Old 11-29-2010, 05:27 PM   #18556
ok so in c1 and c2 you can set you personall settings. does it matter wich one you use?
toptek is offline   Reply With Quote
Old 11-29-2010, 05:38 PM   #18557
BCbud's Avatar
Trader Rating: 37 (100%+)
No, you can use one or the other or you can put a different setup in each one and you do not need the hotwire to change between them.
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Old 11-29-2010, 06:18 PM   #18558
Chemical X's Avatar
Trader Rating: 16 (100%+)
Sorry if this has already been covered, but can someone explain the procedure to switch between C1 and C2 without using HotWire? Thanks.
Chemical X is offline   Reply With Quote
Old 11-29-2010, 06:46 PM   #18559
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
push mode button 5 time led (TP) push INCS to led 6 (C1) led 7 (C2)
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 11-29-2010, 07:38 PM   #18560
Default Hotwire 212
Hey guys ive just converted to a Tekin RS Pro and Redline 4.5 for touring mod. Ive downloaded the Vegas 212 software but i havent seen any other drivers set ups to use as a guide. I'm wondering if anyone can help me with a base set up to start with that i wont blow the motor with. Our track has about a 80-100ft straight.
Im guessing i wont need to run any boost or turbo with 4.5?
Any help will be appreciated.
Cheers.
jeremy mac is offline   Reply With Quote
Old 11-29-2010, 08:27 PM   #18561
Cheers.
Set your speedo in dual mode.
I used for a lrp x11 4,5t a timing of 40 to 45
gearing around the 8fdr.
On the Tekin site I notist that dual mode also is changed and that you can change the rpm range. Also just like the sensord mode 2 custom settings.
I can't waith till saturday to play with the speedo.
left my car ad the track.
It is a track in an old barn from a frend of me. we built there a track and now we race there with about 15 to sometimes 20 and even more racers.
next week the track will be bigger again. going to trow some junk out.
In the summer we drive outdoor. Outdoor I run mod.
put an extra cap on your speedo or a bigger one.
I use a 4700 v16
Old 11-29-2010, 08:30 PM   #18562
thanks I also found the info on the website.
can't wait to try the mod mode.
Old 11-30-2010, 04:33 AM   #18563
guinnes.s's Avatar
Originally Posted by sidecarphil1 View Post
ok
V212 set up for SP13.5v3
motor timing 10
boost 45
turbo 15
start 8500
end 16000
turbo delay 0.2
turbo rate 2
Throttle profile 5
rearing around 7 depending on the track , the rest of the settings are up to you
what about the timing advance setting?
guinnes.s is offline   Reply With Quote
Old 11-30-2010, 04:47 AM   #18564
TrevCoult's Avatar
The timing advance setting only applies if your sensor lead falls out, so don't worry about it.
See http://www.carsrcracing.co.uk/?p=244 for explanations of the settings.
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 11-30-2010, 11:08 AM   #18565
2-Bad's Avatar
Trader Rating: 24 (100%+)
Hi... I'm new to these stock esc and want to place an order for one.
So apart from TT1153 RS Pro esc, is there anything else I need to order to use this esc?
Thanks.....
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 11-30-2010, 11:15 AM   #18566
M-Technic's Avatar
Trader Rating: 15 (100%+)
Thanks.....
You don't need the Pro if you are running stock. Only for mod touring is the Pro necessary. The normal RS is smaller and lighter.
You don't need anything else except possibly a HotWire so you can make setup changes via your laptop, and your own battery connector of choice to solder on. It comes with wire/leads and a capacitor.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 11-30-2010, 01:37 PM   #18567
hey guys,
can anyone help me with 17.5 set-up?
tc5,32/104 gearing
70-80ft straight
trinity t3 motor
carpet/rubber tire
very high traction
thank you
veetz
vito c. is offline   Reply With Quote
Old 11-30-2010, 02:29 PM   #18568
M-Technic's Avatar
Originally Posted by vito c. View Post
hey guys,
tc5,32/104 gearing
70-80ft straight
trinity t3 motor
carpet/rubber tire
very high traction
thank you
veetz
Start with Hara's setup from Tekin's web site.
Old 11-30-2010, 02:32 PM   #18569
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
http://www.teamtekin.com/hotwire/ESCsetups/index.html
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 11-30-2010, 02:42 PM   #18570
Randy, why does Tekin not sponsor a driver like hara for mod?
why don't you sponsor a top 10 driver from Europe or Japan.
noting about the us drivers but in the us Tekin is already having good drivers.
would be nice to see hara race with the speedo in the mod class.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
