Old 12-07-2010, 09:18 PM   #18826
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by genius120 View Post
Need help, TURBO BOOST LOOSING AFTER 5 MINS. ESC rs pro FW:212
-motor: lrp x12 10.5t endbell timing: 0(default) FDR: 7.18
-Boost: 40, start RPM: 8907, end RPM: 22032
-Turbo: 10, Turbo ramp: 2, Turbo delay: .3
-Voltage cut-off: 6.360
-Drive mode: sensored only
-Motor direction: normal
-Throttle profile: 1
-Current limiter: off
-neutral width: 20
No temperature problems ESC temp: 3leds, Motor temp: 60-63C Max.
Switching off and switching on again the ESC, turbo boost back to normal.
thanks
What brand radio do you have?
STLNLST is offline   Reply With Quote
Old 12-08-2010, 01:29 AM   #18827
Sanwa M11X - RX-451R, thanks
genius120 is offline   Reply With Quote
Old 12-08-2010, 01:33 PM   #18828
BCbud's Avatar
Trader Rating: 37 (100%+)
Originally Posted by 20 SMOKE View Post
do you mean this
Good day!
Has this been tested to work and if so, I would assume it would work for a booster as well? I would like to have one switch if it is possible.
PS From post #18823 on page 1255.
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Old 12-08-2010, 03:08 PM   #18829
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
I use it in world gt I was wondering about a booster
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 12-08-2010, 04:36 PM   #18830
BCbud's Avatar
Ok, please bare with me as I try to get this. So the wire going to the switch should be possitive so that would mean that there would be the battery voltage of 3.7V in series with the the 7.4V Rx pack for a total of 11.1??? The RS is rated for 3 cell so there shoulnt be a problem with that but is my asumption that the switch wire is possitive correct? If this is so I cant see why a voltage booster of 5-6V couldnt replace the Rx pack.
Any imput on this is very welcome and thanks in advance.
Recycled teenager.
Old 12-08-2010, 05:11 PM   #18831
20 SMOKE's Avatar
no,it is 7.4 coming in to the bec and is reduced going to the rx it does nothing with supplied power to drive the motor,Jim or randy can get in a more depth detail.randy said they he would like to see life packs since they are 6.6 but i charge my lipo to around the 7.9-8.1 and have no problems and it last 6 or so runs
Jamie W
Old 12-08-2010, 05:31 PM   #18832
BCbud's Avatar
Ok, so what is the on/off switch interupting to turn of the Tekin? I thought the supply or main battery also was the battery suppling power to the Tekin as well so wouldnt there be some voltage going through the switch and that would be added to the voltage of the rx pack wouldnt it?
Recycled teenager.
Old 12-08-2010, 05:50 PM   #18833
Randy, when come these motors on the marked?
they look great.
are they also faster?
http://sphotos.ak.fbcdn.net/hphotos-..._4326525_n.jpg
toptek is offline   Reply With Quote
Old 12-08-2010, 05:59 PM   #18834
HarryLeach's Avatar
Send a message via AIM to HarryLeach
The two switch wires make a loop to power the BEC circuit, which also powers the ESC micro controller.
From what I can tell, the main pack/ESC ground is separate, the switch interrupts the main pack BEC supply. By adding another 1s pack inline with the switch wires, you're feeding 2s to the BEC to be regulated down to 6v output. The 2s feeding the BEC is ONLY feeding the BEC, not adding any more power to the motor. You'd be adding an extra cell to the circuit after the motor gets it's supply, but before it reaches the BEC input by wiring into the switch wires.
Hope that makes sense.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 12-08-2010, 06:06 PM   #18835
BCbud's Avatar
Thanks, that was a well worded explination and kind of what I ment.
Recycled teenager.
Old 12-08-2010, 06:08 PM   #18836
d OG black flag's Avatar
Default i need some help please
can anyone help me with a problem i am having with the hot wire system? i have a trkin fx pro speed control and i was told that it can be program with the hot wire. however when i connect it ti doesn't have the bottom portion where i can access the bottons to apply the settings. i have down loaded the soft many times and i get the same results......nothing no buttons save the setting. can any help or is this a problem for every one since i am not using a brushless esc? thanks
d OG black flag is offline   Reply With Quote
Old 12-08-2010, 06:34 PM   #18837
is there a apply settings button?
pres that after changing your settings. than you probbably see a window with an ok button. pres ok.
as you update the speedo, don't disconnect till it has went treu all stages.
hope this helps.
Old 12-08-2010, 06:40 PM   #18838
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Your screen either isn't big enough or the resolution isn't set high enough.
If this is a netbook reload the hotwire software and choose the "express" version. It should then fit the screen.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 12-08-2010, 06:42 PM   #18839
Team Tekin
Randy_Pike's Avatar
The new Redline Gen 2 motors are still being tested.
In that picture there is also the new micro motor(s) as well as the Roc412 crawling motor.
Old 12-08-2010, 06:47 PM   #18840
they look great. I want them.
how are the test results? and do they stay cooler?
when do you think that they will be availeble?
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
