Old 11-30-2010, 02:43 PM   #18571
thank you fellas
vito c. is offline   Reply With Quote
Old 11-30-2010, 03:19 PM   #18572
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Hara ran our esc at the IIC in Vegas this year. Hara is also using the Tekin RS Pro right now at his home track in Thailand.
2011 will be another good year for Tekin, you never know who might be the next Tekin Team driver!?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 11-30-2010, 03:23 PM   #18573
is he also driving mod with it or only stock?
was he running the Tekin speedo by the last dutch ets race?
I ask this because I hear a lot of negative tings for mod wile I have good experience with the speedo in mod. I'm still running an old 4,5t lrp motor and I'm still winning races with it.
I don't use extra cooling for the speedo and I have no temp problems.
for stock the speedo has proven to be the top. just watch the results. but for mod it would be great.
toptek is offline   Reply With Quote
Old 11-30-2010, 03:44 PM   #18574
darrenoakley's Avatar
Ok just installed the Rs in my T3 011 with 212 and the minimum throttle at 0 but it still seems to give a jolt of power when i first pull away.It almost feels like there is a minimum throttle set and it is kicking in. Does anyone have an idea how i can smooth this out a little ? would it be worth setting some neutral width and if so how much
17.5 duo 2 timing set 1 click above centre (dont know what this is in deg sorry)
FDR 6.38
boost 40
turbo 12
ramp 0.2
delay 0.5
profile 4
rpm start 5000 ish
rpm finsh 18000ish
neutral width 0
Xray x11
Xray T3 011
darrenoakley is offline   Reply With Quote
Old 11-30-2010, 04:04 PM   #18575
locked's Avatar
FDR 6.38
boost 40
turbo 12
ramp 0.2
delay 0.5
profile 4
rpm start 5000 ish
rpm finsh 18000ish
neutral width 0
Your settings are extremely close to mine, but I'm using a 17.5 redline motor right now, 12 min throttle and neutral width around 20 I think. I don't find it jolts. Quite smooth in fact.
Neutral width at 0 might be the problem. If not, you could also try lowering the endbell timing or play around with throttle expo on your transmitter.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 11-30-2010, 04:14 PM   #18576
scribbler's Avatar
Is there any conflicts between Tekin technology, and Spektrum technology.
Every once in a while I have mysterious power cut offs, loss of signal to the ESC, and inconsistant throttle responce.
scribbler is offline   Reply With Quote
Old 11-30-2010, 04:35 PM   #18577
Ok was thinking that could be the way to go so will try it. Thanks for the reply
Xray x11
Xray T3 011
Old 11-30-2010, 06:18 PM   #18578
Team Tekin
Randy_Pike's Avatar
This can be a DSM brown out. It depends on what servo and other things are on the BEC circuit like personal transponders,fans,etc.
Add a cap to your receiver, see if it goes away. It often will.
I'm not sure if Hara was running the RS Pro at the Dutch race to be honest. I've been talking to him daily since the 1/8 Nitro worlds so I'll have to ask him.
Old 11-30-2010, 06:26 PM   #18579
Warren Weaver's Avatar
Trader Rating: 47 (100%+)
Originally Posted by vito c. View Post
hey guys,
can anyone help me with 17.5 set-up?
tc5,32/104 gearing
70-80ft straight
trinity t3 motor
carpet/rubber tire
very high traction
thank you
veetz
veetz hit me up i got one for ya
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 11-30-2010, 06:28 PM   #18580
EJF
EJF's Avatar
Trader Rating: 37 (100%+)
Will a Takin RS be sufficent for a touring car on carpet, i do not intend on running low turn motors, mainly 17.5 or 21.5 rubber tire.
EJF is offline   Reply With Quote
Old 11-30-2010, 06:37 PM   #18581
Team Pink's Avatar
Trader Rating: 20 (100%+)
The RS will be more than sufficient for 17.5 and 21.5 rubber tire on carpet.
Team Losi Racing/ Spektrum/ Horizon Hobby/ JConcepts/ Hobby Star/ Schelle Racing
Team Pink is offline   Reply With Quote
Old 11-30-2010, 09:16 PM   #18582
hey guys jus getting into elec this winter from nitro going to run 17.5 is the rs pro one of the best esc out or is the reg rs better ? Also where do you buy your esc ELEC from online?
younghovaa is offline   Reply With Quote
Old 11-30-2010, 09:22 PM   #18583
pakk's Avatar
Trader Rating: 79 (100%+)
For 17.5, the regular RS is all you need. If you plan to run some mod, pick up the pro. Make sure you get a hot wire. Amainhobbies should have everything you need.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 11-30-2010, 09:49 PM   #18584
ok thanks
Old 11-30-2010, 10:05 PM   #18585
energydrink's Avatar
Hi I downloaded the 212 software with my tekin 17.5 and it seems slower than when I last ran my car with the 208 software . All my settings are the same since the last time I ran in spec mode . Can anyone help me ? Thanks .
Tamiya 415 MSXX...Associated B44...TOP Photon...Mugen MBX6
energydrink is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
