Old 11-30-2010, 10:09 PM   #18586
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by energydrink View Post
Hi I downloaded the 212 software with my tekin 17.5 and it seems slower than when I last ran my car with the 208 software . All my settings are the same since the last time I ran in spec mode . Can anyone help me ? Thanks .
What do you mean by seems slower? If all of your settings are exatly the same you shouldn't feel a difference until you adjust the min throtle and min brake settings. If the track layout is the same what are your lap times with 212 compared to 208?
STLNLST is offline   Reply With Quote
Old 11-30-2010, 10:13 PM   #18587
energydrink's Avatar
i haven't adjusted the min throttle and brake settings yet, what should they be ? The punch feels the same though, it just feels like the car has less top end now and i'm about 2-3 tenths off my old lap times .
Tamiya 415 MSXX...Associated B44...TOP Photon...Mugen MBX6
energydrink is offline   Reply With Quote
Old 11-30-2010, 10:21 PM   #18588
STLNLST's Avatar
Are all of your settings and gearing exactly the same? If you know how much time you're losing per lap I assume it's safe to say that the track layout is the same correct? Is this aspahlt or carpet or off road? If it's on road turn the min throtle to 30 (better punch) and for the top end you can either bump up your turbo or gear up one. Are you getting pulled on the straight?
Old 11-30-2010, 10:25 PM   #18589
All settings and gearing are the same ...
Track layout is same .
This is carpet on road .
Bump my turbo ? But I am in spec mode .
Yes I am getting pulled on straight by friends with 208 .
I need to change my gearing by going from 208 to 212 ?
Old 11-30-2010, 10:38 PM   #18590
Team Pink's Avatar
Trader Rating: 20 (100%+)
Your gearing should not change from 208 to 212. More turbo would give you more top end. I would reccomend sharing your speedo setup if you can and maybe we can try to fix it that way.
Team Losi Racing/ Spektrum/ Horizon Hobby/ JConcepts/ Hobby Star/ Schelle Racing
Team Pink is offline   Reply With Quote
Old 11-30-2010, 10:41 PM   #18591
Still spec mode .
Old 11-30-2010, 10:56 PM   #18592
BCbud's Avatar
Trader Rating: 37 (100%+)
Good day!
Are you running foam tires?
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Old 11-30-2010, 11:00 PM   #18593
No . Rubber .
Old 11-30-2010, 11:02 PM   #18594
BCbud's Avatar
Are they the same ones you used befor? Are they new or neer the end of there life?
Recycled teenager.
Old 11-30-2010, 11:04 PM   #18595
They have only been run on carpet so they still look brand new .
Old 11-30-2010, 11:07 PM   #18596
BCbud's Avatar
Is it posible the tires are starting to fall off a bit, how mutch time is on them?
Recycled teenager.
Old 11-30-2010, 11:09 PM   #18597
STLNLST's Avatar
Still spec mode .
In spec mode there should be no difference. Which spec setting are you running?
Old 11-30-2010, 11:11 PM   #18598
The tires have one race day on them . This is carpet, so they don't really wear .
It's the default setting when I download the software .
Old 11-30-2010, 11:17 PM   #18599
BCbud's Avatar
Ok, they are not the same tires then are they the same compound? What I am getting at is if it is not the speedo, there are other things that can cause a drop in performance. A failing bearing in car or motor, binding suspention from impact, a battery starting to go soft, tires etc......
Recycled teenager.
Old 11-30-2010, 11:19 PM   #18600
No, I maintain my cars . And that wouldnt really affect my car being slow on the straight .
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
