Old 10-30-2010, 09:47 PM   #18031
mikel33's Avatar
Trader Rating: 2 (75%+)
Default Issue running 1S
Ran into something strange with a new-out-of-the-box speedo in 1s config.
Speedo does not turn on when I plug the receiver battery in. I have to power it through the speedo switch. I get the right chimes and beeps and can calibrate the speedo but when I apply throttle I get very little accel. Its like the 2S cut-off has activated. no power at all.
anyone run into this before? could use a little help.
thanks in advance.
Michael Larson.
Village Idiot Racing - Now accepting driver applications.
mikel33 is offline   Reply With Quote
Old 10-30-2010, 10:43 PM   #18032
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Makes me think your receiver pack isn't actually making contact or providing power even though it is plugged in. I would check loose connections in the lipo, or that the lipo is in good working condition. Try another receiver pack to trouble shoot with.
Old 10-30-2010, 11:55 PM   #18033
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
What are you using for a receiver pack? Where are you plugging it into?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 10-31-2010, 08:34 AM   #18034
avs
avs's Avatar
thanks in advance.
you didn't state whether the receiver and steering servo are working. first get the steering servo to function, i use a 5cell receiver pack from a nitro car to get things setup. then add the speedo.
Tony Shimko
avs is offline   Reply With Quote
Old 10-31-2010, 03:15 PM   #18035
Default 212 install
More a point of curiosity I guess. I read the instructions on the website/watched the video, changed the Explorer settings as directed but don't have Tekin.esc file on my disk. Running vs 208 under Windows 7.
208 runs fine, should the file be there? I don't want to mess up the install
yellowshark is offline   Reply With Quote
Old 10-31-2010, 04:37 PM   #18036
How can I reduce RS Pro temps running a 3.5 in a TC on asphalt with nitro foams? Right now all temp lights lit up using no boost/turbo in sensored mode but current limiter set to off. Would using the current limiter help reduce temps? Would running in Dual mode with no timing be better? Motor is a Ballistic 3.5 at default timing. My fdr is 10.94 using 65mm Nitro foams. Motor temps are at 150F after a full 6000Mah 60C pack. I need to be able to run back to back packs without thermalling as I'm trying to prove a point to some nitro guys.
spongerX is offline   Reply With Quote
Old 10-31-2010, 05:22 PM   #18037
mikel33's Avatar
thanks everyone for the suggestions! we found it. rx and steering were working fine. The middle pin (red) in the receiver for the speedo was broken but still in place - it looked ok but when I started poking at the pins it came apart. what an adventure. swapped on rx's and it works fine.
Michael Larson.
Old 10-31-2010, 05:50 PM   #18038
Team Tekin
Randy_Pike's Avatar
Run dual mode, add a 2nd TT3520 power cap and a small fan blowing on the solder posts. You're attempting to run a setup that is on the edge.
Old 10-31-2010, 08:17 PM   #18039
Hey guys
had someone help with setting up the rs pro and was running great.
had another friend download 212 which seem to have lost the perameters for the timing,boost and turbo ...would anyone have any ideas to get me in the ball park right now I have 70 in timing advance 48 for the boost ..turbo is 15 delay is .02 and the ramp is 2 this set up seem to bring the temp up a little to around 50 celcius ..
fasteddie d is offline   Reply With Quote
Old 10-31-2010, 08:19 PM   #18040
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by fasteddie d View Post
Hey guys
what do you need to know
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-31-2010, 08:49 PM   #18041
Also I am running single cell 1/12 scale with a speedpassion 17.5 motor and boost rpm are 2355 to 2999 before the download the motor was running much cooler.
A friend advised that the motor really shouldn't get any hotter then around 60c .
I feel I should try and bring down the temp in the motor and the boost delay felt like came on right away so I increased the delay in the turbo as it seems to come on right away .
I am brand new to the electric scene so thanks for bearing with me.
Old 10-31-2010, 08:59 PM   #18042
bukil's Avatar
Trader Rating: 39 (100%+)
Also I am running single cell 1/12 scale with a speedpassion 17.5 motor and boost rpm are 2355 to 2999 ....
Holy momma....
☆ ActivRC ☆
bukil is offline   Reply With Quote
Old 10-31-2010, 09:07 PM   #18043
20 SMOKE's Avatar
i would say so,you are getting 48* of timing at once your range is 644 go with a 6k-7500 end and a 3k start up
Jamie W
Old 10-31-2010, 09:13 PM   #18044
Still Bill's Avatar
Sorry, you have not provided enough information on your settings for anyone to make any valid comments.
Sorry, your high RPM setting of 2999 defies convention...Is that right? The separation of low and high should be in thousands of RPM as opposed to just hundreds. I would suggest that you thoroughly read this thread and concentrate on posts about 1/12 scale stock car setups. The Tekin website should also enlighten you about such settings. Or talk with local fast racers for their takes on what to do with your RS settings. Take your time and enjoy the ride. Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 10-31-2010, 09:46 PM   #18045
JayBee's Avatar
Trader Rating: 31 (100%+)
Anybody out there running an LRP X12 13.5 with 4-dot timing? What are you rolled out at in your 1/12th scale? *no boost*
Any new 212 settings yet?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
