Old 12-03-2010, 06:41 AM   #18661
need help, esc set-up for vegas 212 rs pro + lrp x12 10,5t, top photon-cefx conversion + solaris rubber tires, large nitro asphalt track with medium traction, thanks
genius120 is offline   Reply With Quote
Old 12-03-2010, 06:56 AM   #18662
Originally Posted by b33 View Post
can anyone tell me if i should run a 5.5 in dual or sensored mode and the difference between both thanks
use dual mode. I didn't use it with the 212 but with the 203 I used it a lot.
srart with an advanved timing of 40.
read the info on the Tekin site. there the new 212 is explained and how the dual mode works.
that's great news Randy. Will it also be posible to make a setup without using a hotwire?
toptek is offline   Reply With Quote
Old 12-03-2010, 07:09 AM   #18663
you were a gm driver?
try this
boost 40
turbo 12
turbo ramp 2 turbo delay 0,8
start rpm 7000
end rpm 16000
warch were your turbo kicks in to fine tune the delay. on larger tracks I always use a bigger delay.
the setup worked for me but I use an other motor.
Old 12-04-2010, 09:14 AM   #18664
stipres's Avatar
Trader Rating: 70 (100%+)
Originally Posted by toptek View Post
how much timing do you use on the motor. I have a 13,5t sp v3.
I use the motor with the timing on 10. this makes the motor more agressive by accelariting.
Originally Posted by theisgroup View Post
our tracks sound to be about the same size. but we had some slow technical corners so i had to run the start rpm a little lower in that setup and the end rpm is also a little lower because we never really had a place that got faster except that back straight. so I would move the start and end rpm up, widen the range if you are on power more often then not.......
Had a great night of practice last night. Thanks for your help with set-up. 10* on the end bell, ESC adjustments, a little gearing adjustments, and some help from my running partner helped me lay down some fast lap times. Now I don't have to go back to nitro
Pres Ilog
AKA Products, Team Losi, Track Star Racing, Tekno RC, Hitec RCD, LRP, Schelle Racing, Imagine It Graphics, EKD, VP/PowerMaster fuels
stipres is offline   Reply With Quote
Old 12-04-2010, 12:00 PM   #18665
Racecrafter's Avatar
Trader Rating: 25 (96%+)
You looked really good out there last night.
Just a feel good moment for those that helped Pres here....
Pres' first run was in the 10.5's a few 10.4's but off the pace early. Our track demands that kind of pace toward the 7 minute mark.
More tuning, more testing, more track time. I took a look at what Pres had for ESC settings and with the 10* motor we changed a little here and there in boost and timing also lowering turbo.
Last run right out of two warm up laps, 9.8! backed up by another 9.8! then a 9.9 and a series of 10.0 -10.2's!
I want to thank everyone here (and our locals Fred, Dave & Stan) for their help in not only helping Pres but myself getting back up to speed in 1/12.
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 12-04-2010, 12:40 PM   #18666
I found my setup that I used with the sp 13,5tv3
boost 50
turbo 5
turbo delay 0 ramp 2
start rpm 8000 to 9000
end rpm 12000 to 14000
rpm settings can be different because I changed them on the track
but the difference is about 3000 to 4000
motor 10
the straight was about 110 feet.
can you post your setup.
i tried the motor first ad 0 but it ran like an old woman.
than i changed it to 10 and the motor came alive.
it has a lot of punch.
Old 12-04-2010, 03:23 PM   #18667
hairy's Avatar
Default I need real Help!
I need to talk to someone who knows these speedos and can help me. This is the third weekend that I blown up an R/s and I don't know what it is I am doing wrong!I have treid to talk to the TECHS at Tekin but they have been too busy I guess because I haven't heard back from anyone.
Please p.m. and email address or I willl send oyu mine so that I can find out what is going wrong!
MERLIN RACING
"He once ran a marathon because it was on his way"
Logic is a lost art!
You are defined in life by how you respond to defeat!
hairy is offline   Reply With Quote
Old 12-04-2010, 03:43 PM   #18668
that's not good.
Old 12-04-2010, 03:45 PM   #18669
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
just post it hairy,what car and settings
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 12-04-2010, 04:05 PM   #18670
hairy's Avatar
I have posted it before and noone at all responded so I figure email would be better
MERLIN RACING
Old 12-04-2010, 04:08 PM   #18671
hairy's Avatar
This is the third weekend that this has happened: I run an X-ray t2r car with an LRP x-12 17.5. After a couple of runs with the motor coming off the track at 170-180 degrees, the R/S will not turn over the motor when the rotor is in a certain position. If you are familiar with Lrp motors they have strong magnet that keeps the motor from free Wheeling like a Duo. There are five settings or "notches" if you will that the rotor rests on. In two of the five positions When the throttle is pulled on the transmitter the speedo lights up like normal but the motor will not turn without a push.I have tried this speedo with a different LRP motor and a Duo 2 motor no difference, I have tried six different sensor wires and two different receivers.
My settings are as follows
FDR 7.53
Carpet track with good traction and a straight of approx 80ft.
V212
boost 51
turbo 10
Timing 80
Start rpm 4278
End rpm 10000
turbo delay.1
Turbo ramp 2
Cut off 2s
sensored mode
motor direction normal
throttle profile 4
current limit 98
drag brake off
brake strength 100
Reverse speed off
nuetral width 8
push control 20
throttle min and brake min at default setting
MERLIN RACING
Old 12-04-2010, 04:23 PM   #18672
20 SMOKE's Avatar
with a straight under 100ft the turbo is usless all it is doing is creating heat and the rpm range is to close for a TC .is the esc getting hot.it did burn up.
Jamie W
Old 12-04-2010, 04:25 PM   #18673
hairy's Avatar
No the speedo did not get hot and it works except for when the rotor is in a certain position and then you have to roll the gear to get it to run.
MERLIN RACING
Old 12-04-2010, 04:28 PM   #18674
20 SMOKE's Avatar
at that point before you have to move it are you using the sensor checker to make sure all the sensors are working
Jamie W
Old 12-04-2010, 04:30 PM   #18675
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Hairy I've helped you before.
There should be 6 positions not 5. This is from the rotor finding it's place in between the 3 "slots" of the motor on the N/S of the rotor.
That being said if the motor will not start from a stop I'd wager you have a bad sensor board in the motor since you've swapped harness's.
You also have a bit too much timing for the setup. You should try your boost around 45 and turbo around 10. This of course will not fix your issues.
I would like to see you try setting your start rpm to 5442 and end to 20,000 to see if this changes anything.
Have you used the RS's sensor checker feature to verify you're getting all 3 led's to cycle on/off?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
