a tekin rs pro. Sent it back paid 100$ got a new one. Then in the mean time got a tekin rs to hold me over. I ran stock as I wanted to watch ryan caveleiri race at the track.. No issues that day at all. Switch back to the 10.5 motor and 4 laps out slapped the hill and same thing different esc.. All lights out rig after hitting the landing wrong. Same exact spot as the other esc. I hope it gets warrantied as it's literally 2 weeks old. But more so need to figure it out. The have always bee good escs.
Facts.. Both esc all lights out. No hookup to pc. Nothing.. But have steering
Both I b4 buggy and quit upon the jump on the track.
Both with using a fanton 10.5 motor. It's an ion3 version.
Aldo I the motor was checked out and itstill works. So I am Los for what's going on.
trackermi is offline   Reply With Quote
Old 12-20-2010, 07:05 PM   #18979
cannon's Avatar
Trader Rating: 35 (100%+)
Have you checked that the receiver is not playing up. The impact might be cutting the signal from the receiver
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 12-20-2010, 07:43 PM   #18980
Not really.. How do I check it cause it binds fine,works fine and wouldn't the esc have at least a light or a noise or something. Were talking all esc lights.
The weird thing is power is cycling through as the steering works.
Even my transponder lights up. Just not the esc.
I never lost steering the whole time. Just all motor power is gone and esc is taking a coffee break.
I even put the esc on my truck and same results.
The radio equipment is all new in November. All airtronics m11x stuff. And after replacing the esc it all works again.
I would have to believe the power input side is ok as it's still powering up the steering, receiver and transponder. Maybe something in the motor or output side it get whacked when it hits the ground.
But two esc and one rs pro and one rs.. I am about to cry..lol
I love these escs so I am not changing.. We just need to figure this out..
I am going to go rip my motor Part real quick..
Old 12-20-2010, 09:16 PM   #18981
Well the motor didn't turn up anything. It's a rather new ion3 and the solder tabs are still in place, copper winding looks fine. Not sure..
Maybe I should just replace the battery and motor also. I like my esc more than them both anyways.
Randy have any thoughts on this. Pm me if you want.
Thanks.
Old 12-21-2010, 11:20 AM   #18982
Team Tekin
Randy_Pike's Avatar
I would like you to turn the unit on AFTER unplugging the sensor harness and the esc from the receiver.
I want to know if the esc powers up with led's.
Old 12-21-2010, 11:41 AM   #18983
Kenny L's Avatar
Trader Rating: 16 (100%+)
Or try firing it up with out b wire on it. Sounds to me you have bad motor wind and its blowing out B phase of esc
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 12-21-2010, 12:12 PM   #18984
I will try that tonight. I did unplug it from the receiver once to see if I could connect via hot-wire.. That failed and no lights came on then. But I will give it a shot.
I will replace the motor just in case. But both times it was a chassis slap that started so it could be something not visually I can see with the motor. Not sure...
Old 12-21-2010, 02:01 PM   #18985
Have you checked the receiver plug on the esc has all the terminals in place? I found after 3 years of using my RS I had the signal wire just working loose so I put on new terminals and all was good
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 12-21-2010, 06:32 PM   #18986
Trader Rating: 77 (100%+)
Default ESC set up help
Any recomendations to start out at.
Running B4. indoor smooth clay (WCRC)
81/22 gearing
Novak 17.5 ballistic motor
goin2drt is offline   Reply With Quote
Old 12-21-2010, 07:59 PM   #18987
I soldered the leads on connected it, flipped the switch and nothing. Sensor wire off. All lights off and no startup noise.
Plugged the receiver back in and the receiver,servo and transponder all came to life. Nothing else.
The esc is two weeks old and I am sure the connections are fine. I just bought the entire setup last month all brand new. Regardless I am pitching the motor and battery just to be safe.
Old 12-21-2010, 08:01 PM   #18988
Team Tekin
Randy_Pike's Avatar
Sorry to hear that. If you've done what I've asked sounds like it needs repair.
Hit me up for an RA# or the tech guys online at our website.
Old 12-21-2010, 08:24 PM   #18989
Thanks. I will send an email tomorrow. I have three tekins so I am set till this one comes back.
Also I got an add showing some new tekin motors.. When are those things coming out. They look awesome.
Old 12-22-2010, 07:41 PM   #18990
postoposto's Avatar
good day guys...
just bought my RSPro with 212 updated... but still blur with the throttle setting..
can somebody plz redefine the 'end RPM', 'start RPM', turbo/ boost setting?
currently using LRP 9.5 on a 60 meters straight line local track...
Thanks.... cheers
***Kelab Kereta Kawalan Jauh Dungun (Reg. No.: 2137-10-TRG)***
>>>Welcome to Dungun Model Car Speedway (DMCS)!!!!<<<
postoposto is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
