Old 12-01-2010, 02:27 PM   #18616
Originally Posted by hacker View Post
No I used 203 say 8 months ago, then went elsewhere. Came back just recently to 212, doesnt have the same top end, in my opinion.
There is a reason the fastest guy in open 17.5 at cleveland used 203
windsor is offline   Reply With Quote
Old 12-01-2010, 02:33 PM   #18617
Originally Posted by Randy_Pike View Post
Andrew Knaaps Tq and winning US Indoor Champs Setup:
any idea on rollout?
Old 12-01-2010, 02:33 PM   #18618
any idea what rollout he was running?
If one were to go to another track that was a little more tight or shorter on the straight would you just change the boost and delay or would you start to look at the rpm range?
gguertin145 is offline   Reply With Quote
Old 12-01-2010, 02:37 PM   #18619
M-Technic's Avatar
Trader Rating: 15 (100%+)
I know someone else that swears by 203 as well, for me I didn't care for 208 but 212 is good. I'm not sure what could possibly make 203 faster than 212.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 12-01-2010, 03:06 PM   #18620
miller tyme's Avatar
What motor ???? I thought stock rotors were 12.5.....12.3 would be a tuning rotor...............
Ken Miller
RCTarget - Capricorn - Pro Level RC - MAX Power - Maxima Fuel - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 12-01-2010, 03:06 PM   #18621
yes thats what I asked for... sorry
Old 12-01-2010, 03:22 PM   #18622
how about an idea for rollout on a no timing setup?
slsspark is offline   Reply With Quote
Old 12-01-2010, 03:26 PM   #18623
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
No timing setups and all other tracks will use different roll outs. I'm sure Andrew will chime in and post it up.
203 is not faster than 212, it's been tested back to back. If anything they're nearly identical.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 12-01-2010, 04:58 PM   #18624
I have a question about the RS Speedy - When you press mode and change, say the throttle profile, would that turn off the turbo and/or the boost values?
I ask because I just changed the profile to #3 and I lost my turbo, and possibly the boost. The timing profile also changed to #2 or 3 instead of the custom (C1,C2) profiles. Only when I hooked it back up to Hotwire did it all come back. Using V212 as well.
Car-less (Velox V10 or 733) // RB T10.5"+" (JB Modified) // Bluebird BMS-990DMG (St) & BMS-631 (T/B) // ATS 16% // Capricorn Wheels // Protoform
"70% of the time, it works ALL the time"
DJ_Shakespear is offline   Reply With Quote
Old 12-01-2010, 05:06 PM   #18625
Krio's Avatar
Trader Rating: 150 (99%+)
When you are making selections on the RS itself, TP is now timing profiles. Led number 1 is no timing, 2 is a little, 3 is some more, 4 is a decent amount, 5 is good for stock, 6 is whatever boost/turbo settings you programmed into cst1, and 7 is whatever boost/turbo settings you programmed into cst2. The actual throttle profiles (that are like expo) are only available on the computer through hotwire.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 12-01-2010, 06:04 PM   #18626
Ahh, so you're saying if I change the Throttle Profile on the ESC, it doesn't change the throttle curve but instead changes the Timing Profile that shows 1-2...C1-C2 to whatever LEDs I make light-up?
Old 12-01-2010, 06:06 PM   #18627
locked's Avatar
yes
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 12-01-2010, 06:11 PM   #18628
Thanks guys! So only if I change the TP, that would get rid of my Boost/Turbo settings? Im not sure if I didnt change that once, but still lost it.
Old 12-01-2010, 06:14 PM   #18629
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Throttle curve gets changed using the hot wire,timing is changed in the factory set profiles using the pit tune mode
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 12-01-2010, 06:17 PM   #18630
So using pit-tune mode, you can change the timing profiles and not the throttle curve - does the curve I previously selected (eg slightly more aggressive) still apply or does it revert to linear?
In Hotwire, you can change the timing profile AND the throttle curve without affecting each other.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
