Old 10-21-2010, 11:13 AM   #17761
locked's Avatar
Originally Posted by hardmankam View Post
I cannot update v208 to v212 on my PC#1. So I have installed v212 on my PC#2 and it works. However, when connecting back on PC#1 with Hotwire v5.2.1 installed, the software still lists v208 as the version to update to (see attachment).
It seems like v208 has not completely uninstall itself on my PC#1. If so, what is the proper procedure to uninstall previous version of the Hotwire? Many thanks!
Try uninstalling it first from add/remove programs (start button-settings-control panel-add/remove programs)
The menu navigation may vary depending on version of windows and personal settings for the way the start menu displays. You might not have a "settings" menu. In that case you should see "control panel" in the right side of the start menu instead.
locked is offline   Reply With Quote
Old 10-21-2010, 11:15 AM   #17762
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
un install it again and re install 212 on the 208 pc does it offer the auto extract,and also look at the video even though it was for old versions it is still helpfull
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-21-2010, 11:50 AM   #17763
hairy's Avatar
The main diff b/w PC#1 and PC#2 is:
PC#1: Win7, 64 bit
PC#2: WinXP, 32 bit
I could be wrong here but to me it shows the current version as 212 and other version as 208.
MERLIN RACING
"He once ran a marathon because it was on his way"
Logic is a lost art!
You are defined in life by how you respond to defeat!
hairy is offline   Reply With Quote
Old 10-21-2010, 12:02 PM   #17764
20 SMOKE's Avatar
your right pc 1 will not upgrade to 212 it still has 208
Jamie W
Old 10-21-2010, 12:04 PM   #17765
Ok, I found the problem.
On my PC#1, if I installed v212 on another folder instead of the default one then it will show v212 as the 'current version' & the 'other version'.
However, if I re-install on v212 back on the default folder, it will show v212 as the 'current version' and v208 as the 'other version'.
strange?!?!.. but at least i got it working properly now.
and thanks for all the suggestions!
Yes, it seems like I cannot completely remove v208 from my PC#1.
hardmankam is offline   Reply With Quote
Old 10-21-2010, 12:07 PM   #17766
TrevCoult's Avatar
PC#1: Win7, 64 bit
PC#2: WinXP, 32 bit
Disable User Access Control on the computer (search for User Access Control in help and support on your PC and it will tell you how). Then uninstall the software. Then install the 212 software on your PC again. There is definitely a file it has not removed when uninstalling.
Hopefully that will then remove the file so you get a complete uninstall. If not you'll have to find and remove it manually.
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 10-21-2010, 01:50 PM   #17767
Has everyone noticed that you MUST restart your PC after installing, but before using v212? I wonder if people having problems have restarted their PC to make sure that the uninstall and install are completed correctly? This is different to previous upgrades, where you had to uninstall the old version manually before installing the new version.
Just a thought...
SlowerOne is offline   Reply With Quote
Old 10-21-2010, 01:53 PM   #17768
mine worked ok without a restart
sidecarphil1 is offline   Reply With Quote
Old 10-21-2010, 01:54 PM   #17769
BCbud's Avatar
Trader Rating: 37 (100%+)
Just a thought...
Good day!
I didn't restart my computer and it seemed to work ok but I will have to double check when I get home from work.
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Old 10-21-2010, 04:01 PM   #17770
georgec's Avatar
Installed 212 on my laptop with 64bit windows 7 OS this morning without a hitch...WooHoo!
Thanks again Tekin!
georgec is offline   Reply With Quote
Old 10-21-2010, 04:27 PM   #17771
TrevCoult's Avatar
Just a thought...
This will depend on the PC, what version of Windows, what it currently has installed and/or running. Comes down to some people will have to restart, some won't. Never any harm in restarting anyway.
I didn't have to on either my Win 7 laptop or Win XP netbook.
Trev
Schumacher Racing
Old 10-21-2010, 04:44 PM   #17772
Trev
I have installed 212 without any problems.
I've run it this evening and it works very well with 208 the trottle feel
was not so good compair it with 212.
I must say I am more confident on the trottle because it works fine
and every lap the same.
Good job Randy and the Tekin team.
Thank
Ed IJzerman
Xray t3 tekin orion
eded1 is offline   Reply With Quote
Old 10-21-2010, 04:46 PM   #17773
Thank
Ed IJzerman
Xray t3 tekin orion
How about posting your setup and motor/ gearing etc for us all to learn from ??
Just a thought
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 10-21-2010, 04:58 PM   #17774
YoDog's Avatar
Trader Rating: 26 (100%+)
Hello all,
Windows 7 handles some files a little differently than XP.
Tekin has instructions on what to do for upgrading hotwire on the W7 platform.
There is a file that is stored in the virtual store directory that must be deleted prior to installing the new update. Windows 7 will use this file to restore the program to the previous state if the new program is installed in the same directory as the old version. Not sure why Microsoft does this but it's not the first time I've had to deal with the virtual store.
Good luck
YoDog is offline   Reply With Quote
Old 10-21-2010, 05:55 PM   #17775
guinnes.s's Avatar
Default tekin rs + SP 13.5t v3 motor
hi guys just got a tekin rs + SP 13.5t v3 motor.
im new to timing setting and wonder if anyone can give me a good starting point for the timing with this motor.
im on the 212 firmware ,a setup pdf would be great.
thanx
guinnes.s is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
