Old 10-28-2010, 07:00 AM   #18001
theisgroup's Avatar
hey jay, i would not worry. we have guys running around 92mm roll out and I am at like 105mm in 17.5 it just depends on the motor and if it is torque or rpm motor. just watch to see if the car is slow out of the corners and the lap times. also how much it falls off. in 8min it should not be more the .5sec
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 10-28-2010, 08:59 AM   #18002
mangoman's Avatar
Originally Posted by JayBee View Post
That's a 72t spur & 52t pinion, with 41.10mm rears.
41.1mm rears? what car is that in? do you mean 51mm on a 12th scale?
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 10-28-2010, 09:02 AM   #18003
M-Technic's Avatar
Trader Rating: 15 (100%+)
I switched back to my Tekin last night (had been running a Speed Passion because it had more rip). Installed v212 (had no problems), got my baseline setup and then started messing with the minimum throttle. It definitely helps a lot with the off-neutral feel. Its hard to call it more rip, because it doesn't make much difference if you only lifted a little bit. But in hairpins, after braking or coming off neutral, it helps. I was running 25 minimum throttle by the end of the night in 17.5.
After getting my baseline setup, I tried my new Duo3 motor as well. WOW. That thing is a beast. It's very similar to the Duo2... Just faster and more torque. The combo of the Duo3 and v212 was killer.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 10-28-2010, 10:15 AM   #18004
JayBee's Avatar
Trader Rating: 31 (100%+)
Are you nuts! Lol.....51mm rears! These are 1/12th scale pan cars....not trucks.
Oh yeah....what Korey says below....
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-28-2010, 10:36 AM   #18005
Korey Harbke's Avatar
Here in the US, carpet tracks generally have WAY more traction than others . Running small tires is a way to be fast. At one of the recent big trophy races here people were running the tires all the way down to the rims
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 10-28-2010, 12:16 PM   #18006
Originally Posted by Rob long View Post
Has anyone got a setup for the rs with a nosram x12 motor running in a touring car on carpet the straight is about 60ft long with a tight ish infield cheers
Anyone please???
Rob long is offline   Reply With Quote
Old 10-28-2010, 05:21 PM   #18007
Anyone please???
What wind?
yellowshark is offline   Reply With Quote
Old 10-28-2010, 05:51 PM   #18008
mangoman's Avatar
Didnt realise you could cut them that small, i thought you start to hit the rim at around 44 or something.
www.smaracing.org
Old 10-28-2010, 06:09 PM   #18009
Originally Posted by yellowshark View Post
What wind?
I think he is running an X12 13.5 in a MI4 LP on a carpet track using rubber tyres
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 10-28-2010, 06:29 PM   #18010
HarryLeach's Avatar
Send a message via AIM to HarryLeach
With the newer wheels, you start hitting plastic at 38.0mm
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 10-28-2010, 06:31 PM   #18011
wingracer's Avatar
Trader Rating: 24 (100%+)
I believe the newer big rims are 38 or 39mm. Older wheels were even smaller than that.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-28-2010, 07:18 PM   #18012
BCbud's Avatar
Trader Rating: 37 (100%+)
I just happen to have some old style Jaco rears and new style CRC. Both ore brand new never run tires.
----------------------Outside rubber------Rim
CRC ----------------------48.5mm--------37.5mm
Jaco----------------------52.0mm--------35.0mm
The old Jacos have lots of rubber.
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Old 10-29-2010, 09:49 PM   #18013
smracer31's Avatar
Send a message via AIM to smracer31
Hey guys, having some trouble getting my green light flashing
Ive selected Timing profile 1 on the hotwire, affirmed that the tp on the esc is led 1. i get two flashing lights on the esc, but no green light to tell me its on the stock profile. I assume im simply overlooking something.
Any help is appreciated.
smracer31 is offline   Reply With Quote
Old 10-29-2010, 09:52 PM   #18014
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
there is no green light on the esc only the Hotwire,you can access the stock profile by using the pit tune mode
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-29-2010, 09:53 PM   #18015
HarryLeach's Avatar
Zero Timing profile on the newest software [firmware v212] has TWO blinking lights at neutral, so show the difference from firmware v208, which had a problem.
Sounds like you've got it set up just fine.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
