Old 11-08-2010, 12:51 PM   #18166
Regional Moderator
CarbonJoe's Avatar
Originally Posted by hpisims View Post
Looking for help. I am just getting into 1/12th scale racing just a question on do I need a receiver pack or booster which is better, and how do you hook them up. I tried to read back through as I am sure its been talked about but could not find it. Thanks
I use the HobbyKing voltage booster (less than $5). Works great. Plug it into the battery port on your Rx. I did add an inline switch on the positive side between the 1s LiPo main pack and the booster so that I can turn the whole thing off without disconnecting the main pack. I have the ESC switch in the Off position.
Originally Posted by sidecarphil1 View Post
i like the booster , it is one less thing to worrie about charging
+1. I was using a 2s LiFE pack on my WGT car (switched) plugged into the battery port on the Rx. With an RS Pro, it ate two packs within a week (one ProTek and one Epic). They were charged in between heats on a LiFE capable charger setting at 200mA (only took 70 mAh). The Epic one lasted 4 runs before swelling. Been using the $5 booster for a month without issues.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 11-08-2010, 01:24 PM   #18167
avs
avs's Avatar
i tried the protek life pack just 1 time, and then went back to a HK booster. i wonder if the charge rate needs to be even lower due to the lack of balancing port?
Tony Shimko
avs is offline   Reply With Quote
Old 11-08-2010, 01:28 PM   #18168
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
in my wgt i have a 2s 400 mah wired through the esc and can make 7-8 runs from a fully charged battery but i only do or one days worth
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 11-08-2010, 01:54 PM   #18169
gonzo416's Avatar
Trader Rating: 39 (98%+)
Originally Posted by gonzo416 View Post
Looking for a setup for WGT with tekin rs and 13.5 motor using 1S
The track is 100 X 45 crc carpet with decent traction
gonzo416 is offline   Reply With Quote
Old 11-08-2010, 02:18 PM   #18170
20 SMOKE's Avatar
5-10 motor
45-50 timing boost
3k start
8500 end
208-210 tire
38/100 ?
this is close to what i have motor comes off around 110 so there is alot of room to grow
Jamie W
Old 11-08-2010, 02:19 PM   #18171
20 SMOKE's Avatar
here is my stupid post,this is page 1212
Jamie W
Old 11-08-2010, 02:28 PM   #18172
DaveW's Avatar
Originally Posted by 20 SMOKE View Post
5-10 motor
45-50 timing boost
8500 end
Curiosity... why such a low end RPM setting?
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 11-08-2010, 02:31 PM   #18173
The low end rpm setting forces the boost to apply fully on a shorter Straight.
For my 12th scale 17.5 set up I end around 6900.
racer357 is offline   Reply With Quote
Old 11-08-2010, 02:40 PM   #18174
DaveW's Avatar
Hm. I thought boost wasnt ramped like turbo?
Old 11-08-2010, 02:53 PM   #18175
M-Technic's Avatar
Trader Rating: 15 (100%+)
Boost is applied gradually between the start and end RPM, so it is kind of "ramped."
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 11-08-2010, 03:40 PM   #18176
20 SMOKE's Avatar
it is applied every 1k rpm
Jamie W
Old 11-08-2010, 03:41 PM   #18177
DaveW's Avatar
So, if your end RPM is set at 8000, and your motor revs to 12,000 RPM at the end of the straight, you spend 4000 RPM out of boost?
Im only asking what seems like previously repeated and simplistic questions because i have been setting my end RPM for max RPM of the motor for the last few months, and gearing so the motor is close to topping out at the end of the straight.
I alter the boost and turbo amounts to change how the car feels in the infield, plus the assumed 'mechanical' motor timing to stay at the 60 degree 'cap'. It seems there is still only so much you can do with a given FDR though... as the motors i use seem to like more gear than timing advance on the edge. If it comes to adding 2 to turbo (from 10 to 12) to get what i want, ill drop back to 10 and add a tooth on the pinion.
My FDR is usually higher than what would work for others as well. I might be at a 6.7 or so and others would be 6.3 (17.5). Regardless, the setup rips on the 17.5, 13.5, and 10.5's ive worked with... but they DO run warm (usually 180+).
And yes i know driving style plays a role in motor temps and FDR's. Im no Pro, but im no point-n-shoot type of driver either.
Anyways... just trying to make sure i grasp this concept fully. Im about to try running an 8.5 boosted... and raised my eyebrow when i found its max RPM was 30,100.
Old 11-08-2010, 04:08 PM   #18178
darrenoakley's Avatar
Agreed when I run 17.5 in my 12th i start at 2500 and finish at 5000. Works really well. I have tried widening the rev range but just not as good. Only tried on our small track though.
Xray x11
Xray T3 011
darrenoakley is offline   Reply With Quote
Old 11-08-2010, 04:30 PM   #18179
JayL's Avatar
track:Speedworld
car xray T3
n***k 17.5 motor timing (25) backed off 5 degrees from stock
2s lipo
tekin rs
gearing 6.34
boost 50
start 2790
end 11000
delay 0
turbo 12
ramp 2
drag brake 15
initial brake 0
initial throttle max
current limit none
motor comes off after every 6min race at 134 degrees F
what can I do for more speed as I must be missing some with that cool motor and no fans?
JayL is offline   Reply With Quote
Old 11-08-2010, 05:04 PM   #18180
20 SMOKE's Avatar
add 2-3 to boost or turbo,not both
Jamie W
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
