Old 10-26-2010, 07:47 PM   #17956
JayBee's Avatar
Trader Rating: 31 (100%+)
Does anyone run a 1s MuffDogg 13.5 w/no boost in a 12th scale? I know that the settings are limited, but any starting suggestions?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-26-2010, 08:16 PM   #17957
bkspeedo's Avatar
Try starting around 3.5" roll-out and 10deg or 2 ticks of positive motor timing. Check motor temp after 4 min. These are high torque lower rpm motors so your should be able to run a large roll-out. I would not go more than 10deg of timing on the motor.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 10-26-2010, 08:38 PM   #17958
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by rambolin View Post
Hi Randy
Any idea how long it will take to receive my 'Return Authorization Number'. I lodged it last week.
Sorry for being a pest but I am getting desperate. I had to cannibalize my son's car to prepare my car for the coming weekend. There has been no reply from Tekin whatsoever so far.
Regards, Rambolin
Please try online support tomorrow in the morning. You can also call the main office.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 10-26-2010, 08:51 PM   #17959
M-Technic's Avatar
Trader Rating: 15 (100%+)
Any chance of fixing the download server tonight?
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 10-26-2010, 09:28 PM   #17960
avs
avs's Avatar
Originally Posted by RedBullFiXX View Post
Had an opportunity to race with the new 212 update last weekend in 1/12 10.5 boosted.
Great update guys.
The new throttle, and brake settings really make the RS That much better.
One can truly customize the feel of everything now.
Well Done, and thanks again for the free updates
how can you say that? 'free' improvements are ruining this hobby! people should have to pay dearly for every improvement and even for stuff that isn't an improvement. get your priorities straight man! (sorry, couldn't help it)
Tony Shimko
avs is offline   Reply With Quote
Old 10-26-2010, 09:45 PM   #17961
JayBee's Avatar
Thanks brah....3.5"= 88.9mm. With my 41.25mm rear tires, 72t spur/50t pinion, I'm @ 89.9mm. I'm also at 10-degree endbell timing. So I'm right there. I will give that a go for tomorrow evening.
Thanks again.....but particular my settings are as follows:
*Drag brake- OFF
*Brake strength- 40
*Push control- OFF
*Brake minimum- 10
*Throttle profile- 5 I'm I okay here?
*Neutral width- 2
*Current limit- OFF
*Reverse speed- OFF
*Throttle minimum- 10 I'm I okay here?
Being that this is my first Tekin....bare with my learning curve
Old 10-26-2010, 10:16 PM   #17962
avs
avs's Avatar
*Drag brake- OFF
*Brake strength- 40
*Push control- OFF
*Brake minimum- 10
*Neutral width- 2
*Current limit- OFF
*Reverse speed- OFF
for WGT 13.5 noboost, a suggested starting point(from IIC) 8degree endbell timing with 85mm rollout(with murfdogg 1s)
so a little more timing and/or a little more rollout sounds like a reasonable starting point.
Tony Shimko
Old 10-26-2010, 10:35 PM   #17963
JayBee's Avatar
I will be running this in a 1/12th brotha so hopefully I'm safe . Not a whole lot of practice before we run. Basically, this is a spot where we have to hit the ground running when we show up. So I better have or be damn close to having my ISH together
Old 10-27-2010, 12:44 AM   #17964
Trader Rating: 8 (90%+)
Originally Posted by VRacing View Post
What have you figured out so far on your own?
That am needing alot more gear than what it should really be. I forget the setting but I believe I'm at a 5.3 fdr and running 60deg of timing at I tick past neutral on the ballistic ramp at 2 and boost is pretty high. C2 rpm's I beleive.
I will find my exact boost setting in the A.m.
Houston,Texas
Serpent 733 EVO
Mikes Hobby shop-Porter Texas/ Gulf coast Raceway"Electric Is For Hairdryers"..Eric Koger
Chris [email protected]
Tha Skinny is offline   Reply With Quote
Old 10-27-2010, 02:51 AM   #17965
Originally Posted by M-Technic View Post
What value are you guys running for minimum throttle in 17.5? Maxed out or what? How much does it affect the temp of your motor over 6 minutes?
I use min throttle at 10, which is enough for me. Really gives it that extra "punch" in the low-end. It had no effect in temp for me. With 208 my motor got 43C and with 212 and min throttle I am at 46C on the motor, but I have also added more timing after that, so I don't think the slightly increased temp is because of min throttle.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 10-27-2010, 08:33 AM   #17966
jjfo80's Avatar
Bullsh*t!!! everything in the world has free updates..... If the firmware or software is updatable then its free. When they run out of software to update they make new hardware and you pay for that and start all over again.... Here is 20cents to buy a clue. ( sorry couldnt help it ha ha ha)
Owner of Precise Fuels and RC and Podified Fuels
jjfo80 is offline   Reply With Quote
Old 10-27-2010, 09:06 AM   #17967
I would say that the price of the updates is worked into the price of modern day updatable products.
@avs: why do you say that free updates are ruining our hobby? Why should we pay for them?
adam lancia is offline   Reply With Quote
Old 10-27-2010, 09:23 AM   #17968
Team Tekin
Randy_Pike's Avatar
Download server is fixed guys. Sorry for the inconvenience.
Old 10-27-2010, 09:44 AM   #17969
M-Technic's Avatar
Thanks. I am going to try it out tonight.
Thanks Randy.
Old 10-27-2010, 09:58 AM   #17970
He was joking
Jeff Reinhart
Team losi 8ight-t 2.0 Team Losi 10 SCTE
RcPro Series Alberta 2013 4X4 Pro Mod Short Course 2nd place
RcPro Series Alberta 2012 4X4 Pro Mod Short Course 2nd place
RcPro Series Alberta 2011 4X4 Pro Mod Short Course 3rd place
JReinhart is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
