Tekin RS ESC sensored >
Old 11-15-2010, 08:33 AM
  #18331
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Krio View Post
Technically speaking it makes the same amount of power via timing setups and whatnot, but the delivery/feel just keeps getting better every time which is translating to faster laptimes.
+1
The Throttle and Brake feel adjustments in 212 are awesome !
RedBullFiXX is offline
Old 11-15-2010, 01:56 PM
  #18332
Originally Posted by Smartypants View Post
how are people finding the 212 software? is it faster than 203 and 208 softwares?
The trottle feel is much better than former upgrades, it is depending
of the track you run on, but i feel the response is better so you run
similar rounds and this turn out at the end a better overal time.
Ed
eded1 is offline
Old 11-15-2010, 02:05 PM
  #18333
Post HELP
Originally Posted by DEIGIMA View Post
im getting a 13.5t brushless motor soon and was wonding what gears i will have to change?
im gunna do this to my hpi rs4 rally. its completely standard.
i also use reedy wolfpack nimh batteries (3600mah 7.2v)
i plan on using it for all-round bashing-including drift, offroad, and crazy stunts(high speed)
so yeh...
what diffs
what spur
what pinion
whateva.
thanks, jim.
--pm me if you can--
c'on! can anybody clue me into a good gear set?!
DEIGIMA is offline
Old 11-15-2010, 02:07 PM
  #18334
Super Moderator
Kraig's Avatar
Trader Rating: 73 (100%+)
What do you have now?
Kraig is offline
Old 11-15-2010, 04:50 PM
  #18335
tmaxx26power's Avatar
Trader Rating: 39 (100%+)
What does the throttle and brake minimum settings mean and do on the 212 software?
tmaxx26power is offline
Old 11-15-2010, 05:00 PM
  #18336
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
it how much throttle or brake is applied at first movement in %
20 SMOKE is offline
Old 11-15-2010, 05:35 PM
  #18337
miller tyme's Avatar
just what it says....the minimum of each applied when each signal is seen from the radio.
so a min throttle of 10 means the lowest throttle available is 10% so as soon as throttle is applied it instantly starts at 10 and when lifting it will fall down to 10 then drop right to 0. Likewise with the Brake.
miller tyme is offline
Old 11-15-2010, 06:16 PM
  #18338
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Originally Posted by SpraydbySprague View Post
Here's one.
My Tekin RS is now running 212 in my 12R5 powered by a TP 3.7 Lipo, TQ booster, and a Team Orion 7.5. Plenty of power, however I've noticed when running timing boost, the brakes seem weaker. Where I used to turn the brake EPA down to 60%, I now have to run up to 100% and the brakes are nowhere near as powerful. Any info will help.
Uhm, anyone? A little help?
SpraydbySprague is offline
Old 11-15-2010, 08:09 PM
  #18339
Try re binding with all epa's at 100. If that does not work check your break setting also your break minimum.
SikKustomz is offline
Old 11-17-2010, 04:39 AM
  #18340
hijinx's Avatar
Trader Rating: 47 (100%+)
Default Fast settings for 17.5
Hey there all, just wondering if anyone has got some awesome fast settings for at TC5R, running a Fantom 17.5, current fdr is 6.14, track has along back straight with a flowing infield all on ashphalt with med to high grip.
Any help would be awesome
hijinx is offline
Old 11-17-2010, 04:52 AM
  #18341
Trader Rating: 5 (86%+)
Default 1/12 settings
Does anyone have a good beginning point for 1/12 17.5 spec class..running an x12 track is 70ftx30ft...looking for a good rollout...also, anyone have a good 13.5 setting for 1/12
obi wun is offline
Old 11-17-2010, 04:58 AM
  #18342
20 SMOKE's Avatar
try mark burts setup,its on tekins site
20 SMOKE is offline
Old 11-17-2010, 05:52 AM
  #18343
You may want to post over on the Electric Off Road
VRacing is offline
Old 11-17-2010, 05:57 AM
  #18344
What are you using now? Did you look on the Tekin website?
VRacing is offline
Old 11-17-2010, 06:41 AM
  #18345
With the X-12 17.5, 85 roll with 4 dot -10 deg timing should be close.
Spec gearing you need to gear for lap time, no matter what it feels like, It may seem slow regardless depending on what you are used to.
This class is all corner speed, and finding the perfect gear.
There are quite a few setups for 13.5 on the Tekin Hotwire team driver setup page
For a decent base setup try
End rpm-10k
Start rpm-3k
50 boost
roll 70
and always temp at 4mins with new boost settings, 180f max is a good temp for consistent 8min runs with X-12, again 4 dot -10 deg
HTH
