Old 11-05-2010, 07:36 AM   #18106
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
there are a few mod setups that you can start with and work from there
http://www.teamtekin.com/hotwire/ESC...-RS-TC-4-5.pdf
http://www.teamtekin.com/hotwire/ESC...n-TC-BD6-5.pdf
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 11-05-2010, 07:39 AM   #18107
spar9368's Avatar
Trader Rating: 53 (100%+)
Send a message via MSN to spar9368
I've read them before, but there are some missing bits, like timing advance and turbo. Does that mean '0'?
Also, I'm looking for some infos with SP v3 motors. So if anyone has any, please.
Cheers
Anyone needs BRAND NEW OS Engines, Please PM me.
spar9368 is offline   Reply With Quote
Old 11-05-2010, 08:09 AM   #18108
jammincrtjames's Avatar
Do the settings from 208 transfer over to 212? I mean should the performance be the same with regards to turbo, boost etc?
NEXUS RACING www.nexusracing.com | FANTOM RACING www.fantomracing.com
ORCA www.orcarc.com | TURTLE TRAX / www.turtletraxraceway.com
"If you're not first...you're last!"
jammincrtjames is offline   Reply With Quote
Old 11-05-2010, 08:13 AM   #18109
20 SMOKE's Avatar
yes
Jamie W
Old 11-05-2010, 08:19 AM   #18110
20 SMOKE's Avatar
Cheers
you are asking for info that 98% of people do not run.with a mod motor it is not recommended to use sensored you can but you need to be very conservative as it comes in fast.start with a range of 5k start and a 25k end o motor 20-25 timing boost 5 -10 turbo this is what i would do is start low and work your way up but slowly
Jamie W
Old 11-05-2010, 08:42 AM   #18111
M-Technic's Avatar
Trader Rating: 15 (100%+)
Hey all,
Just got myself into 1/10 Modified racing in my home track, and I need few starting points for ESC setups.
My home track is a large/fast open asphalt track with long straight and big sweeper, and I'm running RS Pro 212 version.
I have a few 4.5 ~ 5.5T Speed Passion V3 motors and gearing range is about late 8 to early 9.
I know low turn motors normally don't run timing boost and turbo, but I know some does and there must be a significant difference. I've been playing with Stock classes for a while, and just want to know how to setup timing advance/timing boost/turbo.
Thanks in advance.
Yes, it can be a big difference but in my opinion it is not needed! We made a 4wd touring car do a wheelie with a 4.5 and a high boost/turbo Tekin setup. The car was so fast it was having blow-overs like a hydro boat does.
Just start super conservative and work your way up slowly (wide RPM range and low about of boost). Personally I run a 4.5t and an LRP Sphere for mod! No timing, profile 1. The only people running boosted profiles in mod in Florida are running 10.5-7.5t motors.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 11-05-2010, 09:25 AM   #18112
spar9368's Avatar
I understand what you guys talking about, and yes I thought the same thing. But if you look at those two Mod setups, then you can actually find both drivers were running timing boost of 30~35. Scooby Horton runs turbo as well, which I honestly don't have gut to try it out.
From those setup sheets, timing advance remains "blank" for both drivers, which I want you guys to confirm that it means 'zero'. What I tried on my 12th scale was running 10~15 timing advance, and 45 timing boost and zero turbo, which was nice and quick. Performance of the motor was good in every second of 8 minutes, but somehow I'm struggling with 1/10 mod racing.
So, do you guys all suggests 0 timing advance, 0 timing boost and 0 turbo, to be safe? If that's what we want, then I wouldn't have any drama, but wouldn't that be pretty slow?
Old 11-05-2010, 09:52 AM   #18113
TrevCoult's Avatar
Some of you guys are getting confused as to when timing advance is used and when it isn't.
If you are running in sensored mode, timing advance does absolutely nothing unless your sensor lead breaks. The things that make a difference in sensored mode are boost and turbo. It is possible to set timing advance in sensored mode purely because it comes into operation if your sensor lead breaks and the RS switches into sensorless mode, and for no other reason.
If you are running in dual mode, the only thing that makes a difference is timing advance, and you can't set boost or turbo.
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 11-05-2010, 10:01 AM   #18114
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Trev is right.
Timing advance is ONLY used in Dual mode OR if loose your sensor lead, period.
Timing boost and Turbo boost are ONLY available in sensored only mode.
Most guys boosting any type of mod aren't using 3.0-5.0 turn motors. They're using 6.5's and 7.5's in TC with boost and turbo.
The window of error is narrower the lower the turn of the motor is. You can get away with some boost and turbo on a 6.5 but a 3.0 turn motor will NOT tolerate much of it at all.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 11-05-2010, 10:48 AM   #18115
spar9368's Avatar
Trev
Originally Posted by Randy_Pike View Post
Trev is right.
Thanks for your input and yes this is what I read on Tekin website.
Since timing advance is irrelevant, as my sensor cable is strong enough, let me focus on timing boost. From the two above setup sheet, both of them were using 30~35 boost. Also, Scooby with 6.5T was running 14 turbo as well. My home track normally suits 4.5~5.5, so I was thinking maybe 4.5 with 30 timing boost or 5.5 with 35 boost. No turbo at all, since I don't have guts to do so. I was hoping to get some starting point, then again I'm going around the same circle.
Anyway thanks all for the info and please let me know if you have anything to add/share.
Old 11-05-2010, 04:46 PM   #18116
I am running 4.5t Orion with RS Pro FDR 1:7.6 large track.
Speed is about 110 km/h
timing boost 30
turbo 10 or 14
start rpm 7000
end rpm 21000
Trottle prof 1
delay 0.3 or 0.5
Motor temp 85 degr. C
ESC temp 80 degr. C
It runs very well no thermal issues
Hope this helps, this work only with RS Pro, RS will smoke with
this settings.
eded1 is offline   Reply With Quote
Old 11-05-2010, 05:13 PM   #18117
JayBee's Avatar
Trader Rating: 31 (100%+)
Any other kick ass setups for running 17.5 w/BOOST?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 11-05-2010, 05:57 PM   #18118
M-Technic's Avatar
Hara's setup from the Tekin web site is pretty spot on.
Old 11-05-2010, 06:05 PM   #18119
tallyrc's Avatar
isnt that 208? what are you doing with the other settings?
namely initial throttle?
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 11-05-2010, 07:52 PM   #18120
JayBee's Avatar
Sorry guys I meant to add that this is for a 1/12th application
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
