Old 11-23-2010, 02:25 PM   #18436
Originally Posted by 20 SMOKE View Post
start 3-4k
end 12500
50 timing boost
motor what you have already
fdr 5.8 for the small track
6.2 for the bigger track with 5-10 turbo and 15k end.
ramp 2
delay .15
put both in the esc one in the C! and the other in C2 and you can try both in the same run
one last quick question... Looks like my gearing was way off. What rollout would you run with a fdr of 5.8 or 6.2?
Thanks!
gguertin145 is offline   Reply With Quote
Old 11-23-2010, 03:42 PM   #18437
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by sidecarphil1 View Post
is there an nice link to the instructions for changing between C1 and C2 ??
i cannot find it
press mode button 5 times until the led is on TP press the INS button untill led 6(C1) led 7(C2)
Thanks!
i dont use roll out its rubber tire
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 11-23-2010, 03:43 PM   #18438
I was told running a rubber tire setup on foam touring car would run my motor temps to hot?
Old 11-23-2010, 03:45 PM   #18439
20 SMOKE's Avatar
your running foam.i didnt see you say that
Jamie W
Old 11-23-2010, 03:47 PM   #18440
20 SMOKE's Avatar
figure what the roll out is for a rubber and then figure what you need for foam
Jamie W
Old 11-23-2010, 03:56 PM   #18441
cwoods34's Avatar
Ok, seeking advice for 17.5 open TC.........
Novak SS w/max timing (don't know specific number)
Boost 48
RPM 1,500 to 10,000
FDR 5.4
Some turbo thrown in
I was first running around a 6.3 FDR when I started this setup (borrowed from a friend) and it ran horrible while coming off under 100* F. I just threw 4 teeth at it to a 5.4 (currently on the car) and it picked up a considerable amount of speed and a temp of around 155 from what I can remember.
What can I do to give this setup more bottom end? It just doesn't have as much rip as I'd like, but it has nice top end (would be great on a large asphalt track).
Although it seemed to run slower at 6.3 with this setup, would it help to shorten the RPM range a bit and work my way back up into the 6's?.... or take motor timing back off and try another tooth or so?
I've never ran an SS with 212, but some of the other fast guys did and seemed to have great luck with it, so I know it has potential. Thanks Tekin
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 11-23-2010, 04:35 PM   #18442
Con
Turn your motor timing down.and change your rpm to 5000 start and 20000 end.
Con is offline   Reply With Quote
Old 11-23-2010, 05:35 PM   #18443
cwoods34's Avatar
This is for a medium/large carpet track BTW, not asphalt
Old 11-24-2010, 12:56 AM   #18444
hey guys, would appreciate a little insight here, have a weird problem with the RS Pro i used in 12th at the weekend. I've requested an RA number and filled in the form, but before I send it off, is there anything else I should try ?
Here's the issue:
v212
10.5 motor
TQ booster on a 1S Lipo
The car seems to have no acceleration until I hit full throttle and the turbo kicks in, almost like there's no boost being applied.
CPD Racing
chris_dono is offline   Reply With Quote
Old 11-24-2010, 02:08 AM   #18445
TrevCoult's Avatar
Here's the issue:
v212
10.5 motor
I thought I'd just back Chris up on this, it is not a setup issue, we've already been through that. It is exactly as Chris says, it is behaving like there is no boost at all, but there is turbo. Very strange.
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 11-24-2010, 02:20 AM   #18446
Trev
Thanks Trev
CPD Racing
Old 11-24-2010, 03:47 AM   #18447
idbdoug's Avatar
Trader Rating: 33 (100%+)
Here's the issue:
v212
10.5 motor
After loading v212 onto speedo, did you recalibrate your speedo by doing the neutral-full throttle-full brake calibration.
idbdoug
idbdoug is offline   Reply With Quote
Old 11-24-2010, 04:21 AM   #18448
TrevCoult's Avatar
idbdoug
He did that, or at least I think so. If he hadn't, turbo wouldn't have kicked in.
Trev
Schumacher Racing
Old 11-24-2010, 05:40 AM   #18449
Regional Moderator
CarbonJoe's Avatar
Did he try any of the canned timing profiles, or does it only happen on C1 and C2?
Did you try the firmware downgrade/re-upgrade? Does it happen with 203 or 208?
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 11-24-2010, 05:59 AM   #18450
Here's the issue:
v212
10.5 motor
Does it do the same when connected to a 2s lipo?
Smartypants is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
