Old 10-25-2010, 08:52 AM   #17896
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
3.7 x kv = rpm
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-25-2010, 08:56 AM   #17897
If you do the math on a 3.7 volt 1S it will only turn 8800 max. That's "no load", meaning free spinning on the bench, not even in the car yet. When you go into a car under load, it becomes dependent on your gearing. Each driver has to gauge it from there. You will be substantially under that max figure.
Dude, Go RRReally FFFast - When something gets in your way - Turrrnn
VRacing is offline   Reply With Quote
Old 10-25-2010, 09:06 AM   #17898
Krio's Avatar
Trader Rating: 150 (99%+)
Just keep in mind that adding boost/turbo can effectively multiply the max rpm by roughly 1.4 to 1.8.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 10-25-2010, 09:29 AM   #17899
DaveW's Avatar
Originally Posted by VRacing View Post
Your RPM range is to high. the motor never runs out of the top end of the RPM setting, then your hitting it with 10 Turbo while it's still trying to apply Boost. Common issue for most users. You may try moving your RPM range down to make room for Turbo to apply independently. Also, move the Delay setting a few tenths longer. The goal is "coordinate" the settings, not "overlap".
I dunno man, my settings overlap... and my TC is quite the rocket. Spacebound even...
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 10-25-2010, 10:56 AM   #17900
Here's a question: Why doesn't the Advanced option tab open up when I try to click on it? That's the one to see which version you're using.
AreCee is offline   Reply With Quote
Old 10-25-2010, 11:03 AM   #17901
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
It should. When that happens to me I just close it out and restart it. It used to happen to me on V203 after I applied setting or updated. It hasn't happened to me in V212 yet.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 10-25-2010, 11:09 AM   #17902
Ok, I'll have to try that. I wanted to verify if the ESC was indeed updated and it wouldn't open but I didn't try closing it and then reopenning it.
Old 10-25-2010, 11:18 AM   #17903
Originally Posted by DA_cookie_monst View Post
looks like you are overheating the motor maybe, usually a problem caused by overtiming the motor.
Drop the Boost by 8-12' to start with and also activate the limiter to around 90-95%.
Thanks for the suggestion...I will try reducing the Boost however I forgot to include the fact that the motor is coming off @ ~115 F so I'm not convinced that it's actually overheating...I've had motors go up to 160 F with no ill effects in the past.
I think COOKIE is right on with this! Dropping the amount of Boost should help. If you want to keep tinkering beyond that, here are a couple of other things. Your RPM range is to high. the motor never runs out of the top end of the RPM setting, then your hitting it with 10 Turbo while it's still trying to apply Boost. Common issue for most users. You may try moving your RPM range down to make room for Turbo to apply independently. Also, move the Delay setting a few tenths longer. The goal is "coordinate" the settings, not "overlap".
Thank you for that...I suspect you're right about the RPM range although I know several other drivers that are using the same settings on this track and they are not getting the same problem that I'm experiencing.
Just a thought...I vaguely remember somebody mentioning an issue with KO radios (I use an EX-1 UR) not registering full-throttle even if the trigger is pulled fully. Is it possible that at the start of the race I'm getting full throttle but part way through it drifts down enough to cause the reduced performance? If so is there any fix for this issue?
Thanks again for the assistance!
Cheers,
Mike
Mike
Hyper_Mike is offline   Reply With Quote
Old 10-25-2010, 01:06 PM   #17904
jkirkwood's Avatar
Cheers,
Mike
If you suspect that to the be the case, pull your throttle EPA down 10%, recalibrate the ESC, and then put the EPA back to normal. Run a pack and see if that makes a difference.
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
Old 10-25-2010, 02:07 PM   #17905
TVMRocket69's Avatar
Send a message via AIM to TVMRocket69 Send a message via Yahoo to TVMRocket69
Randy, can the regular RS handle lower than 5t with 1s lipo?
Bob Walker Jr.-Sponsor's-
AnswerUSA-RC Team Driver, G's R/C Raceway Team Driver, RBMods Team Driver, Kosmic R/C Fuel Team Driver, MurfDogg Motorworks Team Driver, Serpent S811B, Serpent S811t, MurfDogg Powered V-Desizn Carpet Ripper 5
TVMRocket69 is offline   Reply With Quote
Old 10-25-2010, 02:12 PM   #17906
pakk's Avatar
Trader Rating: 79 (100%+)
You are going to want a pro for 1s mod. I tried a 6.5 and had thermal issues with a regular RS. Yes, its less voltage but because of that, it's more current.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 10-25-2010, 02:33 PM   #17907
Over-rev's Avatar
Do you have to have the capacitor soldered into the ESC on the RS Pro? I have seen some builds where they seem to not run the ESC capacitor. I know they are not to be used on the motor but I am wondering why they still need to be used on the ESC.
And behold, a pale horse, and he who sat upon it, his name was death, and Hades followed him - Revelation 6:8
ΜΟΛΩΝ ΛΑΒΕ
Over-rev is offline   Reply With Quote
Old 10-25-2010, 02:37 PM   #17908
pakk's Avatar
Tekins says to always run a cap so I always do. With that being said, I have gone several races in both 1s and 2s 17.5 classes where the cap fell off and I didn't know. It didn't seem to make a difference, but that's 17.5.
*Photon* *SC10 4x4*
RCRD
Old 10-25-2010, 02:46 PM   #17909
theisgroup's Avatar
jim and randy say to run a cap and i run a cap. they also say to install it as close as you can to the esc.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 10-25-2010, 03:00 PM   #17910
I don't run the cap, and so far it has been okay. I have had one glitch, but that could have been the radio, because I haven't had any problems since.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
