Old 12-09-2010, 02:04 PM   #18871
Regional Moderator
CarbonJoe's Avatar
Originally Posted by Jim_1987 View Post
I'm new to the programable speed controllers, any advice for a good starting point for 13.5?
Another question, is it best to run a wide rpm range 5k to 20k or 5k to 10k? What are the advantages of each one?
Is this 2s LiPo or 1s LiPo?
The bigger the RPM range, the smoother the motor builds "boost", and generally adds less heat than adding boost quicker. The flip side is that some people like the "punch" of adding timing over a smaller range. If you are running 1s LiPo, the smaller RPM range would be recommended, since you may not see the higher RPMs with half the voltage. It also depends on track size.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 12-09-2010, 02:23 PM   #18872
goBezerk's Avatar
Send a message via Skype™ to goBezerk
Originally Posted by M-Technic View Post
I'm running 20 push. It helped but its still there. I think push only activates if you go all the way to neutral.
For me, when faced with the same problem, I found the settings to not be the cause. I found the FDR made the biggest difference. I went from around 6.7 to 4.8 and it transformed it. You have to redo your rpm range to suit the harder gearing but my lap times dropped, were more consistent, motor came off at the same temp and the huge slowing in the sweepers disappeared.
Hope that helps.
► Paul Sims - KRCORCC - BRCCC - TFTR
► R/C racin', 1 percent car, 99 percent driver
► BEZERK RC on Facebook, PayPal accepted
► PROLINE - TEAM AE - GFORCE - R/C Race Supplies
goBezerk is offline   Reply With Quote
Old 12-09-2010, 02:33 PM   #18873
M-Technic's Avatar
Trader Rating: 15 (100%+)
Hope that helps.
Yes, I agree with you. I usually run one of the heavier FDR's at our track. I know that the extra torque of a lighter FDR can make that drag brake feeling worse. I should go back up a few teeth. I kept dropping it because of heat last time, but it feels a lot smoother with a heavier FDR.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 12-09-2010, 02:46 PM   #18874
Jim_1987's Avatar
I will be using 2s lipo in 13.5 TC class. I will post my initial setup later. Thanks
Jim_1987 is offline   Reply With Quote
Old 12-09-2010, 02:53 PM   #18875
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
look over this,it is a how to and a very helpful guide on the rs http://redirectingat.com/?id=42X1295...%23post8320117
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 12-09-2010, 03:19 PM   #18876
goBezerk's Avatar
If it warms up, just drop the boost a tad and leave the turbo alone. I also find with the heavier gear you don't need much boost in the low to mid sections, really just the turbo to keep the acceleration going on the straightaways...
Old 12-10-2010, 04:38 PM   #18877
Originally Posted by ShadowAu View Post
I am curious to know if anyone else had/has cogging/hesitation issues with 208 vs 203?...
I've been away from rc for a few months but my last race meeting was using 208 software but I found it had issues when accelerating out of corners with hesitation/cogging... I went back to 203 and using the EXACT same settings and gearing, the problem disappears... I know 212 is out now but haven't had a chance to try it yet
Yup we had a very similar issue. It would hesitate at the start also. Couldn't figure it at the track but when I got home I did a factory reset and that fixed it. Never happened before or since
yellowshark is offline   Reply With Quote
Old 12-10-2010, 08:37 PM   #18878
guinnes.s's Avatar
is it normal that the TURBO DELAY goes up or down in step of 0.05 , 0.10, 0.15 and so on.
thanx
guinnes.s is offline   Reply With Quote
Old 12-10-2010, 08:38 PM   #18879
20 SMOKE's Avatar
thanx
thats normal
Jamie W
Old 12-10-2010, 10:36 PM   #18880
Team-RTR's Avatar
hi guys, after a starting point setup for a LRP X11 3.5 running an RS Pro on a large track with a 50m straight. have never run mod brushless before so a good starting point on gearing and timing advance etc. would be greatly appreciated. i have also been told that these motors are relatively fragile and crappy so im not to interested in pushing it to its limits, im just after a conservative gearing/timing setup that wont destroy the motor in 3 runs.
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 12-12-2010, 09:18 AM   #18881
duggyload's Avatar
Hi guys Just a question
I am running a x12 17.5 at the moment and it runs super fast
But i will be keeping this motor for nationals only
I bought a novak ballistic 17.5 left the same settings as the x12 and car was slow then i turned the motor timing to max and the motor came alive but to hot . i then turned the motor timing back to zero and went up on the speedo to timing 50 . The temp came down but not as good as before
My question : Where is the best place to add timing, on the motor or on the speedo. And what is the timing on a ballistic at 0 deg i heard that the x12 is 30deg with a 4dot insert
Thanks in advance
duggyload is offline   Reply With Quote
Old 12-12-2010, 10:20 AM   #18882
Randy posted a aetup for a 4,5T a few pages back. I tried it and it works great. Lower the boost a bit abd gear a bid lighter.
It is fast!!!
I think that a 3,5 will be overkill.
Thanks in advance
comebine the motor timing and the speedo timing.
what do you miss with the motor on 0 timing?
post also your setup.
Raced today.
Spot 1 till 3 were after qualyfication for the 3 Tekin drivers. (2 Tekin drivers and 1 that used my second speedo)
He was first using a Speedpassion but he came power to short so he asked iff he could use my speedo.
The finals were again Tekin all the way. First head 1, 2 and 4. the nr 2 driver made a mistake and he was after 3 laps 10th.
He drove back to 4th and almost 3rd place.
second finall 1, 2 and 3 for Tekin.
Last final I put my self ad the back of the starting grid. I won all races so I'm nr 1 overall. notting to loose.
I became 3rd. The other 2 Tekin drivers lapt me almost.
again Tekin 1, 2 and 3.
The nr 4 and 5 were normally my biggest rivals but with a GM and a LRP speedo they are no match any more. They are ordering now a Tekin RS speedo.
This was my setup.
Boost 50
Turbo 7 delay 0 ramp 2
Start RPM ~7000
End RPM 10000
Throttle profile 5
Throttle min 15
Brake 80
Brake min 10
neutral with 0
motor timing 4 (tekin redline 13,5)
6.5 FDR
toptek is offline   Reply With Quote
Old 12-12-2010, 01:47 PM   #18883
Jim_1987's Avatar
Default Setup help
I used my tekin rs pro today at my local race meeting, very happy with the controller. It had good speed through the infield but lack some speed down the straight. Here are the settings I used for the final run, the motor was only 35C after 5 minute run!
Boost 35
Turbo 10
Ramp 2 with 0.12 delay
Start 4748 and finish 13009
Motor X12 with 0000 insert
Gearing 8.01
Carpet Track 30m by 15m
Can somebody offer a little more advice how I can improve the speed down the straight and a little more speed in the infield.
Old 12-12-2010, 02:11 PM   #18884
NTS
Boost 35
Turbo 10
Gearing 8.01
Your FDR is quite high, 7.5 is more typical at our track (also 30 x 15) and you can probably go Boost 40 or 45 as you are currently running very cool. Both will help with top end speed.
NTS is offline   Reply With Quote
Old 12-12-2010, 02:34 PM   #18885
jammincrtjames's Avatar
Can carpet static cause issues with the Tekin? Meaning 1,2, 6,7 lights.
NEXUS RACING www.nexusracing.com | FANTOM RACING www.fantomracing.com
ORCA www.orcarc.com | TURTLE TRAX / www.turtletraxraceway.com
"If you're not first...you're last!"
jammincrtjames is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
