Old 11-08-2010, 07:28 PM   #18196
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Jochim_18 View Post
I'm having problem calibrating my M11 DSS 2.4 GHZ to my tekin I just switch to the new software 212 and I'm not able to calibrate mt radio. The ESC only recognized the radio and neutral positon.
Set your EPA's to 130 for throttle and 160 for brake first. Then after you are done calibrating, move the throttle EPA to 140 (the max).
Make sure the throttle channel is not reversed. I have never had a problem programming my M11 DSS with a Tekin.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 11-08-2010, 07:41 PM   #18197
Jochim_18's Avatar
It just won't calibrate it's driving me crazy I got the D-rate at 100%, EPA Throttle @ 130%, EPA Brake @ 160%, ESC Neutral width at default... What am I doing wrong.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 11-08-2010, 07:42 PM   #18198
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
reverse throttle
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 11-08-2010, 07:59 PM   #18199
Jochim_18's Avatar
It did calibrate but I have to set the neutral width at maximum to calibrate anything lower than that it won't calibrate at all. On what do you guys have your neutral width set at?
Old 11-08-2010, 08:00 PM   #18200
M-Technic's Avatar
10
Old 11-08-2010, 08:06 PM   #18201
Jochim_18's Avatar
It just won't calibrate if I set the neutral width lower than maximum.
Old 11-08-2010, 08:23 PM   #18202
mattleegee's Avatar
Anyone have problems with a Airtronics Mx-3x for setting up to a RS?
AE ft b4.1 Ballistic 13.5 + SXX comp v2 (3-5-3-8) 1258tg
AE ft b4.1 Ballistic 17.5 + SXX comp v2 (3-7-0-4) 1257tg
BRCR
I pick things up and put them down
mattleegee is offline   Reply With Quote
Old 11-08-2010, 08:26 PM   #18203
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
-0- neutral width
Futaba 4PK
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 11-08-2010, 08:31 PM   #18204
Jochim_18's Avatar
What is the difference in setting your neutral width between high and low neutral width?
Old 11-08-2010, 08:34 PM   #18205
More width = more travel on trigger before the throttle is applied.
Old 11-08-2010, 08:49 PM   #18206
Jochim_18's Avatar
Oh well it just won't calibrate on having the neutral width on low setting has anyone have this issue? Is their anything I can adjust on my M11?
Old 11-08-2010, 08:58 PM   #18207
Jochim_18's Avatar
OK I was reading a hundreds page back lol!!! To get your neutral width lower you have to turn up your drag brake I got mine at zero drag brake....
Old 11-08-2010, 09:02 PM   #18208
pakk's Avatar
Trader Rating: 79 (100%+)
If you are having problems calibrating, you want to turn your neutral width up. Try 50.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 11-08-2010, 09:07 PM   #18209
M-Technic's Avatar
Maybe try rebinding your modules.
Old 11-08-2010, 09:27 PM   #18210
Jochim_18's Avatar
It did calibrate but I have to have the neutral width set at maximum. well I did try setting my drag break at 50% and I can not set the neutral width lower.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
