Old 12-08-2010, 06:59 PM   #18841
RacinJ's Avatar
Originally Posted by Randy_Pike View Post
The new Redline Gen 2 motors are still being tested.
In that picture there is also the new micro motor(s) as well as the Roc412 crawling motor.
Are you going to have any 1S (1/12th or WGT) offerings? Motors? Rotors?
Roche P12 '16 & '17; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is offline   Reply With Quote
Old 12-08-2010, 07:01 PM   #18842
I hope that they will come also. 'm going to race 1:12 also.
toptek is offline   Reply With Quote
Old 12-08-2010, 07:48 PM   #18843
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
It'd be nice if more motor companies would use low profile tabs to solder the wires on.
Some 12th scale bodies fit much better with the LRP motors.
Aside from that, the new stuff looks good
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-09-2010, 06:02 AM   #18844
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Default need some ideas.
i know this is onroad, but i have a freinds Shumacher Couger 4x4.
i put in my reciever, and up loaded V212. played with the settings, and then used it. was fine. i then have charged the battery tonight, and used it. i have since recharged, to see what i used. a 50C 5000mah pack, it took 2120 mah to fully charge it again.
problem was, i was trying some different car setup settings, just out the front, and it was a bullet, like the previous night. i braught it to a stop, had a look at the Leds, and only 2 were lighting up for heat. motor was warm, not hot.
so i slowly drove it a distance away from me, and then my phone rang. for 30 secs, i was on the phone, and when i wanted to see how much launch i could get from it, it launched, then it stuttered. kind of like a lean bog on a nitro motor, or i should say a bit of a miss. then it took off again. after that, it was running, but lost power. would still have the initial rip, but lacked the boost, or turbo you can feel kick in. so i continued for maybe another 30 secs. braught it back and checked leds. only one on for heat. i then moved my end point to 105 from 95. it stuttered again. i let off. then slammed the throttle on again, it had its boost and turbo back. then a short while, it lost it again, thats when i thaught id see if i drained the batt too much.
not even half its capacity. batt is an SMC, and motor a redline 10.5.
i am supposed to be racing it tommorow night, and if i can get suggestions, that would be good.
i havent recalibrated the radio to ESC, and i havent checked the speedy settings. i will check settings in s short while. but it seemed strange to just go flat, then come back to life, then fall away again.
i had a complaint last week from the owner, when i was helping him, but that was with my speedy, and different motor. he complained it went flat, and lost its feel of power. so different motors, different speedy, different Cap. not 100% sure if its the same battery though.
thanks for any help in advance.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 12-09-2010, 06:07 AM   #18845
M-Technic's Avatar
Trader Rating: 15 (100%+)
Sounds like a sensor issue. First try a new/different sensor wire. If that doesn't help, try a different motor, and again try different sensor wires.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 12-09-2010, 06:13 AM   #18846
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
you did calibrate after updating the esc
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 12-09-2010, 06:39 AM   #18847
azwan's Avatar
im a new rs pro user..want to ask something
what is:
Throttle Profile: ?
Push Control: ?
Brake Min: ?
Throttle Profile: ?
Neutral Width: ?
Throttle Min: ?
Timing Advance: ?
Boost: ?
Turbo: ?
Turbo Ramp: ?
thanks
XRAY T4 / ORCA VX / ORCA INFINITE / PPRCC
ON ROAD RACING
azwan is offline   Reply With Quote
Old 12-09-2010, 07:09 AM   #18848
dmatter's Avatar
Did the on road guys go back to 208? I was looking at some recent set up sheets of Atsushi Hara etc and they said they were using 208? Is there something wrong with 212?
dmatter is offline   Reply With Quote
Old 12-09-2010, 07:18 AM   #18849
Pattojnr's Avatar
yes i did.
has had diff motor, and sensor wire, and speedy. for 2 diff speedies, i believe it is in the car. time has run out, so ill try to sort at the track tommorow night.
Serpent - Walter RC
Old 12-09-2010, 07:22 AM   #18850
M-Technic's Avatar
The only thing I have noticed is that the car can violently "check up" if you lift the throttle much, like if you are lifted at the apex of a high speed sweeper. This has been a common complaint at our track, but I think it happened on v208 as well. We noticed it after leaving v203.
Old 12-09-2010, 07:43 AM   #18851
Pattojnr's Avatar
Found the problem, as i expected. it is in the car. Slipper has melted from teh extra power i have given the car over the last fortnight. good while its cool, as things heat up, Bye Bye power, and spur gets hot to touch.
i have only used V212 twice. i feel brakes are improved over 203, power is the same, just the settings are a bit different. just have to get used to it.
Serpent - Walter RC
Old 12-09-2010, 07:58 AM   #18852
20 SMOKE's Avatar
what is:
Throttle Profile: ?
Push Control: ?
Brake Min: ?
Throttle Profile: ?
Neutral Width: ?
Throttle Min: ?
Timing Advance: ?
Boost: ?
Turbo: ?
Turbo Ramp: ?
thanks
read over this,it is a new user guide with pics on everything the rs does
http://www.carsrcracing.co.uk/?p=244
Jamie W
Old 12-09-2010, 08:27 AM   #18853
miller tyme's Avatar
Have you checked the Min Throttle and Min Brake, depending on how neutral is I think this could make the car go from a little throttle to a little brake suddenly.
Ken Miller
RCTarget - Capricorn - Pro Level RC - MAX Power - Maxima Fuel - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 12-09-2010, 08:44 AM   #18854
M-Technic's Avatar
I am talking about partial lifting, not even going to neutral, not going to brake. I really don't use brakes on my track so I haven't messed with the minimum brake setting. Minimum throttle I have been using 20-30 (17.5 touring car).
Old 12-09-2010, 09:35 AM   #18855
Krio's Avatar
Trader Rating: 150 (99%+)
Are you going from full throttle? If turbo is engaged and you back off just enough so that timing vanishes, but still on power enough that the magnetic field being created is now "behind" the rotor it will slow the motor to an extent.
www.kriostasis.com
Krio is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
