Old 12-16-2010, 09:11 AM   #18946
Victory Side's Avatar
Send a message via Skype™ to Victory Side
I have it set at 30. On this new Ballistic they have 15-30-45 instead of - N +. I have not touched the timing of this motor. I bought it and stuck it in. I have 2 RS's programmed exactly the same and one wont run the ballistic and the other will. I have caps on both esc's. I is just weird. Just trying to figure out what is going on. Any other suggestions appreciated
WWW.RICHFIELDRACEWAY.COM
"There are only two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle." ~Albert Einstein
"Do you want to know who you are? Don't ask. Act! Action will delineate and define you.'
Victory Side is offline   Reply With Quote
Old 12-16-2010, 10:53 AM   #18947
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Chances are you've got a sensor issue somewhere. My first suggestion is to swap the motors between the two cars and see if the issue follows the motor or stays with the car.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 12-16-2010, 11:22 AM   #18948
speedybill's Avatar
Trader Rating: 73 (100%+)
Wink
I have had several issues with the Ballsitics
They seem to be difficult to get Sensor wire in motor correctly unless you take your time, also I ALWAYS change to a softer sensor wire
Thankx, Bill
ROAR member #5-120259
www.speedybillsrc.com
www.ovrccc.com
Sweep Racing Tires
speedybill is offline   Reply With Quote
Old 12-16-2010, 05:21 PM   #18949
j86
Question regarding ESC Turbo and Motor Timing AND temperatures:
Are these the usual steps you guys usually use to find the right motor temps/speed?
1. Gearing
2. Adjust motor timing (endbell) and/or ESC turbo/boost
3. Gear up (lower FDR #) if your ESC Turbo/Boost settings > 50 + motor temps are still cold
Mainly concerned about #2, do you leave motor timing at 0 then adjust ESC or first adjust motor timing?
This is for a DUO 1/2/3
TIA
j86 is offline   Reply With Quote
Old 12-16-2010, 05:46 PM   #18950
Start with the Boost and gearing to find a good infield speed.
later ad the Turbo for the top speed.
toptek is offline   Reply With Quote
Old 12-16-2010, 06:11 PM   #18951
j86
start with 0 mechanical timing on motor and then add it after? or start with a few notches?
Using a DUO1/3
Old 12-16-2010, 08:18 PM   #18952
That is what I did. I took the novak ss 17.5 out of my one TC and put it in the other TC that had the Ballistic in it. I put the Ballistic in the TC that had the SS and it worked as did the SS worked in the other car. For now I am just leaving them the way they are.
I had tried many others motors as well with simular results with just this one esc. All my other rs's had no issues. Thanks for the help and I love my Tekins.
Old 12-17-2010, 12:06 AM   #18953
marksp's Avatar
Trader Rating: 28 (100%+)
Default V212 ROAR approved Spec profile
How do you select the new ROAR spec profile in Hotwire v5?
I approve of this message
OMS Racing
marksp is offline   Reply With Quote
Old 12-17-2010, 12:13 AM   #18954
pakk's Avatar
Trader Rating: 79 (100%+)
I think you mean non ramping profile? Just put it in profile 1.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 12-17-2010, 08:58 AM   #18955
marksp's Avatar
Thanks. I saw this for v208, but it mentioned blinky center light. v212 mentions blinky lights 3 & 5 and I can't find the v212 manual so wasn't certain. Thanks for your help.
OMS Racing
Old 12-17-2010, 03:58 PM   #18956
look what works the best with the motor.
play with the motor timing to find the best setting for the motor.
I run Tekin, LRP X11 and SPv3 motors.
The Tekin works great with 0 to 10 timing. higher than that causes a lot of head.
The lrp is a spec motor so I never change the timing.
The SPv3 I always run on max timing. As you set it lower, than you have no power. The timing on max on this motor is the only timing I use.
On the Tekin I use a timing of 4 to 10 on larger tracks. On smaller tracks I use 0 to 6 timing on the motor.
Using a DUO1/3
it is the same.
it is 0 timing setting. for stock racing were no timing on the speedo is allowed.
Old 12-17-2010, 06:13 PM   #18957
pakk's Avatar
Yeah, they blink differently. 208 would blink the center light. 212 blinks two lights. I can't say for certain what number lights they are, but it is two lights. You'll also know that you are in the correct profile when you're in hotwire by seeing that all the timing controls have been disabled.
*Photon* *SC10 4x4*
RCRD
Old 12-17-2010, 07:44 PM   #18958
marksp's Avatar
roger that. thanks
OMS Racing
Old 12-17-2010, 08:52 PM   #18959
Spec profile indicated by led's #3 and #5 flashing.
John Warner is offline   Reply With Quote
Old 12-18-2010, 06:15 AM   #18960
kuruption's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to kuruption
Hey guys,
I was trying to setup an RS Pro last night to run Brushed FW-Only w/ Lipo. I had it wired up (ABC to negative on the motor, shared B+) and everytime I put the ESC into calibration mode it would blow the cap. Did this three times.
I'm running 212. Happened with the motor connected and disconnected. Tried to do a factory reset, ensured the ESC was setup for Brushed FW-Only and the LiPo cutoff was working, etc etc. The cap would just blow everytime I tried to calibrate my endpoints.
Was hoping someone would have a clue as to what the issue is.
Thanks!
Ray Sundland
Eat. Sleep. Race. Repeat.
"Feel not as though it is a sphere we live on, rather an infinite plane which has the illusion of leading yourself back to a point of origin."
kuruption is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
