Old 10-21-2010, 11:24 PM   #17791
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Originally Posted by bkspeedo View Post
I've looked through all the documentation i can find and have not figured out how to use the buttons on the RS to switch between the saved C1 & C2 or preset timing profiles.
Does anyone know how to do this?
Press "Mode" in the ESC 5 times
then Press "Set" to the desired setting (#6 and 7 is C1 and C2)
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 10-21-2010, 11:26 PM   #17792
VooDooPH's Avatar
Originally Posted by goBezerk View Post
One question though, why on both the 208 and 212 versions, can you not set the other parameters independantly on C1 and C2? Being an off-roader, if grip is down, I'd use C1 with the initial throttle turned down and the current limiter etc and C2 have them turned back up for when the grip comes up...problem seems if you turn them down it does it to both C1 and C2....yes yo could do it with the timing too but....otherwise couldn't be happier
+1
Old 10-21-2010, 11:32 PM   #17793
Originally Posted by Randy_Pike View Post
I wasn't saying it was done intentionally. Sometimes computers hiccup and stop USB operation,etc. It happens.
I would like everyone to please go to www.teamtekin.com/hotwire.html
and download the latest software update. The original version 212 had a display error while using the C2 throttle profile.
To check to make sure you've got the latest and most current plug in your hotwire and hit the "help" button. It should read Hotwire version 5.7.3
Hi Randy
Can you post something on how the new throttle profiles C1 and C2 work?
light
Gorden
light is offline   Reply With Quote
Old 10-22-2010, 12:49 AM   #17794
TrevCoult's Avatar
Originally Posted by light View Post
Hi Randy
light
Go to
http://www.carsrcracing.co.uk/?p=244
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 10-22-2010, 02:37 AM   #17795
rambolin's Avatar
I had the same problem and ended up with no lights etc on the esc afterwards. Tried downloading again, turning off PC and repeated unconnecting/reconnecting of Hotwire etc. For me, I reloaded 203 (happened to have it on another pc), it then turned on OK. I then retried 212 with the Hotwire in another USB port, it took two attempts and it's now sweet and working as normal.
Thanks for that - anyone that could give me 203 to try?
Regards, Rambolin
rambolin is offline   Reply With Quote
Old 10-22-2010, 04:35 AM   #17796
Senna Racing's Avatar
I have it at home some were so if you send me your email I will try send it to ya when I get home
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 10-22-2010, 04:54 AM   #17797
rambolin's Avatar
Default 203
Hi Senna Racing
Sent you an eMail...
Old 10-22-2010, 06:02 AM   #17798
goBezerk's Avatar
Send a message via Skype™ to goBezerk
Regards, Rambolin
Oops, I should have said 208...might gel a little better than 203
► Paul Sims - KRCORCC - BRCCC - TFTR
► R/C racin', 1 percent car, 99 percent driver
► BEZERK RC on Facebook, PayPal accepted
► PROLINE - TEAM AE - GFORCE - R/C Race Supplies
goBezerk is offline   Reply With Quote
Old 10-22-2010, 07:22 AM   #17799
Originally Posted by TrevCoult View Post
thanks Trev
but I only see info on the Timing Profiles there I'm looking for the Throttle Profile's c1 and c2
Gorden
Old 10-22-2010, 07:27 AM   #17800
Krio's Avatar
Trader Rating: 150 (99%+)
thanks Trev
Throttle Profiles C1 and C2 are timing profiles that you can customize and then save to either C1 or C2. Select C1, set your timing variables to whatever you want, then hit apply. Then select C2, set your timing variables to whatever you want, then hit apply again. Now when you select led #6 on the onboard interface under TP the timing for C1 is selected or C2 if you select led #7.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 10-22-2010, 07:32 AM   #17801
VooDooPH's Avatar
C1 & C2 are user updateable profiles. you can save different settings (currently different timing/boost settings) on either one. you can then select one to use while on the track without having to plug into your pc. personally, this comes in usefull as the traction at our local track changes from midday (low traction) to late in the afternoon (high traction). For this, i'd set up a wider rpm range (i.e. 5k-15k) in C1 and a narrower range in C2 (5k-12k). during the qualifiers when traction is still low, i run C1. during the finals, when the traction picks up, i switch to C2. to switch between C1, C2, and the other profiles (1-5), press "mode" 5 times to get to the TP light, then press "Set" to get to the TP profile of your choice. hths.
Old 10-22-2010, 07:54 AM   #17802
Originally Posted by Team Pink View Post
Here something for you guys incase you have not seen it..
Beautiful! When are those motors available?
dasdaman is offline   Reply With Quote
Old 10-22-2010, 08:30 AM   #17803
JayBee's Avatar
Trader Rating: 31 (100%+)
What he said....
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-22-2010, 08:43 AM   #17804
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Repost! I just thought the picture should be BIG!
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 10-22-2010, 08:57 AM   #17805
I wasn't planning on hitting the iHobby Expo this weekend, but will these motors be on display there?
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
