Tekin RS ESC sensored >
Old 11-30-2010, 10:20 PM
  #18601
djiewie's Avatar
could be your right. The 212 has no 208 in it because the 208 was not excepted with the 0-timing setup. So in 0-timing stock now with 212 it is excepted i believe. Maybe in 208 there was still a bit of timing left.
Greetz JW
djiewie is offline
Old 11-30-2010, 10:30 PM
  #18602
hacker's Avatar
Trader Rating: 141 (100%+)
Originally Posted by energydrink View Post
Hi I downloaded the 212 software with my tekin 17.5 and it seems slower than when I last ran my car with the 208 software . All my settings are the same since the last time I ran in spec mode . Can anyone help me ? Thanks .
thought I was going crazy, glad someone else is finding the same problem.
definately doesnt have that 203 scream down the straight anymore
hacker is offline
Old 11-30-2010, 10:32 PM
  #18603
energydrink's Avatar
What do you mean accepted and not accepted ? i thought both had 0 timing ?
energydrink is offline
Old 11-30-2010, 10:33 PM
  #18604
Do you mean 208 ?
Old 11-30-2010, 10:52 PM
  #18605
after updating. dit you reset the speedo and recalibrated your radio?
toptek is offline
Old 11-30-2010, 11:02 PM
  #18606
Of course .
Old 11-30-2010, 11:39 PM
  #18607
hacker's Avatar
Do you mean 208 ?
No I used 203 say 8 months ago, then went elsewhere. Came back just recently to 212, doesnt have the same top end, in my opinion.
hacker is offline
Old 12-01-2010, 04:44 AM
  #18608
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
there was no timing in 208 spec mode
20 SMOKE is offline
Old 12-01-2010, 05:26 AM
  #18609
Default WGT setup
Our club is starting to run a WGT class, We have a temporary track so the traction is inconsistent, occasionally it will be left laid out for two or three weeks. We decided as a group to go 17.5 turn no timing so the other guys could use GTB's and all of our other classes have switched to superstock so everyone had 17.5's laying around. My question is how much different should the setup be for this compared to 1/12 scale 17.5 setup? Obviously the weight would affect the setup so any pointers on rollout would be appreciated. Our track is 36' x 75' low to medium traction.
Thanks in advance.
slsspark is offline
Old 12-01-2010, 05:45 AM
  #18610
Dog Bone's Avatar
Wasn't there a small amount of 'fixed' timing added by the ESC, even in spec mode? I thought this was why 212 was created and subsequently approved by Roar for spec racing - so there was a true 'zero-timing mode'.
This would explain why 212 is 'slower' than 208.
Dog Bone is offline
Old 12-01-2010, 06:45 AM
  #18611
M-Technic's Avatar
Trader Rating: 15 (100%+)
That is just some people's speculation. It has never been proven.
M-Technic is offline
Old 12-01-2010, 07:27 AM
  #18612
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
I ran 212 in my TC all weekend and the champs and had one of the fastest cars in Super Stock.
I changed from 203 to 212 for the 12th scale main and I thought it was much better. I could of used a little more gear but my car seemed to have more punch in the main than it did with 203 in qualifiying.
L.Fairtrace is offline
Old 12-01-2010, 07:46 AM
  #18613
20 SMOKE's Avatar
Larry can you post you setup with tire size and track size if you don't mind
20 SMOKE is offline
  #18614
I am looking for a good starting setup for a 1/12th scale 17.5 with timing for a duo 3. I run on 2 tracks one with a 75' straight and the other around 100. I do have a single cell rotor or some bs like that if that makes a difference in setup.
A starting point with places you would change from track to track would be great too...
Any help would be appreciated I am fairly new to making changes in my hotwire
gguertin145 is offline
Old 12-01-2010, 01:26 PM
  #18615
Team Tekin
Randy_Pike's Avatar
Andrew Knaaps Tq and winning US Indoor Champs Setup:
Attached Thumbnails Tekin RS ESC sensored-andrew-knaap-us-indoor-champs-1-12-17.5.png
Randy_Pike is offline
