Old 10-22-2010, 09:39 AM   #17806
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Yes
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 10-22-2010, 09:57 AM   #17807
georgec's Avatar
Originally Posted by PitNamedGordie View Post
Repost! I just thought the picture should be BIG!
WOW...Those puppies look sweet..WHEN...WHEN????
georgec is offline   Reply With Quote
Old 10-22-2010, 11:27 AM   #17808
Originally Posted by YoDog View Post
Hello all,
Windows 7 handles some files a little differently than XP.
Tekin has instructions on what to do for upgrading hotwire on the W7 platform.
There is a file that is stored in the virtual store directory that must be deleted prior to installing the new update. Windows 7 will use this file to restore the program to the previous state if the new program is installed in the same directory as the old version. Not sure why Microsoft does this but it's not the first time I've had to deal with the virtual store.
Good luck
Thanks! Your method works in regards in uninstall v208 cleanly. I needed to goto the VirtualStore folder and manually delete the 'Tekin Hotwire' folder. Once I did that, then install v212. Now v212 is working as advertised!
hardmankam is offline   Reply With Quote
Old 10-22-2010, 12:55 PM   #17809
Randy, someone. Can you conform how this latest upgrade works?
Do I have to update the speedo and re-calibrate to radio? Or, will it just update my computer and then read the settings from the speedo without the whole update/re-calibrate malarky?
As an aside, I used the profile with the bug and noticed that it didn't take the end rpm setting. Thinking it was me, I tried again, and again. At the third attempt it read correctly the setting I gave it! I'll update, of course, but just thought I'd note my experience.
Look forward to confirmation of the update procedure, please. Thanks.
SlowerOne is offline   Reply With Quote
Old 10-22-2010, 01:49 PM   #17810
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
After installation of the new hotwire software, when I plug in my speedos, it prompt's me to update the software then. Then you will need to recalibrate your radio to the speed control. The same process as the move from 203 to 208.
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 10-22-2010, 01:50 PM   #17811
TrevCoult's Avatar
Hi Peter,
Always re-calibrate the radio after a software update. Then reapply all your settings, they will almost certainly have been lost after updating the speedo. The update effectively resets the memory where the calibration and settings are stored.
I just thought, if you mean upgrading from 5.7.1 to 5.7.3 HotWires, you don't need to update the speedo software again, that is still 212 and hasn't changed.
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 10-22-2010, 02:17 PM   #17812
RC_Robert's Avatar
Default RS Pro won't turn off.
Originally Posted by RC_Robert View Post
This is really strange. Big race coming in two weeks. I bought a new RS Pro for it yesterday. Install as per instructions. As soon as I plug in the 1cell LiPo the speedo comes on. Turn off the power switch, speedo stays on. Disable the power switch speedo stays on. Disconnect the sensor wire speedo stays on. Disconect the receiver speedo stays on. Disconnect the cap speedo stays on.
With everything disconnected and the power switch disabled as soon as I plug the main battery into it (1cell LiPo) it turns on. Even tried a 4 cell NiMh. WHAT THE HECK IS GOING ON HERE???? This is not my first speedo and have had many NOVAKs. Me and my race buddy's have never seen this. We updated the speedo with the latest ver software and it still turns on as soon as it is plugged into the main battery. A factory reset did not help.
IS THIS NORMAL? This is a brand new speedo. CRAP
any ideas?????
Hello
A good friend called me today and asked me to open it up by removing the four screws and check the solder connections. I was worried about voiding my warranty but thought I would try. He was right! Where the switch is wired to the circuit board a very fine single strand of wire had bridged the two connections. I needed a magnifying glass to see it. I clipped it and now it works fine. WOW. Who would have thought of that???. I was so stressed out about having a new speed control not working that I don't think I slept at all the last two nights.
Thanks to every one for all the suggestions and help.
I am ready to race.....
RC_Robert is offline   Reply With Quote
Old 10-22-2010, 02:23 PM   #17813
JayBee's Avatar
Trader Rating: 31 (100%+)
Those would look nice in a TOP car
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-22-2010, 03:05 PM   #17814
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
send it out and get it coppered
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-22-2010, 03:20 PM   #17815
JayBee's Avatar
Too bad Jason doesn't make a sedan....
Old 10-22-2010, 03:24 PM   #17816
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
He has one that he was working on a few years ago with a nice gold chassis im sure it still floating around his desk somewhere
Old 10-22-2010, 03:35 PM   #17817
jarkkom's Avatar
Send a message via MSN to jarkkom
Guys are reporting they get faster lap times with the new software with zero timing profile.
If the old software wasnt cheat, the new one IS!! Whats up?!
www.eurorc.com/?ad=jm
jarkkom is offline   Reply With Quote
Old 10-22-2010, 03:41 PM   #17818
Team Tekin
Randy_Pike's Avatar
Not likely.
I just spoke to a few more team drivers running 208 back to back to 212 and they're within .02 seconds on lap times between them.
They do all agree however that the new minimum throttle and brake settings are the S__T!
Old 10-22-2010, 03:48 PM   #17819
Green Machine!'s Avatar
Send a message via MSN to Green Machine!
Just curious. Isn't the min brake and min throttle (0-30 correct?) on the new 212 the same adjustment that I use on my Futaba 4PK (throttle accl)
Team Kamikaze.
XCEED RC
SERPENT
FUTABA
SSCLCG
Green Machine! is offline   Reply With Quote
Old 10-22-2010, 03:50 PM   #17820
wingracer's Avatar
Trader Rating: 24 (100%+)
Timing isn't the only thing to effect lap times.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
