Tekin RS ESC sensored
My speedo has a problem......When i pull the trigger it will not take off, you can hear it making a noise and the led's light up ,but will not take off.
I can spin the gear and it will run as long as the gear is turning everything is fine.
I have tried three other motors and different sensor cables to no effect. I have un soldered and resoldered the wires from the battery to the speedo and from the speedo to the motor,no change!
Does any one know what is wrong!
It came off the track from an eventless run and when I went back out this happened.
Is it something in the software or settings that is causing this issue.
Any help would be greatly appreciated!
I have it set at 30. On this new Ballistic they have 15-30-45 instead of - N +. I have not touched the timing of this motor. I bought it and stuck it in. I have 2 RS's programmed exactly the same and one wont run the ballistic and the other will.
My dad and I are having the same issue. I purchased a RS ESC for my 1/10 WGT and download the 212 software. I ran the car the weekend before last with a brand new out of the box 13.5 motor for 3 practice runs, 3 qualifiers and the main. Everything worked awesome, when I went back to the track to practice the next week after not touching the car since the week before it started having issues. The car will not move unless you give the car a push, once it is moving it is fine. We tried resetting the ESC, reinstalled the software, I tried 4 new sensor wires and we even put a new sensor in the motor and after all that it still wouldn't work. I placed a new motor in the car and it works fine with the same ESC and setup. My dad also downloaded the 212 software to his RS ESC and his motor is doing the same thing. We had two different brands of motor in our cars. His car, motor and ESC worked fine until he downloaded the software.
Help please. I am new to 12th scale and am trying to hook up my electronics. I have a 1 cell lipo and a receiver pack life 200mah 6.6v it came with futaba plug on it to go into my receiver but do I need a switch for this or can I just plug and unplug as needed? What switch would I need? pics would help thank you. I am sure this is somewhere on here but can not find it.
Sounds like what happened to me when I upgraded to 212. Reset my Eurus and all was good.
Bill
Help please. I've ploughed thru'20 pages looking for the cap value and it didn't show. Mine broke a leg and the hobbyshop don't got one on the shelf, so I need to get something from the Shack !!
Help me please.
Jacko
Help me please.
Jacko
TT3522 16v 1000uF all units (2)
Good one!
